Catalina - C and Lua for the Propeller 1 & 2 - Page 25 — Parallax Forums
1192021222325»
  • RossHRossH Posts: 5,752
    @FredBlais said:
    @RossH
    I've got a working port of the Berry Language working on the Propeller 2 compiled using Catalina. See https://berry-lang.github.io
    Great! I don't know Berry, but I'll look it up tomorrow.
    Ross.
  • Berry is pretty much like Python, but does not require indentation.
    You can see the difference here : https://berry.readthedocs.io/en/latest/source/en/Berry-in-20-minutes.html#extra
    you can try it online too https://berry-lang.github.io/try-online/
  • FredBlaisFredBlais Posts: 389
    edited 2026-04-23 17:47
    First released binary sits here https://github.com/speccy88/berry/releases/
    with relevant information on the release page
    @FredBlais
    Berry looks interesting. I immediately saw that it's very "Lua like". And when I read further, I found this was exactly the intent. The author of Berry says:
    I used to pay more attention to Lua because it is a very compact embedded scripting language, and its design goal is to be embedded in the host program. However, for the microcontroller, the Lua interpreter may not be small enough, and I cannot run it on a 32-bit microcontroller with a relatively small memory. To this end, I started to read Lua code and developed my own scripting language-Berry on this basis.
    On the Propeller 2, the overhead of full embedded Lua is about 180kb of code. The author of Berry says the minimum memory required to run "full" Berry is about 128kb of EEPROM (which I interpret to mean about 128kb of code) so it looks quite promising. I'll have a play and see what its performance is like compared to Lua.
    Berry may not replace Lua as my preferred Propeller language :) but thanks for bringing it to my attention. The more languages we get working on the Propeller, the better!
    Ross.
    Hmm, trying to compile Berry on Windows, I get a gcc internal compiler error:
    Mingw-w64 runtime failure:
      VirtualProtect failed with code 0x5afgcc.exe: internal compiler error: Aborted signal terminated program cc1
    I'll try Linux.
    Ok! Thanks. Your version works.
    And my Windows version of gcc is now working again - just one of those mysteries of Windows 11, which occasionally does all kinds of odd things.
    I got my quickly hacked version to compile ok, but not run yet. I'll have a look at what changes you made.
    Ross.
    @FredBlais
    I managed to get your port of Berry to build on Linux easily enough, but I have to load it manually. Here is the payload command I use (assumes the Propeller is on port /dev/ttyUSB0):
    payload -o2 -i -q1 -p/dev/ttyUSB0 build/p2/catalina/berry_p2.bin
    No luck with Windows - I had to modify py -3 to python3 in the scripts, but when bash executes catalina, it cannot locate clcc, which indicate that either the LCCDIR environment variable or the path is not being set. In bash (and assuming Catalina is installed in /C/users/rossh/Catalina), you need to do:
    export LCCDIR=/C/users/rossh/Catalina
    source $LCCDIR/use_catalina
    I also see references to macOS in your scripts. Do you use Catalina on a Mac?
    Ross.
    edited 2026-04-24 10:49
    @RossH said:
    @FredBlais
    Ross.
    Actually, my build system spin up a Ubuntu image in Docker to use Catalina
    DEFAULT_BASE_IMAGE="ubuntu:24.04"
    DOCKER_IMAGE="${CATALINA_DOCKER_IMAGE:-berry-p2-catalina-builder:ubuntu24.04}"
    To do this port, I used Codex from OpenAI. The tool is pretty smart, it will figure out a way on its own to make that work.
    Yesterday I started to work on a way to make Berry lunch a new berry instance on another cog to execute the closure I give it.
    Not totally working yet be here is the base code : https://github.com/speccy88/berry/commit/cf1ee553957222fb2374ede0e92a880ba53cecf6
    @FredBlais
    Ah! That explains a few things.
    @FredBlais
    This looks to be similar to Catalina's multi-processing Lua extensions. What mechanism do you intend to use to synchronize and communicate between instances? I see references to mailboxes in your code - that is a reasonable choice for a communication mechanism but it looks like you use them only for passing arguments to the function - is there a facility to return data as well?
    Catalina offers 2 communication mechanisms:
    1. message channels
    2. shared variables
    And 3 synchronization mechanisms:
    1. condition variables (as per Posix)
    2. mutexes (as per Posix)
    3. Propeller locks
    Plus, if the instances are executing on same Propeller (they may not be) then you can also just use shared memory (Catalina's eLua client/server programs use this mechanism).
    This is probably overkill - one of each type of mechanism is probably sufficient, but these choices are partly historical (i.e. inherited from the original luaproc package). See the documents Lua on the Propeller 2 with Catalina and Aloha from Lua for more details.
