Help on a NEC 286 Laptop
I just came across the deal of the century. A 286 laptop computer for a mere
$10. This actually works. I already have it up and programming both
versions of the basic stamps, and pic microcontrollers. It has a massive 20
Mbyte hard drive, and a whopping 640 kbytes of RAM. The floppy drive and
the serial and parallel ports work! The LCD display is black and white.
All working just fine.
The only draw back is that the screen background is white and the text is
black. Not a big deal, but when using EDIT for writing programs, the
alt-key characters are black and don't show up on the screen when the menu
background is black also.
Does anyone know if the is a DOS command that will make the background be
black, and the characters you type show up as white. On my regular Pentium
60 computer the background is black and the characters are white.
It has been a long time since I had to deal with congifuration files for DOS
mode applications.
This computer is running DOS 5.0
Any info would be appreciated.
Also, anyone have any idea where I could find manuals for this computer. I
have checked out the NEC web site, and there is nothing about this computer
on there web site. Their web site doesn't even recognise the serial number
of the computer.
Pete Miles
petem@w...
mode applications.
of the computer.
Pete Miles
petem@w...
and then use ANSI codes in your PROMPT enviroment variable. I think it
would be something like this:
PROMPT $E[noparse][[/noparse]7h$E[noparse][[/noparse]0m$P$G
Put that in your AUTOEXEC.BAT and it should make your background black and
foreground white. I may be mistaken on the syntax, it has been a long time
since I messed with ANSI and prompts.
This fix is kind of hokey, but should do what you need.
Original Message
From: Pete Miles [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=-875542FIjMK5MF8X8m7E5yk2PnjR0TShQJZvcF5VmLQ_dR-1-D9Dg0ODP6_obQ-u-A9PITjIzwVKyY5iA]PeteM@W...[/url
Sent: Monday, March 13, 2000 9:35 AM
To: 'basicstamps@egroups.com'
Subject: [noparse][[/noparse]basicstamps] [noparse][[/noparse]OT] Help on a NEC 286 Laptop
mode applications.
of the computer.
Pete Miles
petem@w...
-- 20 megs of disk space in your group's Document Vault
-- http://www.egroups.com/docvault/basicstamps/?m=1
It is usually the dos directory as in:
DEVICE=C:\DOS\ANSI.SYS.
Dan
Dan Sherman Dsherman@r...
Computer Technician NWCCD - Sheridan College
3059 Coffeen Ave. Sheridan, WY. 82801
307-674-6446 x6225 http://www.sc.whecn.edu/~dsherman
Original Message
From: Levi Ruiz [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=wzXaFbQtHasU5KLLg-Vzne5ClUub78XXguLyEQqkjne1iHvVqDSbh18h4MH2Sg0c4xUNtx0LEWUgmEA]Levi@P...[/url
Sent: Monday, March 13, 2000 10:56 AM
Subject: [noparse][[/noparse]basicstamps] Re: [noparse][[/noparse]OT] Help on a NEC 286 Laptop
Well, one way to fix it would be to add "DEVICE=ANSI.SYS" in your CONFIG.SYS
Original Message
From: Pete Miles [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=W9YP0hQuxzsTeSwSj_ajmp7sso9fnhN5PwxeuH3MphiXu083w7dmUiK6w6054Rv0vSczlgx8UkfoWlWL8yf0-w]PeteM@W...[/url
mode applications.
of the computer.
Pete Miles
petem@w...
eGroups.com home: http://www.egroups.com/group/basicstamps
http://www.egroups.com - Simplifying group communications
the ability to show reverse video, is on the options-color or options-video
menu.
Larry Nielsen
> mode applications.
> of the computer.
> Pete Miles
> petem@w...
reverse the colours.
Original Message
To: <basicstamps@egroups.com>
Sent: Tuesday, March 14, 2000 4:04 AM
mere
20
Pentium
DOS
> mode applications.
I
computer
number
> of the computer.
> Pete Miles
> petem@w...
C:\WINDOWS>edit /?
EDIT [noparse][[/noparse]/B] [noparse][[/noparse]/H] [noparse][[/noparse]/R] [noparse][[/noparse]/S] [noparse][[/noparse]/<nnn>] [noparse][[/noparse]/?] [noparse][[/noparse]file(s)]
/B - Forces monochrome mode.
/H - Displays the maximum number of lines possible for your hardware.
/R - Load file(s) in read-only mode.
/S - Forces the use of short filenames.
/<nnn> - Load binary file(s), wrapping lines to <nnn> characters wide.
/? - Displays this help screen.
[noparse][[/noparse]file] - Specifies initial files(s) to load. Wildcards and multiple
filespecs can be given.
