P2 Smart Pin Pulse Mode Silicon Bug Report — Parallax Forums
Christof Eb.Christof Eb. Posts: 1,567
edited 2026-04-27 12:46 in Propeller 2
Goal: Output a group of 16 pulses to drive a step driver module with the Smart Pin Pulse Mode and then output the next group. With only a very small gap due to the time needed for new setup.
Problem: Although the smartpin mode is completely stopped after every group (see code) the pulse stream is not realigned to the setting intervals. (Which are timed with waitct1)
To show the bug in this case setting interval is 17 cycles. So you would always expect a gap of slightly more than one output cycle. Instead the start of the next group shifts in relation to the setting and sometimes the gap is there and sometimes not.
Blue is port 48 to show the relation.
PRIMI(startPulses) { // ( x y pin -- ) starts smart mode pulses
        _pinh(48);
        int pin= TOS; _drop();
        int y = TOS; _drop();
        int x= TOS; _drop();
        _pinclear(pin);
        _pinstart(pin,P_OE | P_PULSE, x, y);
        _pinl(48);
compiles to:
04b50                 | __startPulses
04b50     59 60 64 FD |     drvh    #48
04b54     E0 D7 02 F6 |     mov arg01, pr0
04b58     04 C8 87 F1 |     sub pr4, #4
04b5c     E4 C1 03 FB |     rdlong  pr0, pr4
04b60     E0 DD 02 F6 |     mov arg04, pr0
04b64     04 C8 87 F1 |     sub pr4, #4
04b68     E4 C1 03 FB |     rdlong  pr0, pr4
04b6c     E0 DB 02 F6 |     mov arg03, pr0
04b70     04 C8 87 F1 |     sub pr4, #4
04b74     E4 C1 03 FB |     rdlong  pr0, pr4
04b78     50 D6 62 FD |     fltl    arg01
04b7c     6B 01 08 FC |     wrpin   #0, arg01
04b80     40 D6 62 FD |     dirl    arg01
04b84     6B 91 08 FC |     wrpin   #72, arg01
04b88     6B DB 12 FC |     wxpin   arg03, arg01
04b8c     6B DD 22 FC |     wypin   arg04, arg01
04b90     41 D6 62 FD |     dirh    arg01
04b94     58 60 64 FD |     drvl    #48
04b98                 | __startPulses_ret
04b98     2D 00 64 FD |     ret
(If you are using the IN bit of the smart pin to restart the group you always loose one output cycle.)
Neither wrpin #0 nor dirl does really stop the smart pin.
Please verify and include this to the known Bugs. It has cost me some hours.
Christof
  • RaymanRayman Posts: 16,345
    The smartpin output is toggling even after a dirl?
    It does take a couple cycles for dirl to take effect right, or doesn’t it?
    Is the pin output changing state even after that?
