FlexProp: a complete programming system for P2 (and P1) - Page 61 — Parallax Forums
1555657585961»
  • @ersmith said:
    I'd really need more context to try to guess what's wrong. In one of your other posts you mentioned using a conditional debug in assembly (like if_b DEBUG()). The hardware doesn't actually support that, and so it should produce an error in flexprop, but if it somehow gets through it'll do weird things.
    The particular weird thing that happens (when C=0 in that case) is that INT0 gets triggered without latching the BRK argument. So it'll repeat the processing of the most recent debug statement. If the cog never did a debug before, I think it defaults to $00, which IIRC triggers single step mode, which FlexProp doesn't have a way to handle. That would look a lot like a hard crash (incl. garbage spew on the terminal).
  • Is it possible to have some files of your project compile to byte code and some to machine code? I'm thinking about a software radio, with dsp compiled to machine code with quite a few largish buffers taking up memory and the gui running as byte code to fit in the remaining space. If this has been answered elsewhere, could someone point me to it please? Cheers, Bob
  • ersmithersmith Posts: 6,252
    Unfortunately that is difficult to do. It is possible, if you can completely separate the two parts -- @Wuerfel_21 did something like this with one of her game emulators (NeoYume and/or MegaYume) where she basically compiled two independent programs with different flags, one of them with the -E -H xxx flags so that it would run at a different hub address. This "upper" program could then be run by the "lower" program.
    Another possibility is to use the -W flag to produce "wrapped" Spin code that's basically inline assembly. But that isn't well tested and probably doesn't work very well.
    I would suggest as a first step just compiling everything into bytecode with -2nu, and then using inline assembly to accelerate the dsp part as necessary. That would be much easier than the other options.
  • Thank you for the advice, @ersmith . I've started with a DSP library made of inline assembly methods working on arrays - just about to add the cordic functions, which will be pretty fast thanks to the use of a cog pair with shared lut. Quite a tricky ballet dance to coordinate the two cogs to give 14 cycles per iq sample. My initial experiments indicate that a string of these methods running in a byte code program would spend by far the most time in the inline code and very little time in Spin.
    So your compiler gives me a chance to compile either way and find out which fits inside 500k.
    Cheers, bob
  • RaymanRayman Posts: 16,054
    edited 2026-02-02 19:10
    @ersmith Testing out Spin2 on P1...
    How does one set the clock? I can't find anything in the docs about it...
    This works, although obviously shouldn't:
    CON
        _clkfreq = 320_000_000
    It is just automatically always setting the clock to 80 MHz?
    Found that you can set the clock the P1 one way in Spin2 for P1, but setting to anything other than 80 MHz seems to break the serial interface.
    So, maybe best to just let it automatically set itself for 80 MHz and leave off the con section for clock?
    edited 2026-02-02 19:08
    Also, things like "pinh" seem to work, but should really be "_pinh" right?
    Actually, found a note in the docs:
    Note that in Spin2
    mode many of these are available without the leading underscore, and in fact
    it's better to use the non-underscore versions since those are also supported in
    the official Parallax compiler.
    Seems pinf() should be in this section too, but it does seem to work regardless...
    Should Pinfields work with Spin2 for P1?
    Thought they might with some under the hood magic, but seems like they don't.
    edited 2026-02-02 20:03
    @ersmith Seeing something in Spin manual that am not understanding...
    Object pointers
    The proposed Spin2 syntax for abstract object definitions and object pointers is
    accepted by flexspin, even in Spin1 mode. A declaration like:
    OBJ
    fds = "FullDuplexSerial"
    declares fds as having the methods of a FullDuplexSerial object, but without
    any actual variable or storage being instantiated. Symbols declared this way
    may be used to cast parameters to an object type, for example:
    PUB print(f, c)
    fds[f].dec(c)
    PUB doprint22
    print(@aFullDuplexSerialObj, 22)
    Maybe slow today, but isn't fds = "FullDuplexSerial" just the regular way of declaring an object?
    Also where is the "a" in "@aFullDuplexSerialObj" coming from? Is that a typo?
