Problem with "subject" line in emailed messages
Hi there.
I'm having a problem when reading some of the emailed messages: the subject field appears blank. It appears as if there is a <newline> in front of the actual subject line.
I enclose a typical header:
Reply-To: ForumAdmin@parallax.com
To: dwayner@planet.eon.net
Date: Sat, 14 Aug 2004 01:18:29 GMT
Organization: Parallax, Inc.
Message-Id: <fba8bc125db54730b279688498c1f6a8@ZEUS>
Subject:
Re: [noparse][[/noparse]The Sandbox] LCD Dot Matrix Displays and the BS
Mime-Version: 1.0
X-Mailer: devMail.Net (2.5.1629.31246-0)
Content-Type: text/plain; charset="iso-8859-1"
Priority: Normal
X-Priority: 3
Return-Path: ForumAdmin@parallax.com
X-OriginalArrivalTime: 14 Aug 2004 01:18:29.0250 (UTC) FILETIME=[noparse][[/noparse]9B3C0620:01C4819C]
I'm using Eudora 6.0.1.1.
Any thoughts as to what is causing that behavior and what might be done to fix it?
Thanks!
dwayne
Subject:
Mime-Version: 1.0
Priority: Normal
X-Priority: 3
Thanks!
dwayne
Sid
No, that does not appear to be the problem. Here is a copy of the relevant lines from the header I posted earlier:
Subject:
Notice how the actual subject line is on its own line below the Subject header.
Hopefully Jim will see this and offer a comment.
dwayne
Jim
Parallax IT Dept.
Jim
Parallax IT Dept.
Sid
