Controlling Gravity (Gesture Recognition Module)
Testing out this DFRobot gesture recognition module...
https://www.dfrobot.com/product-2914.html
Compared to the gravity voice recognition module, this one appears simpler.
But, same warnings about interface apply (Beware 5V!)
https://forums.parallax.com/discussion/178105
This one uses a lot less power, only ~100mA at 3.3V as recall.
Think this one will be useful pointed backwards from robot, so can control with hand gestures.
Or, maybe just have robot stop of person not detected...
Shows up as expected on I2C scanner.
The github archive for this one looks similar to voice, so hopefully can get it going soon.
https://github.com/DFRobot/DFRobot_GestureFaceDetection/tree/master
But, just like voice, can interact without MCU. It's fun. Just can't control anything without MCU connected...
This one is also giving me trouble with I2C interface....
Just figured out that a delay is needed in the read I2C function to get good data...
Ignoring the CRC from the device on read here, but think need to add that, just to be 100%
This code reads the PID from the device and displays it... Should be $272
There is also an issue with I2C not working sometimes when code is restarted...
Power cycle fixes it, but hope there's another way...
Doesn't make any sense but seems that if serial terminal (PST) is disable for a minute or so, then the I2C interface fails.
That is really weird.. Have to think how this can be...
Remember now that closing terminal can reset mcu…
Have similar code in eeprom that fooled me into thinking was not reset…
The I2C interface on this thing seems even more flaky than the voice module...
Needs a lot of delays to keep the I2C bus from hanging...
Maybe too much delay now, but it works for a long time now.
Think one problem was adding additional 10k pullups. Seems it already has 10 pullups and the extra maybe did not make it happy...
Anyway, this code seems to work, but still needs testing...
Spent too much time trying to stabilize I2C interface to be useable over a several minute time span with no luck...
Switched to UART interface with Modbus RTU master and seems to work just perfectly this way, so going to switch this and voice module over.
Fortunately, there is a Modbus RTU master repo in OBEX that fit the bill almost perfectly (OBEX 2549).
This wonderfully includes a 4 port serial driver, which is just great. Can add 2 more sensors and keep the debug port too...
This RTU master only handles a few operations, but it's just enough for this.
There was an issue with the CRC reception code that had to be hacked.
Don't really know what is going on there, but was easy to make work...
There is a physical slide switch on the module that one needs to switch from I2C to UART to make it work.
