BS2e Help
in BASIC Stamp
I've got an old electronics project I designed years ago around the Basic Stamp BS2e (24pin). Well, I extracted the BS2e chip some time ago to build something else and now I want to get the original project back up. I have the original PBasic code but I'm in need of that BS2e chip. My design exceeds the memory availability of the BS2 chip ....which I can buy online. If anyone can direct me to a supplier that would be appreciated. If these IC's are no longer available, is there another product I can drop in its place (same footprint and accepts the original BS2e design code). Thanks !
If you post your code you might find suggestions that help you shrink it to fit the memory you have.
