64 bit ints and doubles should work, but I haven't tested them thoroughly, so if you find bugs, let me know, but I've been using them and having found any issues yet. Many floating point operations aren't supported yet (the code is there, I just need to actually enable compiling it into the library. I've been doing it piece by piece to avoid adding a ton of code at once and then hunting down bugs later).
@iseries I just merged in a rewrite of stdio and your SD card code. I haven't tested the sd stuff, and the changes to stdio shouldn't be breaking anything, EXCEPT I removed simple_printf. After the rewrite of printf, it didn't really makes sense to keep simple_printf since it was only slightly smaller and faster, not enough to keep both implementations. Let me know if you run into any issues.
Hi @n_ermosh finally got around to downloading LLVM on my M2 Pro based Mac to have a brief look. Not sure if you are still actively working on it or not. I downloaded the latest from your github source at ne75/p2llvm.
Hit a few problems along the way so I thought I'd mention them in case you wanted to figure it out. It seems to be related to the use of the modulus % operator in C which is being converted to QUREM psuedo instruction presumably for later access via the Cordic.
I've found a handful of failing files crashing LLVM Clang with an assert condition and so far the common denominator is always the use of the % operator.
Assertion failed: ((I.atEnd() || std::next(I) == def_instr_end()) && "getVRegDef assumes a single definition or no definition"), function getVRegDef, file MachineRegisterInfo.cpp, line 404.
This simple code below is enough to trigger it if you build with LLVM Clang using the P2 as the target. I was using the build of LLVM included in your latest tree as a submodule which I also built locally on my Mac M2 for acting as the P2 cross compiler.
In my digging into this problem I tried to decipher a few things using -emit-llvm on the clang command line and then passing the output file to "llc --print-after-isel" which shows this:
# After Instruction Selection:
# Machine code for function rand: IsSSA, TracksLiveness
Frame Objects:
fi#-1: size=4, align=1, fixed, at location [SP]
Function Live Ins: $r0 in %0, $r1 in %1
bb.0.entry:
liveins: $r0, $r1
%1:p2gpr = COPY $r1
%0:p2gpr = COPY $r0
%2:p2gpr = MOVri @rand_seed, 15, 0
%3:p2gpr = RDLONGrr killed %2:p2gpr, 15, 0 :: (dereferenceable load (s32) from @rand_seed, !tbaa !3)
%4:p2gpr = QUREM killed %3:p2gpr, %1:p2gpr
%5:p2gpr = ADDrr %4:p2gpr(tied-def 0), %0:p2gpr, 15, 0
$r31 = COPY %5:p2gpr
RETA 15, 0, implicit $r31
# End machine code for function rand.
PLEASE submit a bug report to https://bugs.llvm.org/ and include the crash backtrace.
Stack dump:
0. Program arguments: /Users/roger/Applications/p2llvm/bin/llc --print-after-isel math.bc
1. Running pass 'Function Pass Manager' on module 'math.bc'.
2. Running pass 'Live Variable Analysis' on function '@rand'
Stack dump without symbol names (ensure you have llvm-symbolizer in your PATH or set the environment var `LLVM_SYMBOLIZER_PATH` to point to it):
0 llc 0x0000000101ed7ffc llvm::sys::PrintStackTrace(llvm::raw_ostream&, int) + 80
1 llc 0x0000000101ed85a0 PrintStackTraceSignalHandler(void*) + 28
2 llc 0x0000000101ed6578 llvm::sys::RunSignalHandlers() + 140
3 llc 0x0000000101ed9a94 SignalHandler(int) + 276
4 libsystem_platform.dylib 0x000000018797ea24 _sigtramp + 56
5 libsystem_pthread.dylib 0x000000018794fc28 pthread_kill + 288
6 libsystem_c.dylib 0x000000018785dae8 abort + 180
7 libsystem_c.dylib 0x000000018785ce44 err + 0
8 llc 0x0000000100b733b4 llvm::MachineRegisterInfo::getVRegDef(llvm::Register) const + 200
9 llc 0x000000010098a888 llvm::LiveVariables::HandleVirtRegUse(llvm::Register, llvm::MachineBasicBlock*, llvm::MachineInstr&) + 64
10 llc 0x000000010098d54c llvm::LiveVariables::runOnInstr(llvm::MachineInstr&, llvm::SmallVectorImpl<unsigned int>&) + 856
11 llc 0x000000010098d9bc llvm::LiveVariables::runOnBlock(llvm::MachineBasicBlock*, unsigned int) + 488
