P2 Hosted USB Keyboard/Mouse - Page 8 — Parallax Forums
1234568»
  • RossHRossH Posts: 5,780
    edited 2026-05-30 08:16
    I'm looking for any version of the 1CogKbM driver that works with any version of a Spin2 compiler. Can anyone point me to a combination of driver and compiler that works together? I've tried every combination I can find, and by messing around with the code I can usually make it compile, and (usually) get the start-up banner to appear -so I know it is compiling, loading and executing. But none of my attempts seem to get any further. And Spin2 does my head in :(
    I'm using a P2 Eval board, which I know used to work with this driver, but I can't seem to find the right combination of driver version and Spin2 compiler any more.
    Any assistance would be appreciated.
    Ross.
  • RaymanRayman Posts: 16,461
    edited 2026-05-30 10:41
    USBNew is good. I mainly use it for game controllers.
    For keyboards and mice, still using a modification of the old version...
    There are variations on this that let you not use the enable pin and not use the LED pin...
    CON 'USB mouse pin settings --> Set USB keyboard basepin here!
      USB_BASE_PIN    =24'16'24'16'24'16              'led for USB activity
      USB_ENABLE_PIN  =USB_BASE_PIN+1  'Parallax adapter uses this to control USB power  (can be -1 to disable)
      USB_DM_PIN      =USB_BASE_PIN+2  'upper port on Parallax 2 port adapter
      USB_ERR_LED_PIN =USB_BASE_PIN+0 'Need to update USB driver so this can be ignored...
    var 'USB kbm vars
      long mx,my,MaxX,MaxY,buttons,scan1,scan2  'leave these together in this order
        'Start keyboard
        'Start up USB
        kbm.Start(USB_BASE_PIN, USB_ENABLE_PIN, USB_DM_PIN, USB_ERR_LED_PIN, @mx)
        'Wait for keypress
        repeat until scan1
  • maccamacca Posts: 1,079
    If it compiles and load but doesn't work maybe is some settings, like pin numbers, clock settings, etc. ?
    The original 1CogKbM driver doesn't support hubs.
    Anyway, the usb driver I have on my Github repository https://github.com/maccasoft/P2/blob/master/usb.spin2 is PASM-only so it is compiler-independent, it doesn't have a Spin interface, you need to compile and run with debug to see activity from connected devices.
    Other versions, like Ada's usbnew have a lot of preprocessor statements that are not compatible with either PNut or Spin Tools.
    Hope this helps.
    Aha! Bingo! Thanks very much!
    I already have an older version of this driver included as part of Catalina - but I discovered a few days ago that while my version works ok with hardwired keyboards, it no longer works with any of the the hardwired mice I have on hand.
    Your program confirmed that it is my mice that are the problem. The driver seems to support only a limited range of hardwired mice, and I had apparently replaced all my hardwired mice (which used to work) with ones that the 1CogKbM driver does not support - but I did not realize this until a few days ago.
    Both your driver and mine still work with my wireless mouse and keyboard, so at least I now know the problem is with the driver, and is not something I broke in my version (which was what I had feared!).
    Not sure how to fix the driver so it supports a wider variety of hardwired mice yet - but your "standalone" driver is sure to be a great help!
    Ross.
    Take a look at usbnew linked above and follow the MOUSE_FULL_PROTOCOL defines, could be that you mice doesn't support the BOOT protocol.
    edited 2026-05-31 08:36
    @macca
    I think I found the problem, but I'm not sure if my fix is correct.
    The usb.spin2 code works with a wireless combo keyboard/mouse, and also with just a hardwired keyboard, but not with just a hardwired mouse.
    To make it work with all of these I commented out lines 1826 - 1834 - e.g. replace them with:
                    cmp     hkbd_ep_addr, #0        wz      ' A SetIdle() duration of indefinite covers both keyboard and mouse
            if_nz   jmp     #.skip                          ' So skip if it has already been done
                    mov     hpar1, #0                       ' SetIdle() duration 0 = indefinite
                    getbyte hpar2, kb_intf_num, #0
                    call    #hset_idle
                    cmp     retval, #PID_ACK        wz
            if_nz   mov     hmouse_ep_addr, #0
            if_nz   jmp     #.notify_client
    .skip
    The code appears to be assuming that it can set the keyboard idle even when there is no actual keyboard - just a mouse. If I let it do this, I get a PID_STALL response and the mouse stays unrecognized.
    Is there a better solution?
    Ross.
    @RossH said:
    @macca
    Usbnew simply ignores the return from hset_idle:
                            call      #hset_idle
                            'cmp     retval, #PID_ACK        wz
                            'if_nz   mov     hkbd_ep_addr, #0
                            'if_nz   jmp     #.notify_client
                            mov       hctwait, _2ms_
                            call      #poll_waitx
    However I think there is an error because it uses kb_intf_num while it should use ms_intf_num.
    I'm not sure if this has some effects on combo keyboard+mouse.
    Maybe try to replace getbyte hpar2, kb_intf_num, #0 with getbyte hpar2, ms_intf_num, #0 and see if it works with a mouse only, a keyboard and mouse (not combo) and a combo keyboard+mouse.
    If doesn't work just comment the return code check, I don't think this is so important to invalidate the device found.
    edited 2026-06-01 02:47
    Neither of those work with my hardwired mouse. It seems to be the call the hset_idle that is the problem, with either ms_intf_num or kb_intf_num.
    Ross.
    edited 2026-06-01 07:19
    I did a couple of quick tests and seems there are some weird issues depending on the mouse. I have an old Kraun mouse that works without problems, and a RaspberryPi mouse that causes the code to loop forever reinitializing the device, commenting the call to hset_idle it works well. Seems to have the same issue with usbnew.
    I guess commenting the whole idle code set for the mouse is good for now, until someone finds a better fix.
    Yes, that's what I'll do. Thanks.
