Help on a NEC 286 Laptop — Parallax Forums
edited 2000-03-13 23:27 in General Discussion
I just came across the deal of the century. A 286 laptop computer for a mere
$10. This actually works. I already have it up and programming both
versions of the basic stamps, and pic microcontrollers. It has a massive 20
Mbyte hard drive, and a whopping 640 kbytes of RAM. The floppy drive and
the serial and parallel ports work! The LCD display is black and white.
All working just fine.
The only draw back is that the screen background is white and the text is
black. Not a big deal, but when using EDIT for writing programs, the
alt-key characters are black and don't show up on the screen when the menu
background is black also.
Does anyone know if the is a DOS command that will make the background be
black, and the characters you type show up as white. On my regular Pentium
60 computer the background is black and the characters are white.
It has been a long time since I had to deal with congifuration files for DOS
mode applications.
This computer is running DOS 5.0
Any info would be appreciated.
Also, anyone have any idea where I could find manuals for this computer. I
have checked out the NEC web site, and there is nothing about this computer
on there web site. Their web site doesn't even recognise the serial number
of the computer.
Pete Miles
petem@w...
    edited 2000-03-13 17:56
    Well, one way to fix it would be to add "DEVICE=ANSI.SYS" in your CONFIG.SYS
    and then use ANSI codes in your PROMPT enviroment variable. I think it
    would be something like this:
    PROMPT $E[noparse][[/noparse]7h$E[noparse][[/noparse]0m$P$G
    Put that in your AUTOEXEC.BAT and it should make your background black and
    foreground white. I may be mistaken on the syntax, it has been a long time
    since I messed with ANSI and prompts.
    This fix is kind of hokey, but should do what you need.
    From: Pete Miles [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=-875542FIjMK5MF8X8m7E5yk2PnjR0TShQJZvcF5VmLQ_dR-1-D9Dg0ODP6_obQ-u-A9PITjIzwVKyY5iA]PeteM@W...[/url
    Sent: Monday, March 13, 2000 9:35 AM
    To: 'basicstamps@egroups.com'
    Subject: [noparse][[/noparse]basicstamps] [noparse][[/noparse]OT] Help on a NEC 286 Laptop
    mode applications.
    of the computer.
    Pete Miles
    petem@w...
    -- 20 megs of disk space in your group's Document Vault
    -- http://www.egroups.com/docvault/basicstamps/?m=1
    edited 2000-03-13 18:07
    You also have to add the path to wherever the file ansi.sys resides as in.
    It is usually the dos directory as in:
    DEVICE=C:\DOS\ANSI.SYS.
    Dan
    Dan Sherman Dsherman@r...
    Computer Technician NWCCD - Sheridan College
    3059 Coffeen Ave. Sheridan, WY. 82801
    307-674-6446 x6225 http://www.sc.whecn.edu/~dsherman
    From: Levi Ruiz [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=wzXaFbQtHasU5KLLg-Vzne5ClUub78XXguLyEQqkjne1iHvVqDSbh18h4MH2Sg0c4xUNtx0LEWUgmEA]Levi@P...[/url
    Sent: Monday, March 13, 2000 10:56 AM
    Subject: [noparse][[/noparse]basicstamps] Re: [noparse][[/noparse]OT] Help on a NEC 286 Laptop
    From: Pete Miles [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=W9YP0hQuxzsTeSwSj_ajmp7sso9fnhN5PwxeuH3MphiXu083w7dmUiK6w6054Rv0vSczlgx8UkfoWlWL8yf0-w]PeteM@W...[/url
    mode applications.
    of the computer.
    Pete Miles
    petem@w...
    eGroups.com home: http://www.egroups.com/group/basicstamps
    http://www.egroups.com - Simplifying group communications
    edited 2000-03-13 18:40
    Find the program DOSSHELL.EXE and run it. It has lots of neat stuff including
    the ability to show reverse video, is on the options-color or options-video
    menu.
    Larry Nielsen
    > mode applications.
    > of the computer.
    > Pete Miles
    > petem@w...
    edited 2000-03-13 22:31
    this is usualy a hardware thing. try looking for a function key that will
    reverse the colours.
    To: <basicstamps@egroups.com>
    Sent: Tuesday, March 14, 2000 4:04 AM
    mere
    20
    Pentium
    DOS
    > mode applications.
    I
    computer
    number
    > of the computer.
    > Pete Miles
    > petem@w...
    You also may want to try the monochrome option when running EDIT from DOS.
    C:\WINDOWS>edit /?
    EDIT [noparse][[/noparse]/B] [noparse][[/noparse]/H] [noparse][[/noparse]/R] [noparse][[/noparse]/S] [noparse][[/noparse]/<nnn>] [noparse][[/noparse]/?] [noparse][[/noparse]file(s)]
    /B - Forces monochrome mode.
    /H - Displays the maximum number of lines possible for your hardware.
    /R - Load file(s) in read-only mode.
    /S - Forces the use of short filenames.
    /<nnn> - Load binary file(s), wrapping lines to <nnn> characters wide.
    /? - Displays this help screen.
    [noparse][[/noparse]file] - Specifies initial files(s) to load. Wildcards and multiple
    filespecs can be given.