12 llc 0x000000010098e0b4 llvm::LiveVariables::runOnMachineFunction(llvm::MachineFunction&) + 428
13 llc 0x0000000100a7f7ac llvm::MachineFunctionPass::runOnFunction(llvm::Function&) + 456
14 llc 0x00000001011eecec llvm::FPPassManager::runOnFunction(llvm::Function&) + 536
15 llc 0x00000001011f609c llvm::FPPassManager::runOnModule(llvm::Module&) + 116
16 llc 0x00000001011ef5ac (anonymous namespace)::MPPassManager::runOnModule(llvm::Module&) + 672
17 llc 0x00000001011ef134 llvm::legacy::PassManagerImpl::run(llvm::Module&) + 288
18 llc 0x00000001011f64ac llvm::legacy::PassManager::run(llvm::Module&) + 36
19 llc 0x00000001000bf494 compileModule(char**, llvm::LLVMContext&) + 4696
20 llc 0x00000001000bda50 main + 1156
21 dyld 0x00000001875f7fd8 start + 2412
So I'm guessing there is some problem with the QUREM "instruction" not doing the QDIV and taking the result from the GETQY or something like that before returning.
This same problem seems to also prevent me from completing the build of your P2 C library as the file(s) it fails on include the % operator in the C code. It fails on some time functions - I identified strftime.c and localtim.c failing so far, could be more although it got to 96% so it was close! EDIT: no it's just those two files with the % operator, and when I commented out the lines with the modulus, it let the build complete and install the (now broken) libc.a file to the LLVM installation folder.
python3 build.py --skip_llvm --skip_libp2 --install /Users/roger/Applications/p2llvm
[ 1%] Building C object time/CMakeFiles/time.dir/strftime.c.obj
[ 15%] Built target misc
[ 33%] Built target string
[ 38%] Built target math
[ 60%] Built target wchar
[ 90%] Built target stdlib
[ 91%] Built target stdio
[ 91%] Building C object time/CMakeFiles/time.dir/localtim.c.obj
[ 96%] Built target drivers
PLEASE submit a bug report to https://bugs.llvm.org/ and include the crash backtrace, preprocessed source, and associated run script.
Stack dump:
0. Program arguments: /Users/roger/Applications/p2llvm/bin/clang -I/Users/roger/Documents/Code/p2llvm/libc/include -Wall -Werror -ffunction-sections -fdata-sections -Oz -fno-exceptions --target=p2 -MD -MT time/CMakeFiles/time.dir/strftime.c.obj -MF CMakeFiles/time.dir/strftime.c.obj.d -o CMakeFiles/time.dir/strftime.c.obj -c /Users/roger/Documents/Code/p2llvm/libc/time/strftime.c
1. <eof> parser at end of file
2. Code generation
3. Running pass 'Function Pass Manager' on module '/Users/roger/Documents/Code/p2llvm/libc/time/strftime.c'.
4. Running pass 'Live Variable Analysis' on function '@strftime'
I also had a minor issue of the install scripts not fully working outright due to not finding some propeller.h and propeller2.h include files and stuff about missing stdio.h for files that included that. I just copied those files over to the include folder manually and commented out these unnecessary(?) #include <stdio.h> lines and was able to get it to complete the build of the libp2 but unfortunately it doesn't work out of the box from a clean slate so to speak.
With respect to the prior post, I am wondering if this assert is something related to this P2 specific code below in P2ExpandPseudos.cpp that expands the Pseudo instructions where you mentioned in the comment a need to call GETQX first to flush it because I noticed that step was not happening for QUDIV which presumably works okay - although I should really try to go double check that too:
void P2ExpandPseudos::expand_QUREM(MachineFunction &MF, MachineBasicBlock::iterator SII) {
MachineInstr &SI = *SII;
LLVM_DEBUG(errs()<<"== lower pseudo unsigned remainder\n");
LLVM_DEBUG(SI.dump());
BuildMI(*SI.getParent(), SI, SI.getDebugLoc(), TII->get(P2::QDIVrr))
.addReg(SI.getOperand(1).getReg())
.addReg(SI.getOperand(2).getReg())
.addImm(P2::ALWAYS);
// first call getqx so that we flush it out of the cordic. This is in case another cordic operation
// after this calls get qx before it's done.
