@FredBlais said:
@RossH
I've got a working port of the Berry Language working on the Propeller 2 compiled using Catalina. See https://berry-lang.github.io
Great! I don't know Berry, but I'll look it up tomorrow.
Berry looks interesting. I immediately saw that it's very "Lua like". And when I read further, I found this was exactly the intent. The author of Berry says:
I used to pay more attention to Lua because it is a very compact embedded scripting language, and its design goal is to be embedded in the host program. However, for the microcontroller, the Lua interpreter may not be small enough, and I cannot run it on a 32-bit microcontroller with a relatively small memory. To this end, I started to read Lua code and developed my own scripting language-Berry on this basis.
On the Propeller 2, the overhead of full embedded Lua is about 180kb of code. The author of Berry says the minimum memory required to run "full" Berry is about 128kb of EEPROM (which I interpret to mean about 128kb of code) so it looks quite promising. I'll have a play and see what its performance is like compared to Lua.
Berry may not replace Lua as my preferred Propeller language but thanks for bringing it to my attention. The more languages we get working on the Propeller, the better!
I managed to get your port of Berry to build on Linux easily enough, but I have to load it manually. Here is the payload command I use (assumes the Propeller is on port /dev/ttyUSB0):
No luck with Windows - I had to modify py -3 to python3 in the scripts, but when bash executes catalina, it cannot locate clcc, which indicate that either the LCCDIR environment variable or the path is not being set. In bash (and assuming Catalina is installed in /C/users/rossh/Catalina), you need to do:
Yesterday I started to work on a way to make Berry lunch a new berry instance on another cog to execute the closure I give it.
This looks to be similar to Catalina's multi-processing Lua extensions. What mechanism do you intend to use to synchronize and communicate between instances? I see references to mailboxes in your code - that is a reasonable choice for a communication mechanism but it looks like you use them only for passing arguments to the function - is there a facility to return data as well?
And 3 synchronization mechanisms:
1. condition variables (as per Posix)
2. mutexes (as per Posix)
3. Propeller locks
Plus, if the instances are executing on same Propeller (they may not be) then you can also just use shared memory (Catalina's eLua client/server programs use this mechanism).
This is probably overkill - one of each type of mechanism is probably sufficient, but these choices are partly historical (i.e. inherited from the original luaproc package). See the documents Lua on the Propeller 2 with Catalina and Aloha from Lua for more details.
Catalina 8.8.8 has been released on GitHub and SourceForge. If you believe in Chinese numerology, this should be a very, very, very lucky release!
This is a full release. It updates Cake to 0.13.14, which adds support for C bit-fields, and also contains minor enhancements, bug fixes and documentation updates.
Here is the relevant extract from the README.TXT:
New Functionality
1. Cake updated (to 0.13.14). This version has support for C bit-fields.
2. Catalina has a new command line option '-Y' (i.e. minus capital Y)
which tells Catalina to preprocess the C sources but not to compile them.
The preprocessed output files will be written into a 'catalina' subfolder
in the current directory. Since there may be more than one source file,
any '-o' option is ignored, and the output files will have the same names
as the input files. For example:
catalina -Y hello.c bye.c
will generate two output files - 'catalina/hello.c' and 'catalina/bye.c'.
3. Catalina now accepts debug options (i.e. -g or -g3) in conjunction
with C standards other than -C89 or -C90, but issues a warning that
the options may be incompatible. While Catalina's version of Cake now
generates #line directives (which allow the Catalina debugger to display
the line being debugged) debugger support is still very experimental.
Cake changes the source so much that some debugger commands may not
work as expected - e.g. Cake may remove, rename or add new variables,
and also remove, modify, re-arrange or add new lines of source code.
Another option is to first use Cake to translate C99 (or later) source
files to C89, and then compile and debug THOSE files. To do this, add the
new -Y command-line option to a catalina command, which tells Catalina to
preprocess the source files but not compile them. It is important to add
all the correct compile-time options (e.g. libraries and other options)
so that the file will be pre-processed correctly. Any -o option will be
ignored - instead, since there may be more than one source file, the
preprocessed files will be written to a 'catalina' subfolder created in
the current directory, with the same names as the original files.
