OUTA: Timing question
ErNa
I'm running a P2 at 200 MHz. I'm writing Bit 0 to 7 using OUTA.
I observe, that not all bits switch at the same time.
Something, I didn't expect. Is it a bug or a feature?
I did no further tests yet, as it came as a surprise. But I create a sync-pulse
if_z Or outA, #%1000_0000 'Trigger setzen
AND OutBits, #%0011_1111 ' Reset Trigger
mov outA, OutBits
The sync pulse is as short, as it should be.
I think, I could have done it ANDing the bits directly, but didn't care then
a) post your code. It certainly shouldn't take on the order of microseconds(?) to switch the pins
b) generally there is some nanosecond-level difference in propagation delay between pins. You can use the P_SYNC_IO mode to reduce the difference, but now everything is delayed by a full clock cycle.
Main: mov dirA, dirA_Sel ' sets direction of portB pins Subroutine Transition 'Start Transition mov OutBits, PattCurr ' output pattern and OutBits, dirA_sel ' isolate relevant bits mov outA, OutBits mov TimeCT3, TimeCT2 Transition_ret ret ' return from subroutineI output bit 0..7, dirA_sel masks the relevant bits
The timer is redundant
I do not use (to my knowledge) any smart-pin function for this I/O,
but have some ADC and a DAC running.
Where can I find info related to P_SYNC_IO?
Hmm, that code looks alright - are you sure you are measuring it right? Or am I mis-reading the scope claiming a 70us view duration?
P_SYNC_IO (also known as "registered I/O") is a flag you set with WRPIN. This just adds an extra latch into the signal chain, very close to the actual output drivers.
You would e.g.
wrpin ##P_SYNC_IO,#0 addpins 7to enable it for pins 0 through 7The code snippets are both incomplete. The first snippet should exist in the second snippet but doesn't. Also, values are not listed, only symbols.
The next time, I intend to expose my stupidity, I'll impose tariffs! At least, I know how to attach a scope, I'll now exercise to attach it to the right pins....
Regarding P_SYNC_IO, you'll find all those symbols at the end of Chip's "Spin 2 Language Documentation" - https://www.parallax.com/propeller-2/documentation/
