Have you tried using floating point log() in FlexC, compiling and looking at the disassembly? IIRC, FlexC uses the CORDIC unit for floating point math, at least QMUL, QDIV and SQRT. I haven't tested exp() and log(), so far.
No need to look at the disassembly, the source code for __builtin_log2f and __builtin_exp2f are in the FlexProp include/libsys/powers.c file. They're not highly optimized, but I think they work OK.
It's a bit confusing as QLOG works in base 2 and log works in e... Think starting to get it now...
Also have to remember what version of debug type to use... UDEC for qlog, and FDEC for log...
QLOG is a fixed point logarithm using the cordic. Since it's an interface to P2 hardware it's not available on P1 (similarly for other cordic operations, like ROTXY and POLXY). However, the floating point LOG operators (LOG, LOG2, LOG10) are available on P1 in FlexSpin. On P1 they use the built in log tables in the ROM, so they're a little less accurate than the P2 versions. Ditto for QEXP vs EXP, EXP2, EXP10.
Just thought I'd mention that in the latest flexspin QEXP and QLOG are supported on P1, albeit at reduced precision. It turns out that in the EXP and LOG calculations I was basically emulating QEXP and QLOG anyway (using the ROM tables rather than CORDIC), so I moved that code into the common area and provided interfaces. The tables are only accurate to 16 bits rather than 32, but at least programs using them can run.
In digital signal processing and embedded programming, choosing between QLOG fixed-point and SPIN2 floating-point represents a trade-off between computational efficiency and ease of use.
Well, my primary concern was that the 5/27 fixed point format output from cordic qlog in my inline pasm method wasn't displayable in a debug SCOPE window. Any suggestions, please? I have logarray[1024] full of fixed point values, how to display them is the thing.
It's the output of an fft; receiver spectrum displays are best with a log y-axis. I would have thought I could have simply plotted the array as if it was filled with unsigned integers - the numbers would be just scaled by the shift of the decimal point 27 places to the right, but the display doesn't look right.
I'll have another go on those lines, perhaps with a very simple signal rather than the receiver adc output I've been using.
The other thing to try initially is the debug FFT display, which should take the output from the receiver adc directly. Edit: Not useful, this window processes integers, not complex numbers. So good for analysing microphones and other mono sources.
All good fun, bob
The latest versions of Spin2 (found in PNut, Pnut-TS, and PropTools, I believe) have several new log and exp functions that work in floating point.
Thanks, Chip - that'll be used in the spectrum display on the radio receiver I'm working on. Log amplitude is the norm.
Anybody know how qlog and qexp work?
Was just testing it and doesn't make any sense to me..
PUB Main()|x,y x:=2 y:=qexp(x) debug(fdec(y)) x:=256 y:=qlog(x) debug(fdec(y))Getting similar results in PNut, FlexProp, and Spin Tools IDE, so guess that's good anyway...
QLOG and QEXP are fixed point
PUB Main()|x,y x:=3<<27 y:=qexp(x) debug(udec(y)) x:=256 y:=qlog(x)>>27 debug(udec(y))From the latest Spin2 docs
Oh, I see .. thanks
There is a LOG2 operator in that list. Does that match QLOG?
@Rayman :
@ersmith that is for Spin2 on P1 right?
Thanks for that.
For P2, the 64/96/128 Math library on Obex has a 5/27 fixed point format to integer conversion but it's in Spin, not Pasm
All good fun, bob