For example, if the command used to compile %LCCDIR%\demos\hello_99.c
WITHOUT debugging is:
catalina hello_99.c -p2 -C99 -lci -C P2_EDGE -C VGA
Then to generate the C89 version, first add -Y to that command:
catalina hello_99.c -p2 -C99 -lci -C P2_EDGE -C VGA -Y
Then the file catalina\hello_99.c can be compiled for debugging,
loaded and debugged as follows:
catalina catalina\hello_99.c -p2 -lci -C P2_EDGE -C VGA -g3
payload -o2 catalina\hello_99
blackbox catalina\hello_99
Other Changes
1. Document 'Lua on the Propeller with Catalina' updated.
2. Document 'Catalina Optimizer Reference Manual' updated.
3. The notes in CATALINA.TXT in the demos/coremark directory have been
updated to remove the references to 'force_rebuild' (which is not
implemented in the coremark makefile!) and also add that faster
single-threaded coremark results can be obtained by defining the
Catalina symbols NO_INTERRUPTS and FAST_SAVE_RESTORE - this speeds
up coremark by about 25%
4. Fixed a bug in the Catalina Optimizer, which means that Optimizing
programs that contained inline PASM could cause the program to fail.
The Optimizer now skips all code contained in inline PASM statements,
because (a) such code does not necessarily use the same memory model as
the code generated by LCC (which the Optimizer assumed was always the
case), and (b) because optimizing code can change code size and timing,
which could be critical in hand-coded PASM.
Affected the Propeller 1 and 2, on Windows and Linux.
5. Fixed a bug in the Catalina Optimizer, which means that Optimizing
COMPACT programs could cause the program to fail, because the Optimizer
was not retaining some "alignl" statements that were REQUIRED for the
code to execute correctly (e.g. after an I16B_CALI instruction).
6. Fixed a bug in the inline PASM demo inline_pasm/test_inline_pasm_5.c,
which did not correct for pin numbers >= 32 (i.e. accessed via Port B).
Affected the Propeller 2 only, on Windows. Linux and Catalyst.
7. Fixed a bug in the Blackbox source level debugger, which was sometimes
assigning breakpoint addresses to the wrong source line. The debugger
executed the breakpoints correctly, but may have displayed the wrong
source line when the breakpoint address was reached.
I've pushed v8.8.9 to GitHub, but I don't intend to turn it into an official release yet because I still have more testing to do and I won't get much chance in the next week or two. But it might be useful for those on the bleeding edge to have it available now (e..g. @FredBlais - the VLA support will make Berry easier to port and maintain).
The significant changes are:
1. Cake now supports C99 Variable Length Arrays. This means Catalina's C99 language support (via Cake) is essentially complete.
2. Catalina now generates identical code on Linux and Windows.
More on that latter point - I had known for some time that there were differences in Catalina's code generation between Windows and Linux, but both were correct and most people only use one platform or the other so it was never really an urgent problem. Also, it was quite hard to track down since it had to be deep in bowels of LCC. I finally discovered that it was caused by the fact that gcc has different sized long integers on Windows and Linux, even when both are 64 bit platforms. Long integers are 4 bytes on Windows but 8 bytes on Linux. And LCC was not taking into account that code might be generated on a platform with 8 byte longs, but targeted at a platform with 4 byte longs. The differences were in the way code was being optimized - i.e. the code would be correct with or without the optimization but in some cases LCC was failing to detect that further optimization was possible (e.g. by folding constants). In most cases the differences in code sizes only amounted to a few longs.
I finally decided to to buckle down and find it because it was making it difficult to have a fixed code address that worked on both platforms (fixed code addresses are required when building multi-model programs such as eLua) - the address would differ depending on whether the program was compiled on Linux or Windows, which was very annoying.
It’s a bit unfortunate that I don’t have the P2 Edge module with 32 MB external RAM. The current Berry P2 image is already about 497 KB, so on the standard P2 Edge I’m effectively working inside the P2’s internal 512 KB Hub RAM limit. After the image, runtime data, stacks, buffers, and reserved areas are accounted for, I only have around 131 KB left for the Berry heap.
That is enough for a useful embedded Berry environment, but it puts real pressure on features like multiple Berry VMs, worker cogs, dynamic Spin2 object loading, larger scripts, and bigger buffers. With the 32 MB RAM P2 Edge, the design would be much more comfortable: the interpreter could keep the core image in Hub RAM while using external RAM as a much larger heap or object/script storage area.
I made two more updates. Berry is more friendly to use because pressing up key returns the last line instead of giving garbage characters.
Work has been done to run pasm2 binaries on SD Card.
