I'm looking for any version of the 1CogKbM driver that works with any version of a Spin2 compiler. Can anyone point me to a combination of driver and compiler that works together? I've tried every combination I can find, and by messing around with the code I can usually make it compile, and (usually) get the start-up banner to appear -so I know it is compiling, loading and executing. But none of my attempts seem to get any further. And Spin2 does my head in
I'm using a P2 Eval board, which I know used to work with this driver, but I can't seem to find the right combination of driver version and Spin2 compiler any more.
USBNew is good. I mainly use it for game controllers.
For keyboards and mice, still using a modification of the old version...
There are variations on this that let you not use the enable pin and not use the LED pin...
CON 'USB mouse pin settings --> Set USB keyboard basepin here!
USB_BASE_PIN =24'16'24'16'24'16 'led for USB activity
USB_ENABLE_PIN =USB_BASE_PIN+1 'Parallax adapter uses this to control USB power (can be -1 to disable)
USB_DM_PIN =USB_BASE_PIN+2 'upper port on Parallax 2 port adapter
USB_ERR_LED_PIN =USB_BASE_PIN+0 'Need to update USB driver so this can be ignored...
var 'USB kbm vars
long mx,my,MaxX,MaxY,buttons,scan1,scan2 'leave these together in this order
'Start keyboard
'Start up USB
kbm.Start(USB_BASE_PIN, USB_ENABLE_PIN, USB_DM_PIN, USB_ERR_LED_PIN, @mx)
'Wait for keypress
repeat until scan1
If it compiles and load but doesn't work maybe is some settings, like pin numbers, clock settings, etc. ?
The original 1CogKbM driver doesn't support hubs.
Anyway, the usb driver I have on my Github repository https://github.com/maccasoft/P2/blob/master/usb.spin2 is PASM-only so it is compiler-independent, it doesn't have a Spin interface, you need to compile and run with debug to see activity from connected devices.
Other versions, like Ada's usbnew have a lot of preprocessor statements that are not compatible with either PNut or Spin Tools.
Aha! Bingo! Thanks very much!
I already have an older version of this driver included as part of Catalina - but I discovered a few days ago that while my version works ok with hardwired keyboards, it no longer works with any of the the hardwired mice I have on hand.
Your program confirmed that it is my mice that are the problem. The driver seems to support only a limited range of hardwired mice, and I had apparently replaced all my hardwired mice (which used to work) with ones that the 1CogKbM driver does not support - but I did not realize this until a few days ago.
Both your driver and mine still work with my wireless mouse and keyboard, so at least I now know the problem is with the driver, and is not something I broke in my version (which was what I had feared!).
Not sure how to fix the driver so it supports a wider variety of hardwired mice yet - but your "standalone" driver is sure to be a great help!
Take a look at usbnew linked above and follow the MOUSE_FULL_PROTOCOL defines, could be that you mice doesn't support the BOOT protocol.
I think I found the problem, but I'm not sure if my fix is correct.
The usb.spin2 code works with a wireless combo keyboard/mouse, and also with just a hardwired keyboard, but not with just a hardwired mouse.
To make it work with all of these I commented out lines 1826 - 1834 - e.g. replace them with:
cmp hkbd_ep_addr, #0 wz ' A SetIdle() duration of indefinite covers both keyboard and mouse
if_nz jmp #.skip ' So skip if it has already been done
mov hpar1, #0 ' SetIdle() duration 0 = indefinite
getbyte hpar2, kb_intf_num, #0
call #hset_idle
cmp retval, #PID_ACK wz
if_nz mov hmouse_ep_addr, #0
if_nz jmp #.notify_client
.skip
The code appears to be assuming that it can set the keyboard idle even when there is no actual keyboard - just a mouse. If I let it do this, I get a PID_STALL response and the mouse stays unrecognized.
However I think there is an error because it uses kb_intf_num while it should use ms_intf_num.
I'm not sure if this has some effects on combo keyboard+mouse.
Maybe try to replace getbyte hpar2, kb_intf_num, #0 with getbyte hpar2, ms_intf_num, #0 and see if it works with a mouse only, a keyboard and mouse (not combo) and a combo keyboard+mouse.
If doesn't work just comment the return code check, I don't think this is so important to invalidate the device found.
Neither of those work with my hardwired mouse. It seems to be the call the hset_idle that is the problem, with either ms_intf_numorkb_intf_num.
I did a couple of quick tests and seems there are some weird issues depending on the mouse. I have an old Kraun mouse that works without problems, and a RaspberryPi mouse that causes the code to loop forever reinitializing the device, commenting the call to hset_idle it works well. Seems to have the same issue with usbnew.
I guess commenting the whole idle code set for the mouse is good for now, until someone finds a better fix.
Any assistance would be appreciated.
Ross.
Try this - https://forums.parallax.com/discussion/comment/1566322/#Comment_1566322
'Start keyboard 'Start up USB kbm.Start(USB_BASE_PIN, USB_ENABLE_PIN, USB_DM_PIN, USB_ERR_LED_PIN, @mx) 'Wait for keypress repeat until scan1If it compiles and load but doesn't work maybe is some settings, like pin numbers, clock settings, etc. ?
Hope this helps.
Ross.
@macca
{ cmp hkbd_ep_addr, #0 wz ' A SetIdle() duration of indefinite covers both keyboard and mouse if_nz jmp #.skip ' So skip if it has already been done mov hpar1, #0 ' SetIdle() duration 0 = indefinite getbyte hpar2, kb_intf_num, #0 call #hset_idle cmp retval, #PID_ACK wz if_nz mov hmouse_ep_addr, #0 if_nz jmp #.notify_client .skip }The code appears to be assuming that it can set the keyboard idle even when there is no actual keyboard - just a mouse. If I let it do this, I get a PID_STALL response and the mouse stays unrecognized.
Is there a better solution?
Ross.
Usbnew simply ignores the return from hset_idle:
getbyte hpar2, kb_intf_num, #0 call #hset_idle 'cmp retval, #PID_ACK wz 'if_nz mov hkbd_ep_addr, #0 'if_nz jmp #.notify_client mov hctwait, _2ms_ call #poll_waitxHowever I think there is an error because it uses kb_intf_num while it should use ms_intf_num.
getbyte hpar2, kb_intf_num, #0withgetbyte hpar2, ms_intf_num, #0and see if it works with a mouse only, a keyboard and mouse (not combo) and a combo keyboard+mouse.If doesn't work just comment the return code check, I don't think this is so important to invalidate the device found.
Neither of those work with my hardwired mouse. It seems to be the call the hset_idle that is the problem, with either ms_intf_num or kb_intf_num.
Ross.
Yes, that's what I'll do. Thanks.
