BS II - line out to a PA system
Has anyone connected a pinout of a basic stamp II to the line in socket on a
PA system, in order to generate simple beeps over the PA system?
Does anything specific need to be done to the pin out in terms of resistors,
caps, etc. in order to feed into the PA? Is there a dange the PA would
somehow damage the stamp?
ARC in Lago Vista, TX
"Advertising may be described as the science of arresting human intelligence
long enough to get money from it." - Stephen Butler Leacock
ARC -
This is mostly a safety warning, both personal, and for the Stamp.
You need to check the voltage of the PA system voltage. Some have a voltage
potential of 70.7 volts. These are generally found in commercial application,
schools, large auditoriums, etc (I beleive). Check that first, before going
any further (alternate thot below). There are usually fairly simple solutions
to the interface, but knowing what you have at each end will be key.
There are lots of audio gurus here, once you can supply the information they
require. The make, model and other pertinant info from the label on the
amplifier
will certainly be a help.
Bruce
I am across the lake,
small world
we ought to get together and talk stamps sometime
I just finished a stamp application that you might be interested in
pick the top link about night blades
http://www.inetport.com/~davisele/fc.html
richard Friedrich
Lakeway, TX
Original Message
To: <basicstamps@egroups.com>
Sent: Thursday, April 13, 2000 10:34 AM
Subject: [noparse][[/noparse]basicstamps] BS II - line out to a PA system
a
resistors,
intelligence
I'm anything but an electronics guy - I volunteered to help out with my
daughter's archery and they needed a fancy timer - not my brightest moment, but
I'm hoping to get the damn thing done tonite in time for a tournament
.....tomorrow! aieee..... [noparse]:)[/noparse]
dakota wrote:
> hey Ron, hello
> small world
> richard Friedrich
> Lakeway, TX
Original Message
> From: A.Ron Carmichael <arc@i...>
> a
> resistors,
> intelligence
In the 60's people took acid to make the world weird. Now the world is weird,
people take prozac to make it normal.
didn't mean to blather on like that....
Bruce Bates wrote:
> At 10:34 AM 4/13/00 -0500, A.Ron Carmichael promulgated:
> ARC -
> amplifier
> Regards,
> Bruce
microphone laid close to the small speaker, and hope there is no feedback.....
> ARC -
> amplifier
> Regards,
> Bruce