I also added a quick status function to see the state of the p2 and Berry VM
berry> import p2
berry> p2.status()
P2 status
Build May 08 2026 10:47:13
Runtime Catalina P2_EDGE no-PSRAM
Clock 180000000 Hz mode 0x010008F7 tick 696141776
Current cog 0
Memory
image [#######################.] 95% 498368 / 524288 B
main heap [###.....................] 11% 14812 / 131072 B
worker heap [........................] 0% 20 / 32768 B
current free 116260 B
code 253668 B
const 17924 B
init 10680 B
data 205908 B
bytes max 4096 B
stack 1024 slots
Cogs
cog 0 run raw 1 current
cog 1 run raw 1
cog 2 run raw 1
cog 3 run raw 1
cog 4 free raw 0
cog 5 free raw 0
cog 6 free raw 0
cog 7 free raw 0
Hi @FredBlais
Been away for a week. 497Kb sounds like a lot for a basic Berry image. Are there optional Berry modules that can be omitted in favor of more user code or heap space?
Will try compiling your latest version to execute from XMM RAM in the next few days. In Lua I also have an option that executes from Hub RAM but caches the compiled Lua code in PSRAM. I'd be fairly sure Berry could be made to do that as well.
I ordered the P2 Edge with 32MB PSRAM, so I will be able to cram as much stuff/features as possible into the Berry port 😄
I also want to add P2 USB and video support eventually.
I will try to keep the GC heap and main runtime stuff in Hub RAM, but move things like Berry bytecode, const data, modules, solidified objects, and maybe some larger static data into PSRAM/XMM. I also want to experiment with lazy-loading modules/bytecode from PSRAM instead of keeping everything resident in Hub RAM.
Catalina already has VGA and USB keyboard and mouse support. If you want other specific USB device support it may be possible to add it, but I seem to recall (from memory - someone please correct me if I have this wrong) that the P2 is not fast enough to do general-purpose USB.
One day I will add a P2 HDMI/DVI driver. I've just been lazy on that one because I have no need for it myself.
No, general USB is just too complex/bloated when at the end of the day all you really want is HID stuff. That's why the drivers are specialized like that. You could write a more general one, but then you'd also need to handle all the different device classes somewhere and the code would be huge and slow.
Just downloaded the new Berry binary, and of course it is not 497Kb of code - that's the whole image size, which includes pre-allocated space for stack, heap and user programs. The code size Berry reports is 247Kb, which is quite comparable with Lua (252Kb with the 'linenoise' command-line editing module enabled, 236Kb without). The Lua binaries are smaller because they do not include pre-allocated space for stack, heap or data - these are all allocated at run time.
You might want to make this clearer so that people don't think there is only a few kilobytes left for Berry programs.
Catalina 8.8.9 has been released on GitHub and SourceForge. Note that the github tag is v8.8.9.1 because I had already assigned v8.8.9 and then a major Cake update was released.
This is a full release. It updates Cake to 0.13.34, which completes C99, C11, C17 and C23 support, and enhances CXY support.
New Functionality
1. Cake has been updated to 0.13.34, which completes Cake support for C99,
C11, C17 and C23, and enhances support for CXY. For full details, refer
to the Cake documents in source/cake and source/cake/docs.
Other Changes
1. The document 'Getting Started with Catapult' has been updated to note that
the 'stack' size attribute also includes heap, if dynamic memory allocation
(i.e. malloc() etc) is used by the secondary program.
2. The Catalina Binder (bcc) now sorts files into alphabetical order before
processing - this eliminates any differences in the final output because
Windows and Linux use a different sort order when files are specified
using wildcards (e.g. bcc *.s).
3. The Linux version of Catalina was generating code that was different to
the Windows version - both were correct, but the Linux code was missing
some code optimizations, which meant code compiled on Linux could be
slightly different in size to code compiled on Windows. This made it
harder to build multi-model programs (e.g. using catapult) which depend
on having the address of the secondary program embedded in the code
of the primary program. Typically it meant the programs would have to be
edited to change the address when compiled on Linux. Now both Windows and
Linux generate the same code, which means multi-model programs should have
the same addresses on all platforms.
Affected Catalina on Linux only.
4. An older version of Lua (5.4.4) has been removed from the Catalina
libraries. Lua version 5.4.8 is now the only supported version in the
libraries, but a stand-alone version of 5.5.0 is also included.
