PNut/Spin2 Latest Version (v52 - New MOVBYTS(), ENDIANL(), ENDIANW(), NEXT/QUIT <level>, DEBUG end) - Page 76 — Parallax Forums
1707172737476»
  • RaymanRayman Posts: 15,716
    edited 2025-08-18 22:19
    Said flash loader could also attempt to load from uSD, if desired, right?
    Could be useful if uSD is on different pins and/or has a power switch.
    Also, could maybe do something fancy like look for a backup boot file if the first one is missing...
    Also, guess this could allow for long file names and directories...
    4-pin uSD booting should be faster. Wonder if that'd make a difference...
  • Wuerfel_21Wuerfel_21 Posts: 5,650
    edited 2025-08-18 22:38
    Only if you can figure out how to hot-patch the SD boot code to do that - a full SD driver is probably too heavy for the 1024 bytes of bootloader space - just use the stock flash bootloader and then make the SD loader be the payload of that.
    You can make the SD boot A LOT faster as-is by making _BOOT_P2.BIX a tiny stub that sets the clock, patches some stuff in the ROM code and then pivots into a different boot file. I had one like that:
    CON _CLKFREQ = 300_000_000
    DAT
                  org 0
                  asmclk
                  '' Patch pullup check
                  wrlong #0,##$fc5b4 ' not sure why it fails but ok
                  '' Move filename into place
                  mov $1DC,name+0
                  mov $1DD,name+1
                  mov $1DE,name+2
                  drvh #38 ' Set LED
                  call #$fc578
                  drvl #38 ' Clear LED if fail
                  jmp #$
    name          byte "LOADTEST","BIX",0
    (as seen, this tries to load LOADTEST.BIX - also note the Pin 38 LED, change or remove that if necessary)
    Booting a large ~400K executable is a lot faster like that.
    You can also compress the executable you're booting. Flexspin and SpinTools have this option built-in, I also made a standalone version
  • ke4pjwke4pjw Posts: 1,230
    I can confirm this is a "me" problem. I am unsure why it does not boot properly, but I will figure it out. A simple program booted correctly from SD.
    Well, it's working as it should now. Maybe the card was flakey, but all is well now.
    The good news: No code changes for my code to work with PNUT v51a!
  • evanhevanh Posts: 16,775
    Chip,
    I just bumped into something that has changed in recent releases of Pnut. I don't know if this is an explicit change you intended or not. The following compiled and ran when I was compiling with Pnut v46:
        send( "SPI cmode: CPOL=", CPOL + "0", " CPHA=", CPHA + "0", 13,10 )
    But now, with Pnut v51a, I need to add an extra set of brackets as per the following:
        send( "SPI cmode: CPOL=", (CPOL + "0"), " CPHA=", (CPHA + "0"), 13,10 )
    Otherwise I basically get a syntax error. Pnut v51a reports a missing comma or closing bracket without the edit.
  • cgraceycgracey Posts: 14,281
    edited 2025-10-09 03:54
    There is a new version (v52) of PNut.exe at the top of this thread.
    v52 - 2025.10.08
    • New MOVBYTS(), ENDIANL(), ENDIANW() methods.
    • NEXT/QUIT now allowed to select nesting level of operation.
    • DEBUG(DEBUG_END_SESSION) now ends DEBUG session and exits PNut if -rd was used on command line.
    • New DEBUG Display TERM color commands for added simplicity.
