Lego compatible servo can drive wheels from a Stamp — Parallax Forums
Buck RogersBuck Rogers Posts: 2,216
edited 2026-02-06 04:17 in BASIC Stamp
Hello!
Okay I built this thing out of Lego and one of the brown dog's servos.
I am adapting this code:
' RotateParallaxCrServo.bs2
' {$STAMP BS2}
' {$PBASIC 2.5}
counter VAR Word
servoPin PIN 15             ' change I/O pin for servo signal here
 Fward:
FOR counter = 1 TO 100      ' Rotate counterclockwise for ~3 seconds
  PULSOUT servoPin, 850
  PAUSE 20
NEXT
FOR counter = 1 TO 100      ' Hold still for ~3 seconds
  PULSOUT servoPin, 900
  PAUSE 20
NEXT
 FOR counter = 1 TO 100      ' Rotate clockwise for ~3 seconds
  PAUSE 20
NEXT
GOTO Fward
So of course it runs but, ah, I'm not completely sure of what the servo is doing when running. Incidentally that thing is one of two from this discussion:
https://tinyurl.com/46p4dzpr
It is certainly a starter.
Oh and the mascots are watching it run.
  • If you look in the boe-bot manual there is plenty servo code to play with. You can download the manual for free.
    Also true and you win the prize for responding, however I don't know how much a big bucket of bantha milk will be to you.
    However my aim in buying them was first to replicate the boe-bot in Lego and use those servos for that purpose. The problem was first in finding wheels that fit the servos. I've completed that step. The wheel shown in that photo does in fact fit the axle of the servo. Originally Adafruit sold a small robotic base in circular format and declared how to drive the motors included in the kit. One method was the Feather platform that they sell, another was the Pi, both included various types of H-driver for the motors of course. Our discussion here concluded that there was no room on the platform for the full sized CR ones sold here and a matching BASIC stamp design. I've now come to conclusion that it is possible to drive these CR servos that way and apply them appropriately. And they are https://tinyurl.com/crservoorange
    My next venture will be to construct platform that does approximately what that platform did, but around these two.
    A mascot is watching.
  • ServoPAL (#28824): Servo Pulser and Timer
    General Description
    The ServoPAL is a tiny module that plugs in between your BASIC Stamp and two servo motors to pulse
    the motors so your PBASIC program doesn’t have to. In addition, it provides an “alarm clock” function to
    perform timing in the background while the BASIC Stamp is busy with other tasks.
    General Description
    Hello!
    You are quite sure of that catalog gem? Because the website is avoiding it. I believe I did see it described in an earlier version of the site, but not recently. But will keep looking.
    Sleeping mascots stay sleeping.
  • Buck RogersBuck Rogers Posts: 2,216
    edited 2026-02-06 04:20
    Hello!
    Next up. I built up out of Leg and Lego designed wheels, and one CR servo from Brown Dog a platform which uses a BOE and a battery box for the 9V power source.
    Of course it is only a single servo but it works after a fashion. The code is the same as before.
