Wiznet W6100 Spin2 driver usage
Started using the @ke4pjw Spin2 driver for W6100, hoping to use it to implement Modbus TCP for the P2PLC project...
Have it working, sort of...
Using a version where the top file is "SpinnerEdge_Top.spin2".
Thing Terry might have added a regular SPI interface after asking for it. He uses the 8-bit parallel interface.
Have to select which one here:
' Init Ethernet ' elock := W6100.initparallel() elock := W6100.initSPI()
Thought the SPI pins in the main file were for the W6100, but these are for uSD. Added a comment there:
CON 'uSD card pin settings DOPin = 58 CLKPin = 61 DIPin = 59 CSPin = 60
The actual ethernet SPI pins are in W6100drv.spin2. A bit confusing there because A0 and A1 are actually MOSI and MISO in SPI mode. Added a comment there. So, the pins here changed by comments are the ones you need:
CLK = 39'16 MOD = 16 ADDR = 18 ADDPINS 1 RSET = 23 CSn = 40'17 RDn = 21 WRn = 22 ' INTn = 20 'Not used DATA = 24 ADDPINS 7 DPINS = 24 / 8 A0 = 38'18 'mosi in spi A1 = 41'19 'miso in spi
There are also some hopefully unused pins defined here and also some LED pins defined below this. Have to make sure these aren't actually being used or disable that...
Using this with the DMB-4775 enclosure board with a special PCB for the SWaP module and a daughter PCB interface for the wiznet module.
I'm directly connecting with ethernet cable to a spare ethernet port on a PC. This doesn't seem to be a DHCP server, so need to specify IP address for the wiznet here:
' Set IP Address. Set to 0.0.0.0 for DHCP IPADDRESS[0] := 192'0 IPADDRESS[1] := 168 IPADDRESS[2] := 1'0'137 IPADDRESS[3] := 2'150 ' Set Subnet Mask. Set to 0.0.0.0 for DHCP SUBNETMASK[0] := 255 SUBNETMASK[1] := 255 SUBNETMASK[2] := 255 SUBNETMASK[3] := 0 ' Set Gateway Address. Set to 0.0.0.0 for DHCP GATEWAY[0] := 192 GATEWAY[1] := 168 GATEWAY[2] := 1'0'137 GATEWAY[3] := 1'10'1 ' Set DNS Server Address. Set to 0.0.0.0 for DHCP DNS[0] := 192'8 DNS[1] := 168'8 DNS[2] := 1'8 DNS[3] := 1'8
Anyway, so after all that (and copying the files in the "SDCARD" to the uSD card, it seems to work, sort of.
It serves up index.html from uSD to browser, but the page appears either blank or with just the text, "Spinnernet Edge". It doesn't seem to serve up the .png background file. Working now to figure this out.
Will probably eventually switch this over to C, where there is another solution, but want to get this working first.
Should also update the uSD driver with the new one from @evanh ...
@Rayman What browser are you using? I may be too aggressively closing the connection on the webserver. I have wanted to change how those timeouts are performed in the driver, now that I know more about how they can be handled. The browsers want to keep a persistent connection open to the webserver, but that prevents anyone else from connecting.
I am happy to help out with anything I can.
Ok, this was a terrible way to add a wait. For the moment, change 10000 to something larger like 25000. I am going to rework this to be a number of ms to wait before closing the connection.
There are several improvements I have not folded into this terrible code of mine that I have made in other projects.
@Rayman Be sure to copy the favicon.ico file too. Otherwise the browser will try and pull it on every request instead of caching it. That may make for unexpected results.
@ke4pjw Thanks. Adjusted that delay, but doesn't help...
Wondering if browser doesn't like the index.html file...
The favicon is showing up on browser tab, not sure how though...
From the debug it looks like the code is seeing a request with a blank filename...
DHCP is working btw, testing that here at home...
@ke4pjw Appears that Edge does not like your html file...
Made a new one with image and it works...
Hey @rayman, based on the debug, it should be setting the filename to index.htm. If the length is 5 characters, it knows it is "GET /". I will move that down to show the parsed filename.
