Wiznet W6300 - Page 3 — Parallax Forums
Wiznet W6300
13»
  • ke4pjwke4pjw Posts: 1,283
    @Rayman said:
    How does that work? Does the Wiznet ask the device for a preferred name?
    And then, everybody can address each other by name?
    The names have to be in the .local domain, but yes, if you have a nameresolver that supports MDNS, you can connect to other devices with the hostname. Windows will even go to just a short name. I don't know if other resolvers do that.
    How it works in this instance:
    I configure socket 4 on the W6100 to join the multicast group : 01:00:5E:00:00:FB
    I configure the socket to have a destination IP of 224.0.0.251
    I configure the destination port to be 5353
    I open the socket. It joins the multicast group and listens for UDP traffic destined for 224.0.0.251 on port 5353.
    In the webserver, when I am waiting for a connect, if none is detected, I execute a method to check if there is any data waiting on socket 4. If there is, I validate if it a MDNS query. If it isn't, I return. I then check to see of the queried hostname matches my own. If it doesn't, I return. If it does, I send an MDNS announcement via socket 4 with my IP address. The remote machine receives this query and then caches the IP address for the name in its resolver.
    I currently do not do service announcements and I am not sure if there is value in doing that.
  • RaymanRayman Posts: 16,080
    edited 2026-02-25 11:11
    @ke4pjw does the new chip offer any advantages in 1-bit mode?
    I’m a bit delayed in testing your board due to water leak and heating failure where it is, but will get on it soon.
    It requires 3 less pins than quad mode. It's kind of nice that you can do 1, 2, or 4 pins modes with software.
    Let me know how it works for you.
    --Terry