5. Fixed some issues with using the BlackBox debugger on programs compiled
using Cake (via -C99 etc). BlackBox may have reported that it could not
find the source files because the #line information generated by Cake was
not understood by LCC, and this affected the debugging information (i.e. stabs)
output from LCC, which is used by BlackBox.
Affected the Propeller 1 and 2 on Windows and Linux
berry> p2.status()
P2 status
Build Jun 06 2026 14:39:05
Runtime Catalina P2_EDGE PSRAM
Clock 180000000 Hz mode 0x010008F7 tick 720698146
Current cog 0
Memory
image [#######################.] 96% 504960 / 524288 B
main heap [#####...................] 20% 26640 / 131072 B
worker heap [........................] 0% 16 / 16384 B
current free 104432 B
external 33554432 B PSRAM block API, Berry heap in Hub RAM
code 267564 B
const 21008 B
init 7460 B
data 195612 B
bytes max 4096 B
stack 1024 slots
@FredBlais said:
Progress : Berry see the first 16MB of PSRAM as heap space and garbage collection works also on PSRAM.
Excellent progress. Will give it a go soon.
Berry seems to be mostly used in home automation. It is (for example) the scripting language used by Tasmota. Is that where you see it being used on the Propeller 2?
Huge heap version
There is a lot of things to fix but it is a good start!
P2 status
Build Jun 06 2026 23:32:48
Clock 180000000 Hz mode 0x010008F7 tick 3840451941
Current cog 0
Memory
image [########################] 139% 726432 / 524288 B
main heap [#.......................] 3% 534792 / 15728640 B
worker heap [........................] 0% 20 / 16384 B
current free 15193848 B
external 33554432 B PSRAM block API, Berry heap in PSRAM
code 583584 B
const 23040 B
init 7644 B
data 46116 B
bytes max 4096 B
stack 1024 slots
Cogs
cog 1 run raw 1
cog 2 run raw 1
cog 3 run raw 1
cog 4 run raw 1
cog 5 free raw 0
cog 6 free raw 0
cog 7 free raw 0
Ross.
Berry is pretty much like Python, but does not require indentation.
You can see the difference here : https://berry.readthedocs.io/en/latest/source/en/Berry-in-20-minutes.html#extra
you can try it online too https://berry-lang.github.io/try-online/
First released binary sits here https://github.com/speccy88/berry/releases/
with relevant information on the release page
@FredBlais
Ross.
Hmm, trying to compile Berry on Windows, I get a gcc internal compiler error:
I'll try Linux.
Ok! Thanks. Your version works.
And my Windows version of gcc is now working again - just one of those mysteries of Windows 11, which occasionally does all kinds of odd things.
I got my quickly hacked version to compile ok, but not run yet. I'll have a look at what changes you made.
Ross.
@FredBlais
py -3topython3in the scripts, but when bash executes catalina, it cannot locate clcc, which indicate that either the LCCDIR environment variable or the path is not being set. In bash (and assuming Catalina is installed in /C/users/rossh/Catalina), you need to do:I also see references to macOS in your scripts. Do you use Catalina on a Mac?
Ross.
Actually, my build system spin up a Ubuntu image in Docker to use Catalina
DEFAULT_BASE_IMAGE="ubuntu:24.04"
DOCKER_IMAGE="${CATALINA_DOCKER_IMAGE:-berry-p2-catalina-builder:ubuntu24.04}"
To do this port, I used Codex from OpenAI. The tool is pretty smart, it will figure out a way on its own to make that work.
Not totally working yet be here is the base code : https://github.com/speccy88/berry/commit/cf1ee553957222fb2374ede0e92a880ba53cecf6
@FredBlais
Ah! That explains a few things.
@FredBlais
Catalina offers 2 communication mechanisms:
1. message channels
2. shared variables
3. Propeller locks
Ross.