    Ross.
    edited 2026-04-25 08:16
    Catalina 8.8.8 has been released on GitHub and SourceForge. If you believe in Chinese numerology, this should be a very, very, very lucky release!
    This is a full release. It updates Cake to 0.13.14, which adds support for C bit-fields, and also contains minor enhancements, bug fixes and documentation updates.
    Here is the relevant extract from the README.TXT:
    New Functionality
    1. Cake updated (to 0.13.14). This version has support for C bit-fields.
    2. Catalina has a new command line option '-Y' (i.e. minus capital Y)
       which tells Catalina to preprocess the C sources but not to compile them.
       The preprocessed output files will be written into a 'catalina' subfolder
       in the current directory. Since there may be more than one source file,
       any '-o' option is ignored, and the output files will have the same names
       as the input files. For example:
         catalina -Y hello.c bye.c
       will generate two output files - 'catalina/hello.c' and 'catalina/bye.c'.
    3. Catalina now accepts debug options (i.e. -g or -g3) in conjunction
       with C standards other than -C89 or -C90, but issues a warning that
       the options may be incompatible. While Catalina's version of Cake now
       generates #line directives (which allow the Catalina debugger to display
       the line being debugged) debugger support is still very experimental.
       Cake changes the source so much that some debugger commands may not
       work as expected - e.g. Cake may remove, rename or add new variables,
       and also remove, modify, re-arrange or add new lines of source code.
       Another option is to first use Cake to translate C99 (or later) source
       files to C89, and then compile and debug THOSE files. To do this, add the
       new -Y command-line option to a catalina command, which tells Catalina to
       preprocess the source files but not compile them. It is important to add
       all the correct compile-time options (e.g. libraries and other options)
       so that the file will be pre-processed correctly. Any -o option will be
       ignored - instead, since there may be more than one source file, the
       preprocessed files will be written to a 'catalina' subfolder created in
       the current directory, with the same names as the original files.
       For example, if the command used to compile %LCCDIR%\demos\hello_99.c
       WITHOUT debugging is:
          catalina hello_99.c -p2 -C99 -lci -C P2_EDGE -C VGA
       Then to generate the C89 version, first add -Y to that command:
          catalina hello_99.c -p2 -C99 -lci -C P2_EDGE -C VGA -Y
        Then the file catalina\hello_99.c can be compiled for debugging,
        loaded and debugged as follows:
          catalina catalina\hello_99.c -p2 -lci -C P2_EDGE -C VGA -g3
          payload -o2 catalina\hello_99
          blackbox catalina\hello_99
    Other Changes
    1. Document 'Lua on the Propeller with Catalina' updated.
    2. Document 'Catalina Optimizer Reference Manual' updated.
    3. The notes in CATALINA.TXT in the demos/coremark directory have been
       updated to remove the references to 'force_rebuild' (which is not
       implemented in the coremark makefile!) and also add that faster
       single-threaded coremark results can be obtained by defining the
       Catalina symbols NO_INTERRUPTS and FAST_SAVE_RESTORE - this speeds
       up coremark by about 25%
    4. Fixed a bug in the Catalina Optimizer, which means that Optimizing
       programs that contained inline PASM could cause the program to fail.
       The Optimizer now skips all code contained in inline PASM statements,
       because (a) such code does not necessarily use the same memory model as
       the code generated by LCC (which the Optimizer assumed was always the
       case), and (b) because optimizing code can change code size and timing,
       which could be critical in hand-coded PASM.
       Affected the Propeller 1 and 2, on Windows and Linux.
    5. Fixed a bug in the Catalina Optimizer, which means that Optimizing
       COMPACT programs could cause the program to fail, because the Optimizer
       was not retaining some "alignl" statements that were REQUIRED for the
       code to execute correctly (e.g. after an I16B_CALI instruction).
    6. Fixed a bug in the inline PASM demo inline_pasm/test_inline_pasm_5.c,
       which did not correct for pin numbers >= 32 (i.e. accessed via Port B).
       Affected the Propeller 2 only, on Windows. Linux and Catalyst.
    7. Fixed a bug in the Blackbox source level debugger, which was sometimes
       assigning breakpoint addresses to the wrong source line. The debugger
       executed the breakpoints correctly, but may have displayed the wrong
       source line when the breakpoint address was reached.
    edited 2026-05-03 01:42
    I've pushed v8.8.9 to GitHub, but I don't intend to turn it into an official release yet because I still have more testing to do and I won't get much chance in the next week or two. But it might be useful for those on the bleeding edge to have it available now (e..g. @FredBlais - the VLA support will make Berry easier to port and maintain).
    The significant changes are:
    1. Cake now supports C99 Variable Length Arrays. This means Catalina's C99 language support (via Cake) is essentially complete.
