Changing a global variable from inside a method?
bob_g4bby
I want to add a method to my rotary encoder library for the 8encoder that allows the programmer to link a knob to a variable, so that turning the knob changes that variable.
Say I have a variable and a pointer:-
long myvar
^long myptr
This would set myptr to point to myvar - yes?
[myptr] := @myvar
I create a method :-
pub mymethod(knob#, ptr) | delta
delta := read_knob_change(knob#)
... some code ...
I use the method:-
mymethod(2, myptr)
What would 'some code' have to include to modify the value held in myvar, please?
Couldn't find any clues in the Spin2 manual and have tried all sorts, cheers, bob
No matter what, you still have to access the encoder hardware in a method to assign your target variable(s). You get nothing using a pointer in this case.
Where it might be useful is reading all with one method to any arbitrary array.
pub get_encoders(p_data) | ch repeat ch from 0 to 7 long[p_data][ch] := encoder_read(ch)This code works in the P1 and in the P2. The pointer p_data is the address of the first element of the array.
Cheers, Jon, I'll have to go at it another way - there's always an alternative. The code above is a useful example in it's own right - I would never have guessed the syntax
My solution was this in the end:-
pub read_knob_inrange(channel,min,max) : result | temp ' read knob value - channel 1-8 but limit the result to between min and max temp := read_knob(channel) result := min #> temp <# max if temp <> result write_knob(channel,result)so controlling a global variable was just a simple assigment:-
myvar := read_knob_inrange(1,-30,30) ' knob ch1 controls myvar between -30 and 30