    And, what about the "Obj" at the end? Where does that come from?
    Ok, maybe seeing that usual way is fds : "FullDuplexSerial". So, replacing colon with equal sign is the difference.
    CON
    On P1 you need to set up a _clkmode constant (just like you do for Spin1 code). If there isn't one there then any _clkfreq constants are ignored. Probably there should be a warning for this case.
    Hmmm, other frequencies should work for serial, but it's not tested much (P1 in general doesn't get much attention any more). So yeah, probably safest to just leave the default.
    No, I think in Spin2 it's called pinh, isn't it? Has Chip changed that? The _pinh version is always there in all the languages though, so it's what I tend to use.
    Object pointers
    OBJ
    PUB print(f, c)
    fds[f].dec(c)
    PUB doprint22
    As you figured out later, the difference is equal vs colon sign.
    No, it's supposed to represent some concrete object whose address is being taken to pass to the print function. The example isn't quite complete. There should be a declaration like:
      aFullDuplexSerialObj : "FullDuplexSerial"
    Interesting error when clicking on an object in Spin2 file when compiling for P1...
    Seems that FlexProp wants the extension specified in this case...
    Maybe it could assume that a Spin2 file will have objects that are also Spin2, unless otherwise specified?
    592 x 142 - 15K
    @Rayman that's a typo in the GUI source code (Tcl/Tk, which is interpreted). It's fixed in github now, thanks.
    @ersmith Is there a fundamental reason why FatFs can't work with P1?
    I'm thinking it should be able to work, but maybe I'm missing something?
    I think the only fundamental issue is that it probably needs more memory than will fit on P1, or at least more than will fit comfortably. I could be wrong, but I don't think there'd be much space, if any, left after the file system code is included.
    Ok, yeah can see that
    @ersmith Seeing a possible issue with waitus(2) with P1 in Spin2 mode...
    Seems to take ~10x longer than it should... See attached code.
    I see there's a lot going on in the waitus() assembly, so maybe P1 just isn't fast enough for waitus(2)?
    @ersmith Hope not annoying you too much with Spin2 for P1 stuff...
    It seems that debug keyboard input is not implemented for Spin2 on P1...
    Getting this error message:
    warning: Unhandled debug format PC_Key
    Maybe this is relatively easy to implement or fix?
    There's certainly room for improvement in waitus(), particularly for the P1. I'll be checking in a better version soon.
    Having said that, waitus(2) is only 160 cycles on the P1, which given that we need a multiply (done in software on the P1) is not a lot of time. Definitely this is a case where waitcnt() would be useful.
    It's not implemented on P2, either :(. I haven't looked at it yet, but it's probably not trivial (the existing DEBUG things are all output rather than input, so it needs a totally different approach).
  • JonnyMacJonnyMac Posts: 9,673
    I wrote a little P1 EEPROM explorer program. It's in this thread:
    -- https://forums.parallax.com/discussion/178021/p1-eeprom-explorer
    While I don't use FlexProp I do try to test for those that might be interested in what I'm doing. To my surprise, the formatted output from my serial driver doesn't work in FlexProp bytecode mode:
    It does work when compiled to PASM:
  • Wuerfel_21Wuerfel_21 Posts: 5,794
    edited 2026-02-19 01:58
    I shall take a look at it tomorrow (if I don't forget, currently very busy in other endeavours)
    EDIT: On second look, it appears all the hex digits are missing. So that's probably(?) easy to fix.
  • After getting way too deep into it, I realized the compiler is already emitting a warning indicating the issue: jm_fullduplexserial.spin:422: warning: only first element of string is used
    It seems that lookdown with a string doesn't work as it should.
    edited 2026-02-19 14:48
    That explains why decimal works; d is the first character in the lookdown string.
        elseif (c == "%")
          p_str := get_nargs(p_str, @field, @digits)
          c := byte[p_str++]
          if (lookdown(c : "dfbqoxDFBQOX"))
            str(nstr.fmt_number(long[p_args][idx++], c, digits, field, " "))
    Thanks for fixing that.
