Pointer to structure not recognised in parent code? — Parallax Forums
I'm writing a buffer based driver for the HDaudio add-in kit. But I'm having trouble with pointers to structures. I bet it's a simple nooby's mistake. In the driver I have the following code:-
    sigbuff mic1
    sigbuff mic2
    sigbuff linein1
    sigbuff linein2
    sigbuff lineout1
    sigbuff lineout2
    ^sigbuff micbuff
    ^sigbuff lineinbuff
    ^sigbuff lineoutbuff
    ^long micsample
    ^long lineinsample
    ^long lineoutsample
pri changebuffers()
  if buffercycle <> false
            buffercycle := false
              [micbuff] := @mic1
            [micsample] := @mic2
           [lineinbuff] := @linein1
        [lineinsample]  := @linein2
          [lineoutbuff] := @lineout1
        [lineoutsample] := @lineout2
  else
            buffercycle := true
              [micbuff] := @mic2
            [micsample] := @mic1
           [lineinbuff] := @linein2
        [lineinsample]  := @linein1
          [lineoutbuff] := @lineout2
        [lineoutsample] := @lineout1
  cogatn(buffchangealert)             ' send ATN to all cogs runnning dsp to signal it's time to start a fresh cycle
                                      ' at 48 ksample/s that cycle time is 21.333 mS - to do all dsp
There are two buffer sets. So every time an input buffer becomes full of samples from the a/d, the buffer set is swapped over in method changebuffers. e.g. pointer micbuff either points to mic1 or mic2 buffer etc.
If I write in the library, the statement 'lineoutbuff := micbuff' the compiler seems to accept that.
However, in the parent file that instantiates the library as 'sigpump': If I write 'sigpump.lineoutbuff := sigpump.micbuff' , the compiler complains 'Expected an object constant, structure or method'
What needs changing so that latter statement is also accepted?
Hope I've shown enough for someone to spot the mistook. I can post the whole project if need be.
Cheers, Bob
  • bob_g4bbybob_g4bby Posts: 522
    edited 2026-01-26 15:01
    Is it simply the case that no variable declared in a library can be accessed directly from the main program, but can only be read and written via suitable get/set methods?
    Maybe not - Is it the case that a variable declared in a library can be used globally throughout a program unless declared 'static', in which case the variable's scope is limited to the file it's defined in.
  • With FlexSpin at least, I think if you want to use a pub/pri local instance of a structure that's defined in a child object file, you have to first use a syntax like:
    obj
        child: "child.spin2"
    con
        struct lineoutbuff = child.lineoutbuff
    Then you can use it as if it were defined in the current file. It does seem to be accepted without that if you declare it in a VAR block like:
    obj
    var
        child.lineoutbuff some_other_name
    Although it seems like it won't accept it if the instance is named the same as the structure definition name (IOW, it doesn't seem to like: var child.lineoutbuff lineoutbuff)
    error: syntax error, unexpected STRUCTURE NAME, expecting identifier or RESULT or SP_ANNOTATION
    Cheers
