BS II - line out to a PA system — Parallax Forums
edited 2000-04-13 22:28 in General Discussion
Has anyone connected a pinout of a basic stamp II to the line in socket on a
PA system, in order to generate simple beeps over the PA system?
Does anything specific need to be done to the pin out in terms of resistors,
caps, etc. in order to feed into the PA? Is there a dange the PA would
somehow damage the stamp?
ARC in Lago Vista, TX
"Advertising may be described as the science of arresting human intelligence
long enough to get money from it." - Stephen Butler Leacock
    edited 2000-04-13 17:35
    At 10:34 AM 4/13/00 -0500, A.Ron Carmichael promulgated:
    ARC -
    This is mostly a safety warning, both personal, and for the Stamp.
    You need to check the voltage of the PA system voltage. Some have a voltage
    potential of 70.7 volts. These are generally found in commercial application,
    schools, large auditoriums, etc (I beleive). Check that first, before going
    any further (alternate thot below). There are usually fairly simple solutions
    to the interface, but knowing what you have at each end will be key.
    There are lots of audio gurus here, once you can supply the information they
    require. The make, model and other pertinant info from the label on the
    amplifier
    will certainly be a help.
    Bruce
    edited 2000-04-13 18:11
    hey Ron, hello
    I am across the lake,
    small world
    we ought to get together and talk stamps sometime
    I just finished a stamp application that you might be interested in
    pick the top link about night blades
    http://www.inetport.com/~davisele/fc.html
    richard Friedrich
    Lakeway, TX
    To: <basicstamps@egroups.com>
    Sent: Thursday, April 13, 2000 10:34 AM
    Subject: [noparse][[/noparse]basicstamps] BS II - line out to a PA system
    a
    resistors,
    intelligence
    edited 2000-04-13 22:25
    small world indeed - yew are on inetport also? <G>
    I'm anything but an electronics guy - I volunteered to help out with my
    daughter's archery and they needed a fancy timer - not my brightest moment, but
    I'm hoping to get the damn thing done tonite in time for a tournament
    .....tomorrow! aieee..... [noparse]:)[/noparse]
    dakota wrote:
    > hey Ron, hello
    > small world
    > richard Friedrich
    > Lakeway, TX
    > From: A.Ron Carmichael <arc@i...>
    > a
    > resistors,
    > intelligence
    In the 60's people took acid to make the world weird. Now the world is weird,
    people take prozac to make it normal.
    edited 2000-04-13 22:26
    oops. my apologies, folks....I thought I was responding to a private email - I
    didn't mean to blather on like that....
    > ARC -
    > amplifier
    > Regards,
    > Bruce
    acknowledged and thanks - due to time shortage I will probably just have a
    microphone laid close to the small speaker, and hope there is no feedback.....
    > ARC -
    > amplifier
    > Regards,
    > Bruce
