WX Bricked — Parallax Forums
WX Bricked
So it seems as if I've bricked my WX module. I've tried resetting by quickly (and slowly) pulling PGM pin low. Tried a few other things with no success. So I resigned myself to uploading new firmware via serial but I'm stuck at building esp-open-sdk. I've tried for the last 2 days to get the build to complete but it always seems to be something. Short of loading an old version of Debian onto one of the development systems I have laying around (much easier said than done) I was wondering if the community has any suggestions?
When the WX boots, i get a bunch of garbage in the terminal (propeller serial) then it repeatedly tries to boot second stage loader (I think)
[code]
ets Jan 8 2013,rst cause:4, boot mode:(3,2)
wdt reset
load 0x40100000, len 2592, room 16
tail 0
chksum 0xf3
load 0x3ffe8000, len 764, room 8
tail 4
chksum 0x92
load 0x3ffe82fc, len 676, room 4
tail 0
chksum 0x22
csum 0x22
2nd boot version : 1.7(5d6f877)
SPI Speed : 80MHz
SPI Mode : QIO
SPI Flash Size & Map: 16Mbit(512KB+512KB)
jump to run user1 @ 1000
▒▒▒▒8▒n▒▒r▒▒▒n▒b
▒l`▒Ē▒▒▒▒b▒r▒n▒c▒8▒▒
r▒▒▒▒▒8▒▒▒
r▒▒ܷ))RR▒
[/code]
Please tell me there's an easier solution (or someone has the separate binaries laying around somewhere) since i can't seem to get the SDK built on debian 12. Any help greatly appreciated!
  • iseriesiseries Posts: 1,547
    There is pre-built code out there that just requires loading.
    Did you check the github page?
    Parallax-ESP
    It's been a while since I loaded code on that module. Have moved on to the ESP32.
  • From my understanding, the github only has sources, not Pre-Compiled binaries that I can just flash. The only binary that I'm aware of is the over-the-air update which I don't think can be flashed from a serial interface. I could be wrong and please someone let me know if I am.
  • @VonSzarvas said:
    Does the attached help ?
    That's exactly what I was looking for, unfortunately after flashing the serial firmware (successfully) I'm still not able to see the wx wifi AP. I tried several methods of flashing, including using the included .bat as well as the online esp tool. I'm at a loss for why nothing is working.
    The ASC led is constant off and I'm not seeing the boot messages I was previously, just garbage output. I've tried several baud rates and it's all garbage. I do get something from the first stage boot when PGM pulled low from boot. Toggling PGM low 4x does nothing. I'm begging to think this WX module is a lost cause.
    I've ordered a new WX sip module but it would be really nice to recover this one as a backup. Thanks again for all the help, you guys are awesome 👍
  • RaymanRayman Posts: 16,428
    Some of these kind of modules use a lot of power… have seen recent cases where serial garbage was result of not enough power..
  • Boot Loader baud rate for an ESP01 is 74880. Not in the list of baud rates.
