Universal motor driver need input
Hello. I have the new Universal motor driver 64010 Rev B. I have looked over the UniversalMotorDriver P2 add on guide-V.1.1. I am trying to get it running. I have used the HB-25 motor control and I love it. But as soon as I find something I like it is no longer available. I wright simple code for the HB-25 and it works like fantastic. Is the Universal motor driver 64010 Rev B anything like the HB-25???? Where do I input the PWM to what pin??? There are 15 input pins with no pins. Could someone take me by the hand and show me where the pins are to input the PWM (plus with modulation). I have already found the ground pin. Can I use the same code that I use to run the HB-25 on the Propeller 1 (one)?? Is there a demonstration video some where out there??? Or some other paper work that I do not know about?? Thank you very much for any help in this matter. 18nov2025(tue)
Have you seen the product page?
https://www.parallax.com/package/universal-motor-driver-p2-add-on-board-documentation/
This unit is nothing like the HB-25. It can drive BLDC type motors as well as standard motors.
I assume you have the original Motor Mount and Wheel Kit.
Someone should have built code to run those motors.
Hello and thank you for your input. Mr. Rayman I have the documentation that you listed and I have been trying to make heads and tales of it but the going is slow. Mr. iseries your input tells me that I must try a different direction. It took me 3 months to get the HB-25 going and this may take longer. I thank both of you for your time. 20nov 2025(thur)
Hello . Still need input for the Universal motor driver. The blue print with the pin output it is not a mach for what is on the circuit board. The blue print for the connections do not show the pin out for the integrated circuit. What pin do I hook up the pulse with modulation input to is it pin 1 through 15??? I am trying to down load a pitcher but no can find the paper clip for attachments
I tried to drag and drop a pitcher and all this stuff came up?
@"Ken Gracey"
Perhaps Parallax might want to put together a tutorial, how to connect a pair of brushed motors to P2 via this board?
Maybe you already have, but in case you haven't... Have you reviewed the driver repo for the driver that Chip and I put together for the board?
See BLDC Motor Driver repository
Stephen, have you had a look at the hb-25 driver, that he wants to replace. It is for brushed motors!!!
@Iguanaman
Have you seen this example with DC motors: https://www.parallax.com/arlo-conversion-to-p2-with-the-universal-motor-controller/
Although it uses Arlo motors, they are simple DC motors, and the wiring and code example could provide the clues you are searching for ?
You might ignore the encoder wiring- those are not needed to drive motors.
Having a quick look, the demo as shown wires the two DC motors so they use all four motor channels. That allows the motors to be controlled forwards or backwards.
If you only needed a single rotation direction, and if you wanted to connect up to four DC motors, then could could wire your motor +ve cables all direct to your battery, and connect the motor -ve/GND cables to each of the Universal Motor Driver channels (U,V,W,X). Thus you'd set the motor output low to turn the motor on, and high to stop the motor. (By "set the motor output low", I mean, enable the corresponding PWM signal; ie. PWM_UL to set the U output low (the code example in the above linked demo has the detail on this).
Well, you are right, I had not understood the difference...
Using this to drive Parallax motors.
Hooked up just like in this image from product page and works...
Haven't wired up encoders yet though...
Here's some code that was used. Might not be latest, but should demonstrate how to use the driver...
Ha! I'd forgotten about that helper diagram; feels like many moons ago I did that!
Big thanks for bringing it up ; it shows perfectly how I had the Arlo wired in the above linked demo & code in a much better way than words could manage!
Hopefully that's going to help Iguanaman figure out a working solution. Curious to see what gets created.
Hello. Thank you for all your inputs. Rayman in your pitcher #11 what is the device in between the microcontroles and the universal motor driver??? Are the two black rectangle things with twelve square holes in each ( total 24 little square holes ) the input for the pulse with modulation. I do not want to buy the in between device to make it work. If so what Square holes do I input the pulse with modulation into. The blue print do not show the pin out on any integrated circuit on the universal motor driver. Stephen Moraco I went to your sight ( BLDC motor driver repository ) I clicked on a few things and can not get it to work? If I do not know where to hook the wires into the the universal motor driver then the driver is no good to me. I do not want to guess and burn something out at 80 dollars a pop for one driver. Thank you for your time 11dec2025(thur)
Hi, I am not native speaking English, so I am not sure what it means, when you write "pitcher".
The information you are probably looking for is hidden in the schematic:
"IO+3" means that depending from the start pin number there is an offset of 3, if you plug this board into one of the connectors of the parallax P2 adapter. The choice of connector defines the absolute pin number.
What exact type of motor do you use?
I would make some trials with a very small motor and a weak power supply. I have a laboratory power supply where I can limit the current. But some small batteries might be useful too.
In some accents ‘pitcher’ and ‘picture’ sound the same, though they have different meanings (OP means ‘picture’). Similarly, ‘sight’ and ‘site’ sound the same, but have different meanings (OP means ‘site’)
He might not have any Prop2 board. ie: He only has the Universal Motor Driver add-on board.
Thank you! I had guessed, that "picture" might be meant. The difficult part is reading between lines, what someone might be saying, if he is using 'pitcher'.
Hello. I an using the Propeller one ( 1 ). I have used only 30 percent of the Propeller one capability's. Still learning the spin language and it is the only language I know. If you look at Christof Ed post # 15 the top pitcher pin out starts at pins 1 - 12 on the blue print. The bottom pitcher has the same number 1 - 12 . The universal motor driver pitcher shows the pin out the top pin 15 - 8 and the bottom pins as 7 - 0??? The universal motor driver blue print douse not mach the pins on the driver board it self. 18dec2025(thur)
Hi,
The problem is, that you do not know for sure, which connector is j100 and which is j102?
I would measure resistance to the hall connector to find out for Hall_V.
There is also a picture in the product guide side by side.
You are aware that the new motor driver needs completely different signals from the Microcontroller than the old one?
H @Iguanaman
I meant that picture:
Does this help to answer your question?
This board was built to drive BLDC motors directly and is not like the HP-25 that drove the motors for you.
You're going to have to do everything that the HP-25 did by hand. This board will not do anything that the HP-25 did.
On the picture above there are 8 pins labeled XH/XL, WH/WL, VH/VL, UH/UL. These pins control the output voltage on X, W, V, and U.
You will also need to supply 3.3v and GND to power the board.
On the other side you have VDC and GND. This is what will power the motors.
On the P1 side you will have to pick 8 pins that you will set low and plug them into XH/XL, WH/WL, VH/VL, UH/UL.
To drive one motor, you would pull the pin attached to XH high and WL high. This will apply VDC to X and GND to W causing the motor to turn uncontrollably. If you apply a pulse (PWM) to XH you can control the speed of the motor. You could also apply a pulse to WL instead of XH.
Do not make any of the H and L pins high at the same time as the output cannot be both VDC and GND at the same time.
Now to make the motor turn the other way you need to make XL high and WH high and XH would be low as well as WL.
The motor encoders will also have to be done by hand attached to 8 input pins on the P1.
In total you will need 16 pins to make this work.
