Pointer to structure not recognised in parent code? — Parallax Forums
I'm writing a buffer based driver for the HDaudio add-in kit. But I'm having trouble with pointers to structures. I bet it's a simple nooby's mistake. In the driver I have the following code:-
    sigbuff mic1
    sigbuff mic2
    sigbuff linein1
    sigbuff linein2
    sigbuff lineout1
    sigbuff lineout2
    ^sigbuff micbuff
    ^sigbuff lineinbuff
    ^sigbuff lineoutbuff
    ^long micsample
    ^long lineinsample
    ^long lineoutsample
pri changebuffers()
  if buffercycle <> false
            buffercycle := false
              [micbuff] := @mic1
            [micsample] := @mic2
           [lineinbuff] := @linein1
        [lineinsample]  := @linein2
          [lineoutbuff] := @lineout1
        [lineoutsample] := @lineout2
  else
            buffercycle := true
              [micbuff] := @mic2
            [micsample] := @mic1
           [lineinbuff] := @linein2
        [lineinsample]  := @linein1
          [lineoutbuff] := @lineout2
        [lineoutsample] := @lineout1
  cogatn(buffchangealert)             ' send ATN to all cogs runnning dsp to signal it's time to start a fresh cycle
                                      ' at 48 ksample/s that cycle time is 21.333 mS - to do all dsp
There are two buffer sets. So every time an input buffer becomes full of samples from the a/d, the buffer set is swapped over in method changebuffers. e.g. pointer micbuff either points to mic1 or mic2 buffer etc.
If I write in the library, the statement 'lineoutbuff := micbuff' the compiler seems to accept that.
However, in the parent file that instantiates the library as 'sigpump': If I write 'sigpump.lineoutbuff := sigpump.micbuff' , the compiler complains 'Expected an object constant, structure or method'
What needs changing so that latter statement is also accepted?
Hope I've shown enough for someone to spot the mistook. I can post the whole project if need be.
Cheers, Bob
    edited 2026-01-26 15:01
    Is it simply the case that no variable declared in a library can be accessed directly from the main program, but can only be read and written via suitable get/set methods?
    Maybe not - Is it the case that a variable declared in a library can be used globally throughout a program unless declared 'static', in which case the variable's scope is limited to the file it's defined in.
  • With FlexSpin at least, I think if you want to use a pub/pri local instance of a structure that's defined in a child object file, you have to first use a syntax like:
    obj
        child: "child.spin2"
    con
        struct lineoutbuff = child.lineoutbuff
    Then you can use it as if it were defined in the current file. It does seem to be accepted without that if you declare it in a VAR block like:
    obj
    var
        child.lineoutbuff some_other_name
    Although it seems like it won't accept it if the instance is named the same as the structure definition name (IOW, it doesn't seem to like: var child.lineoutbuff lineoutbuff)
    error: syntax error, unexpected STRUCTURE NAME, expecting identifier or RESULT or SP_ANNOTATION
    Cheers
  • @avsa242 , I haven't got your suggestion to work. Here's a simple top level program with the compile fault in main:-
    '' File .......... toplevel.spin2
    '' Version........ 1
    '' Purpose........ test scope of variables defined in library
    '' Author......... Bob Edwards
    '' Email.......... bob.edwards50@yahoo.com
    '' Started........ 26/1/2026
    '' Latest update.. / /
    {Spin2_v50}
    CON {timing constants}
            _xinfreq =  20_000_000
            _clkfreq = 180_000_000
    CON {fixed IO pins}
    CON {application IO pins}
    CON {Enumerated constants}
    CON {Data Structure definitions}
        struct mic1 = lib.mic1
        struct lineout1 = lib.lineout1
    CON { global constants }
    OBJ {Child Objects}
    lib : "library"
    VAR {Variable Declarations}
    {Public / Private methods}
    pub main()
        lineout1 := mic1
    Here's the library that toplevel uses:-
    '' File .......... library.spin2
    '' Purpose........ test of scope of variable defined here
    CON {fixed IO pins}
    CON {global constants}
        sigbuffsize = 1024                                  ' size of the iq signal buffers
        STRUCT sample(real, imag)                           ' one signal sample
        STRUCT sigbuff( sample iqsample [sigbuffsize] )     ' array of samples
    OBJ {Child Objects}
        sigbuff mic1
        sigbuff lineout1
    pub main()
  • maccamacca Posts: 1,079
    VARs in child objects can't be accessed from parent objects directly, you need a getter method to get the pointer to the variable.
    That syntax in CON section is meant to "copy" the structure definition from a child object, but since mic1 and lineout1 are variables it can't work (maybe if it was in a VAR section but AFAIK that is not allowed).
    It works with struct sigbuff = lib.sigbuff then you can use sigbuff to define structure variables in the parent.
    If you add getter methods to library, like:
    pub get_mic1() : r
        return @mic1
    pub get_lineout1() : r
        return @lineout1
    Then you can write something like this in toplevel:
    pub main() | ^sigbuff mic1, ^sigbuff lineout1
        [mic1] := lib.get_mic1()
        [lineout1] := lib.get_lineout1()
    And use the variables like any other struct.
    Hope this helps.
  • Thanks @macca , I'd come to that conclusion this afternoon, based on oop principles, where local variables of an object cannot be read/written by all and sundry. Your code is slightly tidier than mine. Time to get on with making some noises with the HDaudio kit. Thanks again, bob
  • Whoops sorry, I misread your first post - I thought originally you were trying to use structure definitions (not the actual instances) from the child object.
