BS2 to EDE702 to LCD, Problem with LCD — Parallax Forums
ArchiverArchiver Posts: 46,084
edited 2000-03-28 21:37 in General Discussion
I am having problems with my LCD,
I am new to this and I got an LCD, I am trying to hook it up to my BS2, it is not serial, I got it from DIGI-KEY and the vendor is Varatronics and the only numbers I see on·the PCB are 16265 R3, but from looking around I assume most LCD's have the same pin info. on the back there are 2 micro's with stickers over them, one is the HD44100FS, and the·other is HD44780A00
The LCD I have is 16x2 and its backlit. its 16 pins, the first two being the backlight, so 14 pins.
when the power is enabled alls I get is the first line full of boxes?, I haven't seen it do much else, I bought a EDE702 Serial interface and still no difference, thought it would make it less confusing to figure out what was wrong. its nice to only have 3 wire interface as·opposed to·regular way.
The EDE702 is working I can turn an LED on and off via the digital output on the EDE702 so I know the chip works with my serout command , but no change on the LCD.. I have been trying to figure it out. driving me nuts
is there an easy way to know if the LCD works? like a test or something?
can anyone help me out!
Thanks in advance
Tyson
tysonstephen@home.com
  • ArchiverArchiver Posts: 46,084
    edited 2000-03-27 22:54
    I think the backlight should be 15,16 and if you have it hooked up right and
    there are still
    boxes on line one then hook pin 4 to ground all should be fine
    not serial,
    see on the PCB
    info. on the
    the other is
    > HD44780A00
    backlight, so
    > 14 pins.
    haven't seen it
    thought it would
    wire
    > interface as opposed to regular way.
    the EDE702 so
    have been
    > Thanks in advance
    > Tyson
    > tysonstephen@h...
    > eGroups.com Home: http://www.egroups.com/group/basicstamps
    > www.egroups.com - Simplifying group communications
    edited 2000-03-27 23:02
    Original Message
    To: <basicstamps@egroups.com>
    Sent: Monday, March 27, 2000 1:54 PM
    Subject: [noparse][[/noparse]basicstamps] Re: BS2 to EDE702 to LCD, Problem with LCD
    and there are still
    well the backlight is the two pins before pin 1, pin 1 is marked. and I
    don't have any probs lighting the back. but I just can't get this thing to
    work. I have tried grounding pin 4 which is the RS and I still have a first
    line full of black boxes.
    it is not serial,
    numbers I see on the PCB
    pin info. on the
    and the other is
    > > HD44780A00
    the backlight, so
    > > 14 pins.
    haven't seen it
    have 3 wire
    LCD.. I have been
    > > Thanks in advance
    > > Tyson
    > > tysonstephen@h...
    > -- Check out your group's private Chat room
    > -- http://www.egroups.com/ChatPage?listName=basicstamps&m=1
    edited 2000-03-27 23:33
    The RS pin needs to be connected to the EDE chip, not to ground.
    Doublecheck your wiring, with me it's always the wiring. The line of boxes
    means the LCD is being powered up without the controller being initialized.
    You have to tell_the_controller that it's a two line display. I have some
    control codes (and other LCD links) on my page at:
    http://www3.sympatico.ca/orthner/serialcd.html
    Cheers, Duncan
    edited 2000-03-28 11:58
    Original Message
    Sent: Monday, March 27, 2000 2:33 PM
    to
    first
    initialized.
    > Cheers, Duncan
    Well I am still having problems so I will give you all a general Idea of
    what the circuit looks like
    I have pin 1, 2, 3, 4 of the EDE all to 5V, pin1 is the baud 2400=0,9600=1,
    and pin 2 is the polarity, 0=inverted, 1=standard. and pin 3 and pin 4 are 5
    volts
    pin 5 is connected to ground
    pin 6 is connected to the enable pin 6 on the LCD
    pin 7 is the RS pin 4 on the LCD
    pin 8 is the RW pin 5 on the LCD
    pin 9 NA
    pin 10 is connected to DB4 on the LCD pin 11
    pin 11 is connected to DB5 on the LCD pin 12
    pin 12 is connected to DB6 on the LCd pin 13
    pin 13 is connected to DB7 on the LCD pin 14
    pin 14 is connected to 5v which is connected to the LCD pin 2
    pin 15 and 16 are connected together with a 4mhz resonator
    pin 17 is the data line connected to pin 7 on the basic stamp 2
    pin 18 is the digital out, which I have an LED connected to, which works
    when I send the command
    serout 7, n9600,[noparse][[/noparse]$FE]
    serout 7, n9600,[noparse][[/noparse]%11111100] to turn the LED on and [noparse][[/noparse]%11111101 to turn it on.
    pin 1 on the LCD is connected to ground, pin 2 is connected to 5v and pin 3
    is connected to the POT.
