OUTA: Timing question — Parallax Forums
ErNaErNa Posts: 1,851
edited 2026-02-13 23:13 in PASM2/Spin2 (P2)
I'm running a P2 at 200 MHz. I'm writing Bit 0 to 7 using OUTA.
I observe, that not all bits switch at the same time.
Something, I didn't expect. Is it a bug or a feature?
I did no further tests yet, as it came as a surprise. But I create a sync-pulse
if_z        Or      outA,      #%1000_0000    'Trigger setzen
        AND      OutBits,      #%0011_1111    '  Reset Trigger
        mov      outA,      OutBits
The sync pulse is as short, as it should be.
I think, I could have done it ANDing the bits directly, but didn't care then
  • a) post your code. It certainly shouldn't take on the order of microseconds(?) to switch the pins
    b) generally there is some nanosecond-level difference in propagation delay between pins. You can use the P_SYNC_IO mode to reduce the difference, but now everything is delayed by a full clock cycle.
  • ErNaErNa Posts: 1,851
    edited 2026-02-13 22:50
    Main:
            mov      dirA,      dirA_Sel              ' sets direction of portB pins
    Subroutine
    Transition  'Start Transition
            mov      OutBits,   PattCurr          ' output pattern
            and      OutBits,   dirA_sel           ' isolate relevant bits
            mov      outA,      OutBits
            mov      TimeCT3,   TimeCT2
    Transition_ret ret           ' return from subroutine
    I output bit 0..7, dirA_sel masks the relevant bits
    The timer is redundant
    I do not use (to my knowledge) any smart-pin function for this I/O,
    but have some ADC and a DAC running.
    Where can I find info related to P_SYNC_IO?
  • Hmm, that code looks alright - are you sure you are measuring it right? Or am I mis-reading the scope claiming a 70us view duration?
    P_SYNC_IO (also known as "registered I/O") is a flag you set with WRPIN. This just adds an extra latch into the signal chain, very close to the actual output drivers.
    You would e.g. wrpin ##P_SYNC_IO,#0 addpins 7 to enable it for pins 0 through 7
  • evanhevanh Posts: 17,133
    The code snippets are both incomplete. The first snippet should exist in the second snippet but doesn't. Also, values are not listed, only symbols.
    The next time, I intend to expose my stupidity, I'll impose tariffs! At least, I know how to attach a scope, I'll now exercise to attach it to the right pins....
    Regarding P_SYNC_IO, you'll find all those symbols at the end of Chip's "Spin 2 Language Documentation" - https://www.parallax.com/propeller-2/documentation/