New Functionality ----------------- 1. Cake updated (to 0.13.14). This version has support for C bit-fields. 2. Catalina has a new command line option '-Y' (i.e. minus capital Y) which tells Catalina to preprocess the C sources but not to compile them. The preprocessed output files will be written into a 'catalina' subfolder in the current directory. Since there may be more than one source file, any '-o' option is ignored, and the output files will have the same names as the input files. For example: catalina -Y hello.c bye.c will generate two output files - 'catalina/hello.c' and 'catalina/bye.c'. 3. Catalina now accepts debug options (i.e. -g or -g3) in conjunction with C standards other than -C89 or -C90, but issues a warning that the options may be incompatible. While Catalina's version of Cake now generates #line directives (which allow the Catalina debugger to display the line being debugged) debugger support is still very experimental. Cake changes the source so much that some debugger commands may not work as expected - e.g. Cake may remove, rename or add new variables, and also remove, modify, re-arrange or add new lines of source code. Another option is to first use Cake to translate C99 (or later) source files to C89, and then compile and debug THOSE files. To do this, add the new -Y command-line option to a catalina command, which tells Catalina to preprocess the source files but not compile them. It is important to add all the correct compile-time options (e.g. libraries and other options) so that the file will be pre-processed correctly. Any -o option will be ignored - instead, since there may be more than one source file, the preprocessed files will be written to a 'catalina' subfolder created in the current directory, with the same names as the original files. For example, if the command used to compile %LCCDIR%\demos\hello_99.c WITHOUT debugging is: catalina hello_99.c -p2 -C99 -lci -C P2_EDGE -C VGA Then to generate the C89 version, first add -Y to that command: catalina hello_99.c -p2 -C99 -lci -C P2_EDGE -C VGA -Y Then the file catalina\hello_99.c can be compiled for debugging, loaded and debugged as follows: catalina catalina\hello_99.c -p2 -lci -C P2_EDGE -C VGA -g3 payload -o2 catalina\hello_99 blackbox catalina\hello_99 Other Changes ------------- 1. Document 'Lua on the Propeller with Catalina' updated. 2. Document 'Catalina Optimizer Reference Manual' updated. 3. The notes in CATALINA.TXT in the demos/coremark directory have been updated to remove the references to 'force_rebuild' (which is not implemented in the coremark makefile!) and also add that faster single-threaded coremark results can be obtained by defining the Catalina symbols NO_INTERRUPTS and FAST_SAVE_RESTORE - this speeds up coremark by about 25% 4. Fixed a bug in the Catalina Optimizer, which means that Optimizing programs that contained inline PASM could cause the program to fail. The Optimizer now skips all code contained in inline PASM statements, because (a) such code does not necessarily use the same memory model as the code generated by LCC (which the Optimizer assumed was always the case), and (b) because optimizing code can change code size and timing, which could be critical in hand-coded PASM. Affected the Propeller 1 and 2, on Windows and Linux. 5. Fixed a bug in the Catalina Optimizer, which means that Optimizing COMPACT programs could cause the program to fail, because the Optimizer was not retaining some "alignl" statements that were REQUIRED for the code to execute correctly (e.g. after an I16B_CALI instruction). Affected the Propeller 1 and 2, on Windows and Linux. 6. Fixed a bug in the inline PASM demo inline_pasm/test_inline_pasm_5.c, which did not correct for pin numbers >= 32 (i.e. accessed via Port B). Affected the Propeller 2 only, on Windows. Linux and Catalyst. 7. Fixed a bug in the Blackbox source level debugger, which was sometimes assigning breakpoint addresses to the wrong source line. The debugger executed the breakpoints correctly, but may have displayed the wrong source line when the breakpoint address was reached.I've pushed v8.8.9 to GitHub, but I don't intend to turn it into an official release yet because I still have more testing to do and I won't get much chance in the next week or two. But it might be useful for those on the bleeding edge to have it available now (e..g. @FredBlais - the VLA support will make Berry easier to port and maintain).
Ross.
I just released version 0.9.3 working with your latest compiler version
https://github.com/speccy88/berry/releases/tag/v0.9.3
https://github.com/speccy88/berry/releases/tag/v0.9.5
berry> import p2
berry> p2.status()
P2 status
Current cog 0
Memory
code 253668 B
const 17924 B
init 10680 B
data 205908 B
bytes max 4096 B
stack 1024 slots
Cogs
cog 1 run raw 1
cog 2 run raw 1
cog 3 run raw 1
cog 4 free raw 0
cog 5 free raw 0
cog 6 free raw 0
cog 7 free raw 0
Hi @FredBlais
Ross.
@FredBlais
Ross.
Thanks for clarifying.
Ross.
@RossH I just received my P2-EC32MB! It was back order for 1 month on DigiKey…
Can’t wait to continue pushing Berry
Good stuff!
A lot of progress has been made!
