When using Catalina's version of Geany, using Cake as the C preprocessor produces messy error and warning messages. This is because Cake uses ANSI escape codes to set the message color - which works in a command-line or terminal window, but not in Geany's compiler output window.
It is not very intuitive, but you can disable Cake's use of color by adding -W-Wp-fdiagnostics-format=msvc to the Catalina command line (see note below as to what this means) - and the easiest way to do that in Geany is using the Project Properties dialog box.
For example, to enable the use of Cake but also disable Cake's use of color, you might add the following line to the Catalina Options:
-C99 -W-Wp-fdiagnostics-format=msvc
In the next release I will make disabling color the default, and instead add an option to enable the use of color.
There is also a very minor tweak to Cake's error message formatting that I have pushed to GitHub.
Ross
A note about -W-Wp-fdiagnostics-format=msvc : the first -W tells Catalina to pass the rest of the option to LCC . Then the -Wp tells LCC to pass the rest of the option to the preprocessor (i.e. Cake). Then the -fpdiagnostics-format=msvc tells Cake to use Microsoft format for messages, which (in this version of Cake) is the only format that disables the use of color. I have asked the Cake author to make enabling/disabling color an independent option, which will make things simpler in the next version!
@RossH said:
... But someone else is welcome to do so, since it involves rewriting just a single and entirely self-contained plugin which is just a few hundred lines of PASM (see target/p2/cogsd.t - ignore the clock support which is implemented in the same cog just because there is spare space).
Oh, I see, ignore the RTC functions. And these forum outages are getting annoying too. I come back to check on a posting and, bam, an error page is all I get.
Well, I've hacked at that file a bit and got results. Albeit nowhere near where it should be as yet. Doubled the bit rate (For 300 MHz sysclock) of the low level R/W bit-bashed routine - Now locked at sysclock/12 clock divider, producing a few percent gain on reads and nothing at all on writes. Then took a look at the block write routine to find an unexpected 10 ms WAITX instruction with a comment asking why its needed ... wiped that out and all its related conditions, nearly halving the code size of that routine. Result is sequential writes are now 5x faster: 50 kB/s.
Can't see any quick improvements for block reads though. I can see the driver runs in its own cog so I guess a block of prefetching will help but I'd like to see what can be done about enhancing the mailbox features first. There is no multi-block request! A multi-block request would remove large amounts of mailbox handshake. The block read duration is currently at 350 us but each has a 1.4 ms gap of inactivity from completion of prior block to request for a contiguous block!
What file do I look at to mangle the mailbox interface as I see fit?
While the forums are up (and who knows how long they will stay!), I'm posting this same message in a couple of threads:
I will no longer be monitoring these forums until Parallax gets it sh*t together. If anyone needs Catalina support, my email address is in the Catalina documentation. Email me direct for support.
That 10ms delay was required to support some SD cards. I never could figure out why it was needed, or exactly what value it should be, so I just settled for 10ms which worked with all the cards I tested. Removing or reducing it might work with some cards but not others. There seems no way to tell whether or not it is actually required. However, I could make it a compile-time option.
There is no multi-block support in DOSFS. It was specifically designed to minimize its RAM footprint, so (for example) it only ever use a single sector buffer. This is what made it suitable for the Propeller 1, where Hub RAM is at a premium - but on the Propeller 2 it is indeed a bit of a bottleneck. However, having a different file system on the Propeller 1 and Propeller 2 is also not a very good option.
You can add new services easily enough, but you can't modify the mailbox interface itself - the Registry (which is what Catalina calls it) underpins too many aspects of Catalina's functionality, and if you change it the amount of rework required would be huge. If you find the Registry is not suitable, use it to establish a shared memory buffer on startup and then use that as your interface instead. However, you make a good point - I retired the document that described Catalina's Registry in detail some time ago and never replaced it. I will add more detail on the Registry to the Catalina reference manual.
I've not seen fixed delays in other drivers. They just require a card busy/ready check at the right points ... and Catalina's driver looks to be doing those checks already. I didn't try to evaluate it too hard though.