BuildMI(*SI.getParent(), SI, SI.getDebugLoc(), TII->get(P2::GETQX), SI.getOperand(0).getReg())
.addReg(P2::QX)
.addImm(P2::ALWAYS)
.addImm(P2::NOEFF);
BuildMI(*SI.getParent(), SI, SI.getDebugLoc(), TII->get(P2::GETQY), SI.getOperand(0).getReg())
.addReg(P2::QY)
.addImm(P2::ALWAYS)
.addImm(P2::NOEFF);
SI.eraseFromParent();
Here's what you do for QUDIV which is one instruction less.
UPDATE: So when I removed the extra GETQX from QUREM and rebuilt LLVM it didn't crash anymore with that assert if I use the % operator in C code. So it would appear that this possible QX issue needs to be resolved in a different way somehow.
Ugh, in my attempts to get MicroPython to compile with LLVM I'm running into a serious problem with stack frame generation and computation of parameter offset addresses in function calls with P2LLVM. This seems to be buggy and will crash MP printing code in some situations.
E.g here's my C calling code snippet (with some puts debug stuff added)
puts("calling mp_print_int");
if (fill==' ')
puts("fill is a space");
chrs += mp_print_int(print, val, 0, base, fmt_c, flags, fill, width);
puts("done printing int");
And here's the start of the called code which checks the "fill" argument after it is passed a space character. I found this value was not getting through correctly to the lower layers of code which is why I checked it and then printed the result here.
STATIC int mp_print_int(const mp_print_t *print, mp_uint_t x, int sgn, int base, int base_char, int flags, char fill, int width) {
char sign = 0;
if (fill==' ')
puts("fill still a space");
else
puts("not a space");
Executing the code results in:
fill is a space
not a space
... and then the code never returns due to infinite loop lockup later due to invalid data being passed from not addressing the arguments correctly
I disassembled the relevant code and it sure looks like the argument addressing is wrong.
Caller:
44bc: ed a1 03 f6 mov r0, r29
44c0: ff a0 07 f5 and r0, #255
44c4: 20 a0 5f f2 cmps r0, #32 wcz
44c8: 08 00 90 5d if_nz jmp #8
44cc: df a1 03 f6 mov r0, r15
44d0: 14 bd c3 fd calla #\puts
44d4: db a1 03 f6 mov r0, r11
44d8: 01 a0 07 f1 add r0, #1
44dc: 06 a0 07 f5 and r0, #6
44e0: dd c9 03 f6 mov r20, r13
44e4: d0 c9 83 f1 sub r20, r0
44e8: ff ff 7f ff augs #8388607
44ec: f0 b7 07 f5 and r11, #496
44f0: 0f b6 87 f1 sub r11, #15
44f4: 07 da 67 f7 signx r29, #7
44f8: f8 a1 03 f6 mov r0, ptra
44fc: 04 a0 07 f1 add r0, #4
4500: d0 db 63 fc wrlong r29, r0 <---- write "fill" parameter to SP+4
4504: f8 a1 03 f6 mov r0, ptra
4508: 08 a0 07 f1 add r0, #8
450c: d0 a7 63 fc wrlong r3, r0 <--- write "flags" parameter to SP+8
4510: f8 ab 63 fc wrlong r5, ptra <--- write "width" parameter to SP+0
4514: 07 b6 67 f7 signx r11, #7
4518: f8 a1 03 f6 mov r0, ptra
451c: 0c a0 07 f1 add r0, #12
4520: d0 b7 63 fc wrlong r11, r0 <---- write "base_char" parameter to SP+12
4524: d4 a1 03 f6 mov r0, r4 <--- setup "*print" parameter in r0
4528: ec a5 03 f6 mov r2, r28 <--- setup "sgn" paramter in r2
452c: e4 a7 03 f6 mov r3, r20 <--- setup "base" parameter in r3
4530: 10 f0 07 f1 add ptra, #16 <---- advance SP by 4 long parameters passed on the stack (16 bytes)
4534: 38 46 c0 fd calla #\mp_print_int <---- invoke mp_print_int function
4538: 10 f0 87 f1 sub ptra, #16
453c: ef a3 03 f6 mov r1, r31
4540: e0 a1 03 f6 mov r0, r16
4544: 14 bd c3 fd calla #\puts
The beginning code from the called function is this:
You can see that the SP (ptra) is being advanced by 17 for local variable use (and not divisible by 4) yet when the "fill" argument is read into r8 as a long from ptra[-21] to be checked against a space character (32) it has not really compensated for the offset correctly which is why it doesn't match a space anymore. The stack read won't be aligned to the "fill" data on the stack.