Huge heap version
still more progress. Interactive session example :
Berry 1.1.0 (build Jun 08 2026 17:53:48) [Catalina] on Propeller 2 Edge (P2_EDGE, PSRAM) [xmm profile] [image 928448 B | code 739844 B | const 27268 B | init 13800 B | data 81468 B] [heap 15728640 B | stack 4096 slots | bytes max 4096 B] [external 33554432 B PSRAM | XMM 16777216 B | block 16777216 B @ 16777216 | Berry heap external] [Ctrl-D or Ctrl-C at an empty prompt quits] berry> import p2 berry> berry> def blinker(pin, ms) ...> return p2.cog.blinker(pin, ms) ...> end berry> berry> h38 = p2.cog.spawn(blinker, 38, 250) berry> h39 = p2.cog.spawn(blinker, 39, 700) berry> berry> p2.status() P2 status --------- Build Jun 08 2026 17:53:48 Runtime Catalina P2_EDGE PSRAM Clock 180000000 Hz mode 0x010008F7 tick 4291539021 Current cog 0 Memory image [#.......................] 6% 928448 / 16777216 B main heap [#.......................] 3% 544296 / 15728640 B worker heap [........................] 0% 20 / 16384 B current free 15184344 B external 33554432 B PSRAM block API, Berry heap in PSRAM code 739844 B const 27268 B init 13800 B data 81468 B bytes max 4096 B stack 4096 slots Cogs cog 0 run raw 1 main main Berry VM / REPL reg 0x0007be70 type 0 current cog 1 run raw 1 xmm_cache XMM cache service reg 0x1d07be78 type 29 cog 2 run raw 1 runtime Catalina runtime service type 1 reg 0x0107be80 type 1 cog 3 run raw 1 runtime Catalina runtime service type 22 reg 0x1607be88 type 22 cog 4 run raw 1 runtime Catalina runtime service type 6 reg 0x0607be90 type 6 cog 5 run raw 1 runtime Catalina runtime service type 28 reg 0x1c07be98 type 28 cog 6 run raw 1 user p2.cog blinker p38 250ms, handle 100 slot 0 cog 7 run raw 1 user p2.cog blinker p39 700ms, handle 101 slot 1 berry> p2.cog.stop(h38) {'cog': 6, 'kind': 'closure', 'last_result_bool': false, 'last_result_int': 0, 'native_pin': 38, 'setup_function': true, 'wait_ms': 0, 'function': 'blinker', 'repl_idle_only': false, 'stack_bytes': 2048, 'argc': 2, 'setup_descriptor_return': true, 'calls': 107, 'status': 2, 'used': true, 'error': '', 'isolated_source': false, 'handle': 100, 'last_result_type': 4, 'period_ms': 250, 'native_blink': true, 'task_kind': 'blinker', 'descriptor_task': false, 'raw_running': false, 'model': 'native_blink', 'call_result': 0, 'running': false, 'label': 'p2.cog blinker p38 250ms, handle 100', 'closure_name': 'blinker', 'slot': 0} berry> p2.cog.stop(h39) {'cog': 7, 'kind': 'closure', 'last_result_bool': false, 'last_result_int': 0, 'native_pin': 39, 'setup_function': true, 'wait_ms': 0, 'function': 'blinker', 'repl_idle_only': false, 'stack_bytes': 2048, 'argc': 2, 'setup_descriptor_return': true, 'calls': 47, 'status': 2, 'used': true, 'error': '', 'isolated_source': false, 'handle': 101, 'last_result_type': 4, 'period_ms': 700, 'native_blink': true, 'task_kind': 'blinker', 'descriptor_task': false, 'raw_running': false, 'model': 'native_blink', 'call_result': 0, 'running': false, 'label': 'p2.cog blinker p39 700ms, handle 101', 'closure_name': 'blinker', 'slot': 1} berry> p2.status() P2 status --------- Build Jun 08 2026 17:53:48 Runtime Catalina P2_EDGE PSRAM Clock 180000000 Hz mode 0x010008F7 tick 3655775709 Current cog 0 Memory image [#.......................] 6% 928448 / 16777216 B main heap [#.......................] 3% 544840 / 15728640 B worker heap [........................] 