P2 - HDMI and Waveshare 5" display — Parallax Forums
Hi,
I have a 5" round waveshare hdmi display and I have the P2 running the the spiral hdmi demo, it works on a normal hdmi display but doesn't work on the waveshare. I know the display works as i plugged it into RPI. Any thoughts on why the waveshare won't display it?
  • Possible issues:
    • Display does not like the pin drive mode used (try replacing the line that says wrpin ##%001001<<8,#7<<6 + hdmi_base 'set 1k-ohm drive on HDMI pins with wrpin ##P_REPOSITORY|P_OE|P_LOW_FAST|P_HIGH_1K5|P_SYNC_IO, #hdmi_base addpins 7
    • Specialty display wants special resolutions (try this on a PC or something - does it actually take 640x480 modes?)
    • Some sort of exciting protocol incompatibility (not sure if chip's example is 100% spec compliant)
  • RaymanRayman Posts: 15,930
    What is display resolution?
    Looks like might be 800x480…
    That might require code tweaks
    Also it might be the 5v signal. Some displays seem to need it. The parallax adapter needs a jumper wire added to provide that…
  • Oh the 5V pin, that's the No. 1 thing to check actually. Some sinks will not turn on without that. Simple electrical fix.
    Here's an example of the jumper wire... Could also be a resistor instead of a jumper, like 1k or so...
    480 x 640 - 213K
  • Brian_BBrian_B Posts: 844
    edited 2026-01-01 18:04
    1080x1080 , but after i tried It with the 5 volt jumper wire it won't even work on the RPI.
  • VonSzarvasVonSzarvas Posts: 3,623
    edited 2026-01-01 18:34
    The newer rev of the hdmi addon has pads labelled near the hdmi socket for adding a 1k resistor or jumper/shunt.
    BUT… first be sure that your breakout board is outputting 5V at the accessory headers.
    That usually means the breakout is powered by 5V (and not a higher voltage). And also that the breakout board has the 5V outputs enabled.
    To verify, measure the 5V output pin on the breakout board header before attaching the addon.
    edited 2026-01-01 19:45
    P2 can't drive 1080x1080 HDMI display directly. 800x480 is close to the max.