This is not good and makes the entire function call system unreliable. Not sure if/how easy it is to fix or where to start looking. Maybe some rounding up to the next long is needed when any local variables are assigned stack space.
EDIT: I found with some tweaks to the stack space by adding 3 more bytes to a local buffer it would align to a multiple of 4 and start to get further, so it's definitely some alignment issue. It still crashes though as there are deeper layers to also fix.
char buf[INT_BUF_SIZE+3]; <--- I added 3 to align the stack
Results:
fill is a space
fill still a space
EDIT2: Digging a bit further I think this might well be related to the "eliminateFrameIndex" method in the target specific P2RegisterInfo.cpp file. If you google "llvm eliminateFrameIndex" the AI overview response indicates this is probably the area of code needing to be investigated for this problem I am seeing above. That method seems to be where the RDXXXX instructions that use PTRA indexing are being selected/configured and something may be going awry there with the stack frame offsets so I need to try to figure out what is does and if/how to fix it.
Actually I found something else which seemed like it might fix the problem. When you instantiate the P2 specific derived class from its TargetFrameLowering parent class you can also configure the stack alignment. If I set this up to keep the stack aligned using Align(4) it now seems to not crash in MicroPython like it used to and the stack is rounded up to a multiple of 4 when you allocate local variables of arbitrary size.
In P2FrameLowering.h it was using this before, which results in the crash:
The parent class from the LLVM codebase is this and I also setup the TransientStackAlignment to 4 which would otherwise default to 1 if not passed into the initializer.
The description of the TransientStackAlignment member is provided below, which is what we likely need to maintain on a 4 byte boundary to ensure that the computation of the indexes relative to PTRA will be correctly addressing the data items on the stack whenever they are accessed in the function.
/// getTransientStackAlignment - This method returns the number of bytes to
/// which the stack pointer must be aligned at all times, even between
/// calls.
Align getTransientStackAlign() const { return TransientStackAlignment; }
I imagine this fix is probably the way to resolve the issue even though it might have to pad the stack between every single small local item allocated to ensure 32 and 16 bit data can be accessed via indexed reads/writes. Regardless it's good if this is a workable fix in all cases as we do need one if P2LLVM is to be reliable when generating P2 machine code from C. Code can just crash otherwise.
Another idea I was thinking about was using the currently unused PTRB as a some sort of stack frame base register that is loaded from the SP (PTRA) in the prolog and is used for accessing stack frame variables via indexed reads/writes. This lets PTRA grow by arbitrary byte sizes during function execution without affecting the indexing offsets as they'll remain static. It may also help to allow performing "alloca" operations on the stack as well, which I'm not sure is currently supported by P2LLVM. Coding all that is beyond my level of capability at this point however.
Guess it'd be interesting to try to compile RISC-V P2 on Windows again with this. Couldn't get anywhere before, but maybe worth a shot... Then, maybe could try that version of Micropython too... Would love to have this in Windows. Not really at home in Linux...
Is long long (64) bit supported?
I have this code that generates two different answers and don't know if this is correct:
int main(int argc, char** argv) { long long t; int d1; unsigned int c5; int x; printf("Starting\n"); x = rand() % 10; printf("Rand: %d\n", x); d1 = 8052495 + x; c5 = 31559; t = d1 - (c5 << 8); x = d1 - (c5 << 8); printf("t: %lld, x: %d\n", t, x); printf("Done\n"); while (1) { wait(500); } }The long value is 4294941851 were the int value is -25445 which is the answer I was looking for.
