Availablity of P2 code for Nextion Displays?
in Propeller 2
@JonnyMac
I just received a Nextion display for another non-P2 project. I would like to incorporate into my next P2 projects. In another idscussion you mentioned having both P1 and P2 code.Are your P2 code/objects available somewhere? I checked OBEX but did not find them?
TrapperBob
Here you go. This simple demo shows the specifics of the connected display, and if it sends text strings the way I do in my projects, will display them onscreen.
I found a display that had an Escape Room timer running it it. There's not a lot of interaction, but the display does report when the user enters a bad code (shows the number of current tries) and when successful, reports locked as 0.
Here's the output on my system.
You'll need to set BR_HMI, TX_HMI, and RX_HMI constants for your display and connections.
Thanks Jon,
I looked it over. Seems very nice as I have found all your code. I hope to start working on the P2 project in about 2 weeks when I have some free time.
Bob
Wonder if one really needs RX if just want to show things and not get feedback…
Would be nice if just needed 1 P2 I/o pin…
You could do that, but not with my object because it verifies that the Nextion is connected. Underneath my Nextion object is a trim serial object (jm_xfds.spin2) that can be used in transmit-only mode (set the RX pin to -1). That said, with P2 smart pins one could make a cogless object that just sends bytes and strings for display-only control. I routinely run my Nextion displays at 230400 baud, and even switch to 921600 when uploading a new TFT file. As most display strings would be short, I think a cogless display-only object would work fine.