On a related note, the low level bit-bashing is a lot cleaner the way I've got now without the extraneous extra clocks. It is possible that SPI mode could get sensitive to mismatched byte lengths during a transaction the way it was. The spec talks about SPI mode working in exact bytes.
EDIT: Err, the original code doesn't actually do that. It just looks slightly odd with the terminating OUTL #_SD_CK is all.
What might be of significance though is the version notes says:
Version 4.0 - Added 8 extra clocks after each operation. Added a new "ready" check before each operation.
The 10 ms block write delay was likely compensating for the missing ready check. With that fixed I doubt you'll find any cards that require the 10 ms any longer.
-C99 -W-Wp-fdiagnostics-format=msvcIn the next release I will make disabling color the default, and instead add an option to enable the use of color.
Ross
Here's the main edits so far:
'+-----------------------------------------------------------------------------+ '+ SD SPI Send/Recv Routines... (write/read byte/long simultaneously) + '+ Bit-bashed at sysclock/12 clock divider, ignoring any SD spec + '+-----------------------------------------------------------------------------+ _recvlong neg dataout, #1 ' call here to Recv a Long (+send 1's) _sendlong mov bitscnt, #31 ' call here to Send a Long (long=32bits) jmp #_sendrecv _sendFF ' call here to Send $FF Byte _recvbyte neg dataout, #1 ' call here to Recv a Byte (+send 1's) _sendbyte rol dataout, #24 ' call here to Send a Byte (msbit first) mov bitscnt, #7 ' (byte=8bits) _sendrecv rol dataout, #1 wc ' prepare output bit (DI=0/1).. outl #_SD_CK ' CLK=0 outc #_SD_DI ' write output bit: output on CLK falling edge mov reply, #0 ' clear reply outh #_SD_CK ' CLK=1 rep @.rend, bitscnt rol dataout, #1 wc ' prepare output bit (DI=0/1).. outl #_SD_CK ' CLK=0 outc #_SD_DI ' write output bit: output on CLK falling edge testp #_SD_DO wc ' read input bit: SD Standard Speed output on CLK falling edge outh #_SD_CK ' CLK=1 rcl reply, #1 ' accum DO input bits .rend waitx #2 ' safe lag timing of 16 ticks from CLK falling to IN sampling outh #_SD_DI ' idle high testp #_SD_DO wc ' read input bit: SD Standard Speed output on CLK falling edge _RET_ rcl reply, #1 ' accum DO input bits'+-----------------------------------------------------------------------------+ '+ Write Block/Sector: (512 bytes) + '+ CMD24, PAR=blocknr + '+-----------------------------------------------------------------------------+ _writeBLOCK ' CMD24: PAR=sector, 512 bytes getct ini_time '\ set timeout for cmd24 mov time_out, ##delay2s '/ '+-----------------------------------------------------------------------------+ call #_cmdRZtoken ' /CS=0, send cmd, recv R1, /CS=0(ena) if_nz jmp #_fail '24 ' <>$00(good): error '+-----------------------------------------------------------------------------+ mov dataout, #$FE ' start block token call #_sendbyte ' write data byte '+-----------------------------------------------------------------------------+ .writebyte rdlong dataout, bufaddr ' load byte movbyts dataout, #%00_01_10_11 call #_sendlong ' write data byte add bufaddr, #4 ' bufaddr++ djnz longscnt, #.writebyte ' byte-- ' NOTE: CRC16 is ignored in SPI mode call #_getreply ' and reply, #$1f cmp reply, #5 wz drvl #56 ' diag if_z ret or reply, #$100 ' ensure reply is not zero jmp #_failI've also tweaked
_readBLOCKto use_recvlonginstead of_recvbyteAnd SD clock pin now idles high too. This suits better for not clashing with the SPI CS pin of the Flash EEPROM.
Ross.
Thanks for the reply.
OUTL #_SD_CKis all.What might be of significance though is the version notes says:
Yes please. No doubt I'll regret it.
