New SD mode P2 accessory board - Page 36 — Parallax Forums
1303132333436»
  • RaymanRayman Posts: 15,923
    Did get it going though. Just have to change the RL basepin at the top and then comment/uncomment the correct lines here for sdsd mode:
    //static struct __using("blkdrvr/sdmm.cc") DRV;    // compiles to 54804 bytes
    //static struct __using("blkdrvr/sdmm_bashed.cc") DRV;    // compiles to 56904 bytes (w/retries)
    static struct __using("blkdrvr/sdsd.cc") DRV;    // compiles to 60596 bytes
    static FILE * mountsd( void )
        FILE *handle;
        int  rc, clkdiv;
        uint32_t  part;
        umount("/sd");
        _seterror(0);
    //    handle = _sdmm_open(CLK_RL, CS_RL, MOSI_RL, MISO_RL);
    //    handle = _sdmm_open(CLK_EVAL, CS_EVAL, MOSI_EVAL, MISO_EVAL);
    //    handle = DRV._sdmm_open(CLK_RL, CS_RL, MOSI_RL, MISO_RL);
    //    handle = DRV._sdmm_open(CLK_EH, CS_EH, MOSI_EH, MISO_EH);
    //    handle = DRV._sdmm_open(CLK_EVAL, CS_EVAL, MOSI_EVAL, MISO_EVAL);
        handle = DRV._sdsd_open(CLK_RL, CMD_RL, DAT0_RL, PWR_RL, LED_RL);
    //    handle = DRV._sdsd_open(CLK_EH, CMD_EH, DAT0_EH, -1, -1);
    Guess this new way of just adding a new folder is easier than old way. Just have to find the install instructions...
  • evanhevanh Posts: 17,032
    edited 2025-11-11 21:05
    Yeah, I decided it's best to have the example tester programs use the boot pins and built-in driver by default so then can see it working before testing new hardware.
    Looks like you've found all the settings. :)
    Driver doesn't have to be in a subdirectory. That was mainly because of multiple drivers.
    The struct __using() and _sdsd_open() is the install instructions.
    PS: You're welcome to work from the Spin2 edition of the tester. There's an updated version with ioctl() added - https://forums.parallax.com/discussion/comment/1569697/#Comment_1569697
    Instructions are missing in the latest version zip…
    edited 2025-11-11 23:39
    The example source code is the instructions. It's just struct __using() and _sdsd_open(). The rest is normal C file ops, including the use of ioctl().
    Or did you just mean the v1.12 zip I posted back a few posts doesn't have the example tester sources included?
  • roglohrogloh Posts: 6,211
    edited 2025-11-12 00:17
    @evanh it might be handy to include a small readme.txt file in your zip archive stating a few things to help new users out (you might feel this is redundant if you look at that code but for new users it's important to know what to do to get started).
    For example to make use of the API in your own code it's not yet built into the tools, so you'll need to create a subfolder under your own application folder called "blkdrvr" and copy the low lever driver files there. Then you can make use of the API from C (or SPIN2) in flexspin that gets used by the demo. Given it's all C based you could mention how to enable the C API calls from SPIN2 via including the libc.a and mmdrv objects, as some SPIN2 users may not yet know about much of that.
    Also that you may need to customize the pins (and where you'd modify them). Plus mention any IO restrictions like having the 4 bit DAT pins start on 4 bit pin boundary (although I do see that is listed in the source code), and the difference between the 3 driver file variants in how they operate.
    A brief description of the functionality and any IOCTL options available, maybe a short list of the basic APIs and one line description of what it does would be good too even if this is taken from the source.
    It's just far nicer for new users to have something to initially start from rather than have to reverse engineer all from the raw code directly, as it will give people more confidence than starting out blind so to speak.
    Think the 1.0 has a helpful doc that 1.2 does not..
    edited 2025-11-12 02:40
    Oh, that tiny .txt in the driver directory, it was a cut'n'paste from Eric's original plugin code for the built-in driver. And I'm not even using that arrangement in the example testers. I've forgotten why Eric did that arrangement, there was some small reason.
    The Spin2 example is the best one to read if you're not C familiar already. It shows using the specific objects in Spin2. It'll align better with Basic I suspect also.
    In the end though, learning libc is kind of a prerequisite since you're going to be using all the file access functionality from it at the very least. Then using stuff like printf() becomes a no-brainer.
    edited 2025-11-12 07:02
    @rogloh said:
    It's just far nicer for new users to have something to initially start from rather than have to reverse engineer all from the raw code directly, ...
    That's the main reason I have a driver subdirectory. So then the demo speed tester programs are the only sources present at first glance. Any driver otherwise can be right alongside the top level source.
    Rayman,
    Fire off specific questions in here about the Spin2 speed tester and I'll put more comments in the source code so that people reading it in the future will find it easier.