    2. Catalina now generates identical code on Linux and Windows.
    More on that latter point - I had known for some time that there were differences in Catalina's code generation between Windows and Linux, but both were correct and most people only use one platform or the other so it was never really an urgent problem. Also, it was quite hard to track down since it had to be deep in bowels of LCC. I finally discovered that it was caused by the fact that gcc has different sized long integers on Windows and Linux, even when both are 64 bit platforms. Long integers are 4 bytes on Windows but 8 bytes on Linux. And LCC was not taking into account that code might be generated on a platform with 8 byte longs, but targeted at a platform with 4 byte longs. The differences were in the way code was being optimized - i.e. the code would be correct with or without the optimization but in some cases LCC was failing to detect that further optimization was possible (e.g. by folding constants). In most cases the differences in code sizes only amounted to a few longs.
    I finally decided to to buckle down and find it because it was making it difficult to have a fixed code address that worked on both platforms (fixed code addresses are required when building multi-model programs such as eLua) - the address would differ depending on whether the program was compiled on Linux or Windows, which was very annoying.
    Ross.
    edited 2026-05-08 00:26
    I just released version 0.9.3 working with your latest compiler version
    https://github.com/speccy88/berry/releases/tag/v0.9.3
    It’s a bit unfortunate that I don’t have the P2 Edge module with 32 MB external RAM. The current Berry P2 image is already about 497 KB, so on the standard P2 Edge I’m effectively working inside the P2’s internal 512 KB Hub RAM limit. After the image, runtime data, stacks, buffers, and reserved areas are accounted for, I only have around 131 KB left for the Berry heap.
    That is enough for a useful embedded Berry environment, but it puts real pressure on features like multiple Berry VMs, worker cogs, dynamic Spin2 object loading, larger scripts, and bigger buffers. With the 32 MB RAM P2 Edge, the design would be much more comfortable: the interpreter could keep the core image in Hub RAM while using external RAM as a much larger heap or object/script storage area.
  • I made two more updates. Berry is more friendly to use because pressing up key returns the last line instead of giving garbage characters.
    Work has been done to run pasm2 binaries on SD Card.
    https://github.com/speccy88/berry/releases/tag/v0.9.5
    I also added a quick status function to see the state of the p2 and Berry VM
    berry> import p2
    berry> p2.status()
    P2 status
    Build May 08 2026 10:47:13
    Runtime Catalina P2_EDGE no-PSRAM
    Clock 180000000 Hz mode 0x010008F7 tick 696141776
    Current cog 0
    Memory
    image [#######################.] 95% 498368 / 524288 B
    main heap [###.....................] 11% 14812 / 131072 B
    worker heap [........................] 0% 20 / 32768 B
    current free 116260 B
    code 253668 B
    const 17924 B
    init 10680 B
    data 205908 B
    bytes max 4096 B
    stack 1024 slots
    Cogs
    cog 0 run raw 1 current
    cog 1 run raw 1
    cog 2 run raw 1
    cog 3 run raw 1
    cog 4 free raw 0
    cog 5 free raw 0
    cog 6 free raw 0
    cog 7 free raw 0
    edited 2026-05-10 06:29
    Hi @FredBlais
    Been away for a week. 497Kb sounds like a lot for a basic Berry image. Are there optional Berry modules that can be omitted in favor of more user code or heap space?
    Will try compiling your latest version to execute from XMM RAM in the next few days. In Lua I also have an option that executes from Hub RAM but caches the compiled Lua code in PSRAM. I'd be fairly sure Berry could be made to do that as well.
    Ross.
    edited 2026-05-10 08:17
    I ordered the P2 Edge with 32MB PSRAM, so I will be able to cram as much stuff/features as possible into the Berry port 😄
    I also want to add P2 USB and video support eventually.
    I will try to keep the GC heap and main runtime stuff in Hub RAM, but move things like Berry bytecode, const data, modules, solidified objects, and maybe some larger static data into PSRAM/XMM. I also want to experiment with lazy-loading modules/bytecode from PSRAM instead of keeping everything resident in Hub RAM.
    @FredBlais
    Catalina already has VGA and USB keyboard and mouse support. If you want other specific USB device support it may be possible to add it, but I seem to recall (from memory - someone please correct me if I have this wrong) that the P2 is not fast enough to do general-purpose USB.
    One day I will add a P2 HDMI/DVI driver. I've just been lazy on that one because I have no need for it myself.
    Ross.
    No, general USB is just too complex/bloated when at the end of the day all you really want is HID stuff. That's why the drivers are specialized like that. You could write a more general one, but then you'd also need to handle all the different device classes somewhere and the code would be huge and slow.