    ok my basic stamp 2 code sorta goes like this
    N9600 con 84 ' Variable defination and 84 is what I got from the basic stamp
    manual for 9600 baud non inverted.
    lcd con 7 ' definition that the LCD data line is pin7
    loop:
    pause 200 ' to let the LCD initialize, never initializes though
    serout 7, n9600,[noparse][[/noparse]%000011]
    pause 10
    pause 10
    pause 10
    serout 7, n9600,[noparse][[/noparse]%000010]
    pause 10
    serout 7, n9600,[noparse][[/noparse]%001010]
    pause 10
    serout 7, n9600,[noparse][[/noparse]%001000]
    pause 10
    serout 7, n9600,[noparse][[/noparse]%000001]
    pause 10
    serout 7, n9600,[noparse][[/noparse]%000110]
    pause 10
    serout 7, n9600,[noparse][[/noparse]$01]
    pause 10
    pause 10
    serout LCD,N9600,[noparse][[/noparse]"Hello LCD"] 'Supposed to print this on LCD'
    serout 7,n9600,[noparse][[/noparse]$FE] '=254 blank space?
    serout 7,n9600,[noparse][[/noparse]$C0] '=goes to second line
    pause 10
    serout 7,n9600,[noparse][[/noparse]"This should be the second line"]
    This is where I got the info for initializing any HD44780 Controlled LCD
    When interface is 4-bits wide
    [noparse][[/noparse]Power ON]
    [noparse][[/noparse] Wait more than 15ms ]
    [noparse][[/noparse]after Vdd rises to 4.5v]
    RS R/W DB7 DB6 DB5 DB4 Can't check BF before this instruction
    0 0 0 0 1 1 Function set (8-bit interface)
    [noparse][[/noparse]Wait more than]
    [noparse][[/noparse] 4.1ms ]
    [noparse][[/noparse] 100us ]
    BF can be checked after the following
    instructions. When BF is not checked,
    the waiting time between instructions
    is longer than the execution time.
    (See Instruction set)
    0 0 0 0 1 0 Function set (to 4-bit interface)
    0 0 0 0 1 0
    0 0 N F * * Function set [noparse][[/noparse]4-bit Interface ]
    [noparse][[/noparse]Specify display lines]
    RS R/W DB7 DB6 DB5 DB4 [noparse][[/noparse]and character font ]
    0 0 0 0 0 0 These cannot be
    0 0 1 0 0 0 Display OFF changed afterwards
    0 0 0 0 0 0
    0 0 0 0 0 1 Display ON
    0 0 0 0 0 0
    0 0 0 1 I/D S entry mode set
    I am not sure I put this in my code correctly, since nothing works I have
    tried numerous combinations.
    if this is not clear email me and I will try to explain better....
    edited 2000-03-28 17:32
    Your hardware connection looks good, and the fact that the EDE702 is
    receiving serial data and toggling the LED means that quite a few things are
    correct. Since you can see the top row of segments on, it sounds as if your
    contrast is O.K. but that the LCD is never being initialized. I noticed
    that you had code for initializing the LCD; this shouldn't be necessary, as
    the EDE702 handles all of this at powerup; you should only need to connect
    the EDE702 to the LCD, power it up, and all segments will be blank with the
    display initialized. You can write text without any further initialization
    on your part.
    Is the LCD module connector a 1x14 or 2x7 connector? Sometimes it's easy to
    miswire those 2x7 connectors and mistake the pin count. Also, I've seen a
    lot of connections from the EDE702 to the lower nibble of the LCD module; it
    needs to be to the upper. Doublecheck that as well. If you're still stuck,
    give me a call at (816) 257-9954 and we'll walk through the circuit pin by
    pin.
    Good luck,
    Todd Peterson
    E-Lab Digital Engineering, Inc.
    --Manufacturers of the EDExx IC Family--
    (816) 257-9954 FAX: (816) 257-9945
    http://www.elabinc.com
    Original Message
    Sent: Tuesday, March 28, 2000 8:32 AM
    are
    your
    as
    the
    initialization
    > on your part.
    to
    it
    stuck,
    > pin.
    Yah I knew that the ede702 did all the initializing, but when it didn't work
    I just was trying everything... [noparse]:)[/noparse]..
    its a 1-16 pin configuration so
    The vss is labeled pin 1
    0 0 0 0 0 0 0 0 0
    0 0 0 0 0 0 0
    db7 db6 db5 db4 db3 db2 db1 db0 E RW RS
    VEE VDD VSS + - for the back light
    Pardon my knwoledge gap, but what exactly do you mean be the lower nibble of
    the LCD? I think i have heard a few things like this but don't know what it
    means.
    Thanks a bunch I am learning a lot from this problem.
    -Tyson
