Use of long, word, byte, res in inline assembly Solved. RET needed!
R Baggett
I never see this:
PUB DoNothingExample(V1,V2,V3):V4,V5|V6
org
rdlong var1,#@clkfreq
shl var1,#1
var1 res 1
end
And indeed, some code where I tried it is acting up.. Is this not allowed?
Is there a way to get beyond the variable limit for inline code (6, I think?)
Without an explicit RET added after the SHL, you're attempting to execute whatever is placed in var1.
I just did this with an inline FFT. Both res and long are fine. You will need to "ret" before the cog tries to run whatever is in those variables as instructions.
There are also named registers pr0 through pr7 that may be used by inline assembly.
I knew that... Hate when that happens
THANKS!
THAT, I missed somehow..
Thanks!
While I was answering an email and editing the demo, everyone answered -- but here it is. I have have used res inside inline PASM a few times.
I have a no-cog version of a WS2812 pixel driver that uses the PRx registers. In this case setregs is used to move global variables into the PRx registers to be used by the inline PASM.
pub show(swap) '' Refresh pixels '' -- swap.[0] is 1 for red/green swap (WS2812b) '' -- cog prX regs: '' 0:pin, 1:p_buf/color, 2:count, 3:reset, 4:zero, 5:one, 6:period, 7:timer setregs(@pixout, PRX_REGS, 7) ' copy hub vars to cog regs pr0..pr6 org drvl pr0 ' make output/low waitx pr3 ' allow reset mov ptrb, pr1 ' point to start of buffer .pixloop rdlong pr1, ptrb++ ' get pixel data testb swap, #0 wc ' swap red & green? if_c movbyts pr1, #%%2310 ' yes getct pr7 ' initialize bit timer rep #7, #24 ' loop through all bits shl pr1, #1 wc ' get MSB drvh pr0 ' pin on if_nc waitx pr4 ' hold for bit timing if_c waitx pr5 drvl pr0 ' pin off addct1 pr7, pr6 ' update bit timer waitct1 ' let bit timing finish djnz pr2, #.pixloop endFrom what I just read, ret may be preferable to ret as an instruction because it skips context restore.. right?
Gotta keep that one in the toolbox..
Thanks!
To be honest, I don't know. My understanding is that the inline PASM is copied into the lower cog memory and called from the interpreter like any other routine, hence a return instruction gets back to the standard interpreter code.
Maybe @cgracey can chime in.
The _RET_ prefix and the RET instruction do the same thing (return from the hardware stack).
There are only a few differences / things to note:
_RET_ DJNZfor a loop and it will automatically return after the last iteration.Thanks! My confusion decreases.
_RET_takes two cycles fewer thanRET. If the top of stack is $1FF, i.e. XBYTE is in operation, then_RET_andRETtake zero and two cycles, respectively, because no actual return is done and TOS remains $1FF. As it is a prefix not a separate instruction,_RET_can save a significant amount of code in pure PASM programs and is one of Chip's many great ideas.RETcan restore C or Z or both or neither with WC/WZ/WCZ/{no suffix}.Instruction prefixing does take up extra code space. An example of prefixing is the AUGx instructions. They modify the subsequent instruction.
_RET_is a built-in option of most instructions, like CC modification or conditional execution. No extra code to have these.PS: The Z80 was famous for its instruction set extensions via prefixing.
Yeah I guess using "prefix" is not quite right here
Thanks all for the clarifications!
I can't find an appropriate definition of this. I presume it refers to what the PASM manual calls 'Effects'? Else I am missing something (Again...)
I remember that...
It's a feature of the instruction architecture, like 3-operand instructions would be called a feature. I've sometimes called an individual use a "modifier" but that's more a programming language terminology thing.
I suppose, in the source code,
_RET_is textually written as a prefix to the mnemonic. It is required to be in that position to get assembled correctly. It can't be on a separate line like a label can. So in that textural sense it is a prefix.
