How to convert this duty to P1 — Parallax Forums
T ChapT Chap Posts: 4,260
edited 2025-12-05 01:37 in General Discussion
I want to see if there is a way to convert this to P1 so I can get a value ie 20% as the small one looks or 95% on the big one. Any ideas ?
  • T ChapT Chap Posts: 4,260
    edited 2025-12-05 03:19
    Better said, I want to see if I can send this signal direct to the propeller and convert it to a value 0-100. Counter?
    throttlePin  = 0  ' whatever pin you wire it to
    PUB MeasureDuty : dutyPercent
      dira[throttlePin]~        ' input
      ' Wait for a clean rising edge
      waitpne( |< throttlePin, |< throttlePin )  ' wait until low
      waitpeq( |< throttlePin, |< throttlePin )  ' wait until high
      t0 := cnt                   ' start of period
      waitpne( |< throttlePin, |< throttlePin )  ' wait for falling edge
      tHigh := cnt - t0
      waitpeq( |< throttlePin, |< throttlePin )  ' wait for next rising edge
      tPeriod := cnt - t0
      dutyPercent := (tHigh * 100) / tPeriod
  • The recipe for fixed frequency PWM on the P1 is pretty easy, but it does require a cog. I've used the attached strategy to drive motors and LEDs and other devices that need fixed-frequency PWM.
    Here's the outputs captured on my LA; frequency is set to 24kHz with ch0 set to 20% and ch1 to 95%.
  • Thanks Jon, I’m sure I may have not been clear. I’m trying to connect something to the propeller that is outputting that signal on the scope so that I can read it into the propeller and convert it into a value inside the propeller.
  • JonnyMacJonnyMac Posts: 9,742
    edited 2025-12-05 19:24
    Sorry, I misunderstood. No problem, there is a counter mode that can be used -- let me look it up.
    A few minutes later....
    Found it. I created a dual pwm-read object for a TV prop that was controlled via wireless DMX receiver; my object could read the PWM signal from the receiver and convert it to a value between 0..255. For this demo I added a conversion in the main code to get 0..100. The reader object should work -- if not, it will give you direction in how to use the counters to measure pulses.
  • Awesome! I will hook this up tomorrow and test it out thanks a bunch for posting this.
  • My demo uses the pwm output from the first code I posted -- just disable that and connect your external signal to one of your PWM input pins.
