Reset Switch on BOE Rev A — Parallax Forums
Photon ArtistPhoton Artist Posts: 18
edited 2004-09-01 00:57 in BASIC Stamp
I need a part number/supplier for the reset switch used on the BOE revision A.
I need to purchase them in bulk..
Rus
"My mind wanders...I'm just along for the ride!
  • NewzedNewzed Posts: 2,503
    edited 2004-08-27 13:49
    Go to the parallax site, Browse All Products/Components/Miscellaneous and scroll down until you see the little pushbutton.· It is just above the Tact Switch.
    Sid Weaver
    Pluggable Serial Backpack
    http://hometown.aol.com/newzed/index.html
    edited 2004-08-27 14:20
    You can get those kinds of switches in bulk from companies like Digi-Key and Mouser.
    Jon Williams
    Dallas Office
    edited 2004-08-27 14:22
    Jameco is another source...
    http://www.jameco.com
    Chris Savage
    Knight Designs
    324 West Main Street
    P.O. Box 97
    Montour Falls, NY 14865
    (607) 535-6777
    Business Page:·· http://www.knightdesigns.com
    Personal Page:··· http://www.lightlink.com/dream/chris
  • Photon ArtistPhoton Artist Posts: 18
    edited 2004-08-28 00:05
    Hey Jon,
    You wouldn't happen to have a part number?
    I looked at the Digi-Key site and needless to say making my own switch from a hairbrush, a paperclip, and some twine would be easier than sorting through the specs!· LOL! lol.gif
    I am designing a board that uses the OEM BS2 to drive the outputs...I have modeled the power supply section after the BOE rev A.
    I thought the switch used on the BOE appeared a bit more robust than a numberof others switches of similar type.
    Rus
    Jon Williams said...
    edited 2004-08-28 00:42
    I don't have the part number -- but I do have a Digi-Key (Sep-Dec 2004) catalog ... and the ability to crack it open. smilewinkgrin.gif
    In two seconds I was directed to page 1078 of the catalog, and Figure 1 on that page is identical to the switch on our boards.· There are about 15 options for that board spacing, here's the part numbers I would suggest investigating:
    P8010S-ND
    P10890S-ND
    P12192S-ND
    P12195S-ND
    Okay, now you owe me a Guiness (I'm Irish turn.gif ).
    Jon Williams
    Dallas Office
    edited 2004-08-28 01:48
    Jon,
    I definitely need the Catalog!!!
    I will most definitely buy you a Guiness!!
    P8010S-ND
    P10890S-ND
    P12192S-ND
    P12195S-ND
  • Frank SmithFrank Smith Posts: 4
    edited 2004-08-29 00:36
    Rus,
    I have been needing that part number also. Glad you asked!
    Have you come across a part number for the power connectors? I have the NX-1000 24/40 board. The wall wart available through Parallax connects to that board.
    Jon, Thanks for replying! I'd buy you a Guiness too. I am part Irish.
    Frank
    edited 2004-08-30 03:02
    The part number for the power connector that I am using is...
    2.1mm (DigiKeyCP-202A)·
    From what I understand this is a pretty common plug size...however, I am also open to other suggestions....
    Rus
    edited 2004-08-31 10:50
    Thanks Rus!
    I will check that out later. The DigiKey search function isn't working at the moment.
    Frank
    edited 2004-08-31 12:13
    Take a look at Digikey's SC1153.· It's the same as what is on the BOEs.
    Sid Weaver
    Hey Sid,
    That looks good. Thanks!
    Take care,
    Frank
