Changing a global variable from inside a method? — Parallax Forums
bob_g4bbybob_g4bby Posts: 591
edited 2026-02-28 22:49 in PASM2/Spin2 (P2)
I want to add a method to my rotary encoder library for the 8encoder that allows the programmer to link a knob to a variable, so that turning the knob changes that variable.
Say I have a variable and a pointer:-
long myvar
^long myptr
This would set myptr to point to myvar - yes?
[myptr] := @myvar
I create a method :-
pub mymethod(knob#, ptr) | delta
delta := read_knob_change(knob#)
... some code ...
I use the method:-
mymethod(2, myptr)
What would 'some code' have to include to modify the value held in myvar, please?
Couldn't find any clues in the Spin2 manual and have tried all sorts, cheers, bob
  • JonnyMacJonnyMac Posts: 9,821
    edited 2026-03-01 00:29
    No matter what, you still have to access the encoder hardware in a method to assign your target variable(s). You get nothing using a pointer in this case.
    Where it might be useful is reading all with one method to any arbitrary array.
    pub get_encoders(p_data) | ch
      repeat ch from 0 to 7
        long[p_data][ch] := encoder_read(ch)
    This code works in the P1 and in the P2. The pointer p_data is the address of the first element of the array.
    edited 2026-03-01 08:42
    Cheers, Jon, I'll have to go at it another way - there's always an alternative. The code above is a useful example in it's own right - I would never have guessed the syntax
  • My solution was this in the end:-
    pub read_knob_inrange(channel,min,max) : result | temp
    ' read knob value - channel 1-8 but limit the result to between min and max
           temp := read_knob(channel)
           result := min #> temp <# max
           if temp <> result
                write_knob(channel,result)
    so controlling a global variable was just a simple assigment:-
    myvar := read_knob_inrange(1,-30,30) ' knob ch1 controls myvar between -30 and 30
    edited 2026-03-03 17:13
    [deleted]
