Code Help Please -- Counting Button Presses — Parallax Forums
dk_akjdk_akj Posts: 37
edited 2004-08-18 19:46 in BASIC Stamp
Hi,
This code gives me trouble.
It is supposed to count how many times pin 4 goes high.
FOR i = 1 TO 4
· DEBUG "press button x times" , DEC i,CR,LF
· COUNT 4, 25000, m_PulseCount
· DEBUG "got " , DEC m_PulseCount,CR,LF
NEXT
It counts, but it counts way to many, if i press the button 4 times it counts 8 or 10.
I have a 10K pulldown resistor on pin 4.
Can it be the button bounching ? It is the printbutton that i gor with my education board.
What can I do to solve my problem ??
//akj
Post Edited By Moderator (Jon Williams) : 8/17/2004 8:39:43 PM GMT
    edited 2004-08-17 20:11
    It sounds like contact bounce is your problem...If you're trying to COUNT pulses from a mechanical device such as a pushbutton, you may want to use the BUTTON command instead.· It handles debounce, and even repeat.
    Chris Savage
    Knight Designs
    324 West Main Street
    P.O. Box 97
    Montour Falls, NY 14865
    (607) 535-6777
    Business Page:·· http://www.knightdesigns.com
    Personal Page:··· http://www.lightlink.com/dream/chris
  • Tracy AllenTracy Allen Posts: 6,658
    edited 2004-08-17 21:48
    Or add an RC circuit in parallel with your switch, say C=0.1uf. That should absorb the bounce. You might have to increase the value of your pulldown resistor to 49k or 100k.
    Tracy Allen
    www.emesystems.com
  • dk_akjdk_akj Posts: 37
    edited 2004-08-18 06:36
    Thanks.
    I'll try that.
    //akj
    Now it works
    I'm using the button function.
    //Akj