    Roger,
    I'll make a quick txt document listing the driver's settings and include the Obex description - which itself links to your excellent schematic for wiring up a suitable SD card slot in the opening post of this topic.
    First run at the readme.
    The other text file has good usage notes…
    Make a folder under flexprop and copy the three files there…
    The "adding a driver ..." text file has no usage at all. It has an incomplete init/mount routine.
    @evanh said:
    Roger,
    Cool. It's a good way to help describe what this is for new users. I noticed a few typos/grammar errors (is/are) are still in there to clean up when you read closely through it. Although who am I to judge that with all of my later post tidy ups that I end up doing. LOL.
    By the way the schematic shown here is what I used recently for FireAnt which probably includes a better p-FET for power on/off control vs the original one.
    https://forums.parallax.com/discussion/comment/1570122/#Comment_1570122
    A tomorrow job. I'm always fixing dyslexic and grammar and general readability. Most forum posts are re-edited just for this.
    The original is tidier but I'll add this one too.
    Now recovered from a cold of some sort, very chesty. I haven't done much of anything in the last week, watched a bit of telly was my limit.
    Updated and added a few markdown's. You'll need to rename it to readme.md since the the forum software doesn't accept .md as a suffix.
    edited 2025-11-22 08:00
    PS: I've changed the ioctl() features. Reduced it to just two user control numbers, the same two (70 and 72) as used in the demo speed testers. So the demos don't need altered. The other two aren't functionally gone as such, they're just combined with the remaining two. Now, instead of separately getting and setting a value, it returns the prior value while also setting the new value.
    Latest edit:
    Hehe, first success playing with __pasm {} code sections. Converted just the data block read routine - Performance sucks! Which I'm going to put down to my blind fast copy firing on every call. Presumably Flexspin's Fcache is smarter than that.
     Buffer = 2 kB,  Written 512 kB at 13617 kB/s,  Verified,  Read 512 kB at 774 kB/s
     Buffer = 2 kB,  Written 512 kB at 13607 kB/s,  Verified,  Read 512 kB at 774 kB/s
     Buffer = 2 kB,  Written 512 kB at 13609 kB/s,  Verified,  Read 512 kB at 774 kB/s
     Buffer = 8 kB,  Written 2048 kB at 18108 kB/s,  Verified,  Read 2048 kB at 2807 kB/s
     Buffer = 8 kB,  Written 2048 kB at 17733 kB/s,  Verified,  Read 2048 kB at 2807 kB/s
     Buffer = 8 kB,  Written 2048 kB at 18129 kB/s,  Verified,  Read 2048 kB at 2807 kB/s
     Buffer = 32 kB,  Written 4096 kB at 18312 kB/s,  Verified,  Read 4096 kB at 8095 kB/s
     Buffer = 32 kB,  Written 4096 kB at 18299 kB/s,  Verified,  Read 4096 kB at 8094 kB/s
     Buffer = 32 kB,  Written 4096 kB at 18102 kB/s,  Verified,  Read 4096 kB at 8094 kB/s
    Compared to:
     Buffer = 2 kB,  Written 512 kB at 15457 kB/s,  Verified,  Read 512 kB at 16113 kB/s
     Buffer = 2 kB,  Written 512 kB at 15460 kB/s,  Verified,  Read 512 kB at 16111 kB/s
     Buffer = 2 kB,  Written 512 kB at 15452 kB/s,  Verified,  Read 512 kB at 16111 kB/s
     Buffer = 8 kB,  Written 2048 kB at 18834 kB/s,  Verified,  Read 2048 kB at 20529 kB/s
     Buffer = 8 kB,  Written 2048 kB at 18832 kB/s,  Verified,  Read 2048 kB at 20529 kB/s
     Buffer = 8 kB,  Written 2048 kB at 18812 kB/s,  Verified,  Read 2048 kB at 20529 kB/s
     Buffer = 32 kB,  Written 4096 kB at 19234 kB/s,  Verified,  Read 4096 kB at 21925 kB/s
     Buffer = 32 kB,  Written 4096 kB at 19002 kB/s,  Verified,  Read 4096 kB at 21948 kB/s
     Buffer = 32 kB,  Written 4096 kB at 19158 kB/s,  Verified,  Read 4096 kB at 21941 kB/s
    No, it really isn't.
    Big issue with that idea I see is that you can no longer instantiate 2 drives at the same time. (The pasm blocks are equivalent to DAT blocks in Spin, you only get one instance for a class)
    edited 2025-12-11 00:52
    Hmm, yeah, that one did slip. Funnily it's the presets that I'm trying to merge with the code that'll be where this problem comes up.
    Not pursuable at any angle now. :( Oh well.