Yes, the SD card functions has a bug in it and I didn't know how to send an updated version to an alread submitted pull request.
Apparently all I had to do was update it.
Anyway I need to send you an update to the SD card functions. Also hopefully the memory functions that I updated and you merged in work for you.
Submitted update SD driver code.
Speed test program that was used:
#include <stdio.h> #include <sys/time.h> #include <stdlib.h> #include <propeller.h> #include <sys/sdcard.h> uint32_t randfill(uint32_t *, size_t); int compare(uint32_t *, uint32_t *, size_t); #define PIN_SS 23 #define PIN_MISO 20 #define PIN_CLK 21 #define PIN_MOSI 22 uint32_t data1[25000]; uint32_t data2[25000]; struct tm tv; int main(int argc, char** argv) { FILE *fh; uint32_t ticks; time_t t; struct timeval x; tv.tm_year = 2022 - 1900; tv.tm_mon = 3; tv.tm_mday = 7; tv.tm_hour = 6; tv.tm_min = 0; tv.tm_sec = 0; t = mktime(&tv); x.tv_sec = t; x.tv_usec = 0; settimeofday(&x, 0); printf( " clkfreq = %d clkmode = 0x%x\n", _clkfreq, _clkmode); printf( " Randfill ticks = %d\n", randfill( data1, sizeof(data1) ) ); printf( " Mounting: " ); sd_mount(0, PIN_SS, PIN_CLK, PIN_MOSI, PIN_MISO); if( (fh = fopen( "SD0:/speed2.bin", "w" )) > 0 ) { ticks = getms(); fwrite( data1, 1, sizeof(data1), fh ); fclose( fh ); ticks = getms() - ticks; printf( " Writing %u bytes at %u kB/s\n", sizeof(data1), (sizeof(data1) * 1000 / ticks + 512) >> 10 ); } else printf( " SD card write error!\n" ); if( (fh = fopen( "SD0:/speed2.bin", "r" )) > 0 ) { ticks = getms(); fread( data2, 1, sizeof(data2), fh ); fclose( fh ); ticks = getms() - ticks; printf( " Reading %u bytes at %u kB/s\n", sizeof(data2), (sizeof(data2) * 1000 / ticks + 512) >> 10 ); if( compare( data1, data2, sizeof(data2) ) ) printf( " Matches! :)\n" ); else printf( " Mis-matches! :(\n" ); } else printf( " SD card read error!\n" ); while (1) { waitms(500); } } uint32_t randfill( uint32_t *addr, size_t size ) { uint32_t ticks; size >>= 2; ticks = _cnt(); do { *(addr++) = rand(); } while( --size ); return( _cnt() - ticks ); } int compare( uint32_t *addr1, uint32_t *addr2, size_t size ) { uint32_t pass = 1; size >>= 2; do { if( *(addr1++) != *(addr2++) ) pass = 0; } while( --size ); return( pass ); }Mike
Assertion failed: ((I.atEnd() || std::next(I) == def_instr_end()) && "getVRegDef assumes a single definition or no definition"), function getVRegDef, file MachineRegisterInfo.cpp, line 404.This simple code below is enough to trigger it if you build with LLVM Clang using the P2 as the target. I was using the build of LLVM included in your latest tree as a submodule which I also built locally on my Mac M2 for acting as the P2 cross compiler.
#include <stdint.h> uint32_t rand_seed = 2223; uint32_t rand(uint32_t min, uint32_t max) { return (rand_seed % max)+min; }In my digging into this problem I tried to decipher a few things using -emit-llvm on the clang command line and then passing the output file to "llc --print-after-isel" which shows this:
void P2ExpandPseudos::expand_QUREM(MachineFunction &MF, MachineBasicBlock::iterator SII) { MachineInstr &SI = *SII; LLVM_DEBUG(errs()<<"== lower pseudo unsigned remainder\n"); LLVM_DEBUG(SI.dump()); BuildMI(*SI.getParent(), SI, SI.getDebugLoc(), TII->get(P2::QDIVrr)) .addReg(SI.getOperand(1).getReg()) .addReg(SI.getOperand(2).getReg()) .addImm(P2::ALWAYS); // first call getqx so that we flush it out of the cordic. This is in case another cordic operation // after this calls get qx before it's done. BuildMI(*SI.getParent(), SI, SI.getDebugLoc(), TII->get(P2::GETQX), SI.getOperand(0).getReg()) .addReg(P2::QX) .addImm(P2::ALWAYS) .addImm(P2::NOEFF); BuildMI(*SI.getParent(), SI, SI.getDebugLoc(), TII->get(P2::GETQY), SI.getOperand(0).getReg()) .addReg(P2::QY) .addImm(P2::ALWAYS) .addImm(P2::NOEFF); SI.eraseFromParent(); }Here's what you do for QUDIV which is one instruction less.