0% 20 / 16384 B current free 15183800 B external 33554432 B PSRAM block API, Berry heap in PSRAM code 739844 B const 27268 B init 13800 B data 81468 B bytes max 4096 B stack 4096 slots Cogs cog 0 run raw 1 main main Berry VM / REPL reg 0x0007be70 type 0 current cog 1 run raw 1 xmm_cache XMM cache service reg 0x1d07be78 type 29 cog 2 run raw 1 runtime Catalina runtime service type 1 reg 0x0107be80 type 1 cog 3 run raw 1 runtime Catalina runtime service type 22 reg 0x1607be88 type 22 cog 4 run raw 1 runtime Catalina runtime service type 6 reg 0x0607be90 type 6 cog 5 run raw 1 runtime Catalina runtime service type 28 reg 0x1c07be98 type 28 cog 6 free raw 0 free available reg 0xff07bea0 type 255 cog 7 free raw 0 free available reg 0xff07bea8 type 255 berry> import i2c berry> berry> i2c.init(25, 24, 400) berry> print(i2c.scan()) [119] berry> print(1 + 2) 3 berry> a = 6 berry> print(a * 7) 42 berry> for i:0..3 ...> print(i) ...> end 0 1 2 3 berry> import math berry> import json berry> print(math.sqrt(81)) 9 berry> print(json.dump({"a": 1, "b": [2, 3]})) {"a":1,"b":[2,3]} berry> b = bytes().fromstring("AB") berry> print(b.tohex()) 4142 berry> import os berry> print(os.listdir("/")) ['MODULES', 'TESTS'] berry> f = open("/TEST.TXT", "w") berry> f.write("hello from berry") berry> f.close() berry> print(open("/TEST.TXT", "r").read()) hello from berry berry> print(p2.clock_freq()) 180000000 berry> print(p2.ticks()) 633571581 berry> print(p2.psram_info()) {'block_base': 16777216, 'max_transfer': 8192, 'reserved_pin_last': 57, 'cache_base': 16777216, 'reserved_pin_first': 40, 'cache_bytes': 16777216, 'available': true, 'pointer_heap_limit': 16777216, 'xmm_bytes': 16777216, 'heap': true, 'bytes': 33554432, 'pointer_window_bytes': 16777216, 'block_bytes': 16777216, 'access': 'xmm+block'} berry> real(3)/2 1.5 berry> int(3.0/2) 1 berry> math.sqrt(2) 1.41421 berry> math.pow(2,3) 8 berry> def hi() print("Hello, Berry") end berry> berry> hi() Hello, Berry berry> hi <function: 0x15abe8> berry> def fib(n) ...> if n <= 1 return n end ...> return fib(n-1) + fib(n-2) ...> end berry> fib(10) 55 berry> m = {"k1":"v1", "k2":"v2", "k3":"v3"} berry> for k: m.keys() print(k, m[k]) end k2 v2 k1 v1 k3 v3 berry> p2.status() P2 status --------- Build Jun 08 2026 17:53:48 Runtime Catalina P2_EDGE PSRAM Clock 180000000 Hz mode 0x010008F7 tick 4186106277 Current cog 0 Memory image [#.......................] 6% 928448 / 16777216 B main heap [#.......................] 4% 570152 / 15728640 B worker heap [........................] 0% 20 / 16384 B current free 15158488 B external 33554432 B PSRAM block API, Berry heap in PSRAM code 739844 B const 27268 B init 13800 B data 81468 B bytes max 4096 B stack 4096 slots Cogs cog 0 run raw 1 main main Berry VM / REPL reg 0x0007be70 type 0 current cog 1 run raw 1 xmm_cache XMM cache service reg 0x1d07be78 type 29 cog 2 run raw 1 runtime Catalina runtime service type 1 reg 0x0107be80 type 1 cog 3 run raw 1 runtime Catalina runtime service type 22 reg 0x1607be88 type 22 cog 4 run raw 1 runtime Catalina runtime service type 6 reg 0x0607be90 type 6 cog 5 run raw 1 runtime Catalina runtime service type 28 reg 0x1c07be98 type 28 cog 6 free raw 0 free available reg 0xff07bea0 type 255 cog 7 free raw 0 free available reg 0xff07bea8 type 255Neat. Looks like you found and the SD card problem. I have not had time to look yet - what was it?
Ross.
The latest release is here : https://github.com/speccy88/berry/releases/tag/v0.9.6
that would be fun if someone else from the forum could chime in and give me some feedback
Can you tell me if you are able to make it to work? I also improved the README in the repo for a nicer tutorial
For the SD, it is just because I was not able to get it to work with FAT volume starting at 2048
