use of multiple identical objects in spin2 — Parallax Forums
when I have 4 of these X Band devices hooked up, and code it this way, does it use 4x the memory? Do I have to make a clever multipin X Band Object to make better use of memory?
  • RaymanRayman Posts: 16,266
    Pretty sure uses 1X the memory, unless you have a VAR section.
    Each would get its own copy of things in VAR sections...
    At least, that's the way remember it...
  • evanhevanh Posts: 17,173
    Not hard to test. See how much the compiled file size increases when adding first object compared to adding more copies.
  • Code and DAT sections are shared between instances. The VAR section of the object is duplicated to be unique for each instance.
    Quick test with my version of the x-band object.
    #    Code  Delta    Vars  Delta
    0    2448      0     556      0
    1    2552    104     572     16
    2    2560      8     588     16
  • oh, right... thanks all. I should pay more attention to the "Object Info" viewer.
