Reset Switch on BOE Rev A
I need a part number/supplier for the reset switch used on the BOE revision A.
I need to purchase them in bulk..
Rus
"My mind wanders...I'm just along for the ride!
Rus
Sid Weaver
Pluggable Serial Backpack
Jon Williams
Dallas Office
http://www.jameco.com
Knight Designs
324 West Main Street
P.O. Box 97
Montour Falls, NY 14865
(607) 535-6777
Business Page:·· http://www.knightdesigns.com
Personal Page:··· http://www.lightlink.com/dream/chris
You wouldn't happen to have a part number?
I looked at the Digi-Key site and needless to say making my own switch from a hairbrush, a paperclip, and some twine would be easier than sorting through the specs!· LOL!
I am designing a board that uses the OEM BS2 to drive the outputs...I have modeled the power supply section after the BOE rev A.
I thought the switch used on the BOE appeared a bit more robust than a numberof others switches of similar type.
Rus
In two seconds I was directed to page 1078 of the catalog, and Figure 1 on that page is identical to the switch on our boards.· There are about 15 options for that board spacing, here's the part numbers I would suggest investigating:
P8010S-ND
P10890S-ND
P12192S-ND
P12195S-ND
Okay, now you owe me a Guiness (I'm Irish
Jon Williams
Dallas Office
I definitely need the Catalog!!!
I will most definitely buy you a Guiness!!
I have been needing that part number also. Glad you asked!
Have you come across a part number for the power connectors? I have the NX-1000 24/40 board. The wall wart available through Parallax connects to that board.
Jon, Thanks for replying! I'd buy you a Guiness too. I am part Irish.
Frank
2.1mm (DigiKeyCP-202A)·
From what I understand this is a pretty common plug size...however, I am also open to other suggestions....
Rus
I will check that out later. The DigiKey search function isn't working at the moment.
Frank
Sid Weaver
That looks good. Thanks!
Take care,
Frank