void P2ExpandPseudos::expand_QUDIV(MachineFunction &MF, MachineBasicBlock::iterator SII) { MachineInstr &SI = *SII; LLVM_DEBUG(errs()<<"== lower pseudo unsigned division\n"); LLVM_DEBUG(SI.dump()); BuildMI(*SI.getParent(), SI, SI.getDebugLoc(), TII->get(P2::QDIVrr)) .addReg(SI.getOperand(1).getReg()) .addReg(SI.getOperand(2).getReg()) .addImm(P2::ALWAYS); BuildMI(*SI.getParent(), SI, SI.getDebugLoc(), TII->get(P2::GETQX), SI.getOperand(0).getReg()) .addReg(P2::QX) .addImm(P2::ALWAYS) .addImm(P2::NOEFF); SI.eraseFromParent(); }UPDATE: So when I removed the extra GETQX from QUREM and rebuilt LLVM it didn't crash anymore with that assert if I use the % operator in C code.
+#if 0 BuildMI(*SI.getParent(), SI, SI.getDebugLoc(), TII->get(P2::GETQX), SI.getOperand(0).getReg()) .addReg(P2::QX) .addImm(P2::ALWAYS) .addImm(P2::NOEFF); +#endifUgh, in my attempts to get MicroPython to compile with LLVM I'm running into a serious problem with stack frame generation and computation of parameter offset addresses in function calls with P2LLVM. This seems to be buggy and will crash MP printing code in some situations.
puts("calling mp_print_int"); if (fill==' ') puts("fill is a space"); chrs += mp_print_int(print, val, 0, base, fmt_c, flags, fill, width); puts("done printing int");And here's the start of the called code which checks the "fill" argument after it is passed a space character. I found this value was not getting through correctly to the lower layers of code which is why I checked it and then printed the result here.
STATIC int mp_print_int(const mp_print_t *print, mp_uint_t x, int sgn, int base, int base_char, int flags, char fill, int width) { char sign = 0; if (fill==' ') puts("fill still a space"); else puts("not a space");Executing the code results in:
Caller:
44bc: ed a1 03 f6 mov r0, r29 44c0: ff a0 07 f5 and r0, #255 44c4: 20 a0 5f f2 cmps r0, #32 wcz 44c8: 08 00 90 5d if_nz jmp #8 44cc: df a1 03 f6 mov r0, r15 44d0: 14 bd c3 fd calla #\puts 44d4: db a1 03 f6 mov r0, r11 44d8: 01 a0 07 f1 add r0, #1 44dc: 06 a0 07 f5 and r0, #6 44e0: dd c9 03 f6 mov r20, r13 44e4: d0 c9 83 f1 sub r20, r0 44e8: ff ff 7f ff augs #8388607 44ec: f0 b7 07 f5 and r11, #496 44f0: 0f b6 87 f1 sub r11, #15 44f4: 07 da 67 f7 signx r29, #7 44f8: f8 a1 03 f6 mov r0, ptra 44fc: 04 a0 07 f1 add r0, #4 4500: d0 db 63 fc wrlong r29, r0 <---- write "fill" parameter to SP+4 4504: f8 a1 03 f6 mov r0, ptra 4508: 08 a0 07 f1 add r0, #8 450c: d0 a7 63 fc wrlong r3, r0 <--- write "flags" parameter to SP+8 4510: f8 ab 63 fc wrlong r5, ptra <--- write "width" parameter to SP+0 4514: 07 b6 67 f7 signx r11, #7 4518: f8 a1 03 f6 mov r0, ptra 451c: 0c a0 07 f1 add r0, #12 4520: d0 b7 63 fc wrlong r11, r0 <---- write "base_char" parameter to SP+12 4524: d4 a1 03 f6 mov r0, r4 <--- setup "*print" parameter in r0 4528: ec a5 03 f6 mov r2, r28 <--- setup "sgn" paramter in r2 452c: e4 a7 03 f6 mov r3, r20 <--- setup "base" parameter in r3 4530: 10 f0 07 f1 add ptra, #16 <---- advance SP by 4 long parameters passed on the stack (16 bytes) 4534: 38 46 c0 fd calla #\mp_print_int <---- invoke mp_print_int function 4538: 10 f0 87 f1 sub ptra, #16 453c: ef a3 03 f6 mov r1, r31 4540: e0 a1 03 f6 mov r0, r16 4544: 14 bd c3 fd calla #\putsThe beginning code from the called function is this:
00004638 <mp_print_int>: 4638: 28 18 64 fd setq #12 463c: 61 a1 67 fc wrlong r0, ptra++ <----- saves 13 registers from r0-r12 4640: 11 f0 07 f1 add ptra, #17 <---- advances SP (for local variables?) 4644: d3 af 03 f6 mov r7, r3 <-- preserve arg r3 4648: d0 a9 03 f6 mov r4, r0 <---preserve arg r0 464c: 78 02 00 ff augs #632 4650: f7 a1 07 f6 mov r0, #503 <--- compute first string address 4654: 72 02 00 ff augs #626 4658: 77 a7 07 f6 mov r3, #375 <---- compute alternative string address 465c: 2b b1 07 fb rdlong r8, ptra[-21] <---- read "fill argument" by subtracting 21 longs worth (84 bytes) 4660: 20 b0 5f f2 cmps r8, #32 wcz <--- check against space character 4664: d3 a1 03 a6 if_z mov r0, r3 <--- matches space 4668: d0 a1 03 56 if_nz mov r0, r0 <--- doesn't match space 466c: f8 ed 03 f6 mov pa, ptra 4670: 11 ec 87 f1 sub pa, #17 4674: f6 01 48 fc wrbyte #0, pa <--- clear local? 4678: 14 bd c3 fd calla #\puts <--- print result 467c: 00 b2 07 f6 mov r9, #0 4680: 2c a7 07 fb rdlong r3, ptra[-20] 4684: 0f a4 97 fb tjz r2, #15 4688: ff ff 7f ff augs #8388607 468c: ff a3 5f f2 cmps r1, #511 wcz 4690: 04 00 90 1d if_nc_and_nz jmp #4You can see that the SP (ptra) is being advanced by 17 for local variable use (and not divisible by 4) yet when the "fill" argument is read into r8 as a long from ptra[-21] to be checked against a space character (32) it has not really compensated for the offset correctly which is why it doesn't match a space anymore. The stack read won't be aligned to the "fill" data on the stack.
char buf[INT_BUF_SIZE+3]; <--- I added 3 to align the stackResults:
explicit P2FrameLowering(const P2TargetMachine &TM) : TargetFrameLowering(StackGrowsUp, Align(1), 0), tm(TM) {I just changed it to this and I don't get the crash any more:
explicit P2FrameLowering(const P2TargetMachine &TM) : TargetFrameLowering(StackGrowsUp, Align(4), 0, Align(4)), tm(TM) {The parent class from the LLVM codebase is this and I also setup the TransientStackAlignment to 4 which would otherwise default to 1 if not passed into the initializer.
/// getTransientStackAlignment - This method returns the number of bytes to /// which the stack pointer must be aligned at all times, even between /// calls. Align getTransientStackAlign() const { return TransientStackAlignment; }I imagine this fix is probably the way to resolve the issue even though it might have to pad the stack between every single small local item allocated to ensure 32 and 16 bit data can be accessed via indexed reads/writes. Regardless it's good if this is a workable fix in all cases as we do need one if P2LLVM is to be reliable when generating P2 machine code from C. Code can just crash otherwise.
@rogloh sounds like good progress. Think I remember building this in Windows a while ago. Guess I’ll try again when you think it’s ready…