Maybe there is a problem with the file index.htm file. Make sure it is named index.htm as index.html is not the default document. I should have it configured to go through the list of potential default documents (index.html , index.htm, Default.htm, etc) It should be setting the image file as the background image of the .htm page. That's why I was asking what browser you were using. I had some problems with how Safari and Safari mobile works and have not rolled those changes into the code located at https://griswoldfx.visualstudio.com/spinner edge/_git/Software
I have spent some time adding comments to the W6100.spin2 file in that repo. I had some additional changes I am going to make, but they will potentially break existing code. Only minor tweeks needed to make existing code work again. I am adding proper timeouts based on ms, rather than a crude arbitrary counter.
Ok, I'll try again with your index.htm. These are files that this driver came with for testing....
Ok, it's strange. Sometimes my index with image works and sometimes it doesn't.
I can see the request for the image in the debug window, but must not be going through...
This is on a PC with Edge browser. Maybe safari is different?
On the initial request it doesn't appear to get a filename and just goes with its preset default, "index.htm".
Think it might be something with the filesystem. Seems like it can only serve up on file and then quits...
Think found the problem!
Commenting out the second condition makes it work:
Repeat until FS.fileTell() == FS.fileSize() 'or W6100.isdisconnected(socket) == True@Rayman I am going to take a look at it this week. It was put there so that very large file downloads could be aborted appropriately.
Thanks @ke4pjw . There's no rush.
Maybe top level needs some tweaks but driver seem good.
One other minor issue: The DHCP fails occasionally. Maybe it can try a few times before giving up?
App needed for won't use DHCP, so not a big deal for me...
I have seen that on occasion. Yeah, I think we should have it retry if it doesn't hear a reply in time.
--Terry
I have not published yet, but have updated dhcpclient() so that if it does not receive a response in 5 seconds it tries again. If it makes it's way to the failed status, it calls itself again.
Have integrated this into the P2 PLC device and appears to be working.
Just changed so starts a new cog to service ethernet requests and then returns to main program.
Up next, is to switch from port 80 (HTML server) to 502 (Modbus TCP) and implement the modbus tcp...
Hi,
I am trying to get this to work on a custom board. I wonder if there is any more solid information on what is needed for the parallel connection.
I think I have it figured out, but not working and the signals I see seem a little strange.
Here is my modification to W6100drv (I picked up my copy on this thread..):
And my connections where XX is the P2 pin, and 'text nn' is the datasheet name and w6100 pin number.. Have I got this much right?:
(Yes, I did the board by the suggested schematic from Wiznet before attempting to understand this driver..)
00 'DATA0 37'
01 'DATA1 38'
02 'DATA2 39'
03 'DATA3 40'
04 'DATA4 41'
05 'DATA5 42'
06 'DATA6 43'
07 'DATA7 44'
08 'MOSI 32'
09 'MISO 33'
10 '!WR 35'
11 '!RD 34
12 '!RST 48'
13 '!INT 47'
14 '!CS 29'
'MOD[2] 27' is pulled high, other MOD pulled low. all the places in the driver where MOD is manipulated are commented out. I found only instances where it was placed high for parallel mode.
The schematic I use: P2 Edge is U15
ANYONE that sees this Correct the painfully obvious mistake of grounding SCLK by connecting it to a pin on the P2.
You might look at the @ke4pjw website and spinner net product page…
That was a little bit of a search, but most helpful. Once I get the boards back after fixing my mistake, I will describe the connections here for future reference.
I see your comment above about which connections are really needed. is this still valid?
Thanks!
Well, Clock wasn't it. It never toggles anyway, since I am using parallel comm. According to my capture, I think things are working perfectly until it is time to interpret the signals from the W6100.
According to my monitoring of the digital lines, Attempting to start is working as far as this spot in W6100_Etherned1a.spin2.:
' ID Chip W6100.readreg(W6100.REG_CIDR0,W6100.IDM_BSR_Common_Register,2,@CHIPID) debug("Chip Identification: ", uhex_(CHIPID[0])," ",uhex_(CHIPID[1])) if CHIPID[0] == $61 and CHIPID[1] == $00 debug("Wiznet W6100 detected") else debug("Error: Wiznet W6100 NOT detected.") if CHIPID[0] == $FF and CHIPID[1] == $FF and W6100.isspimode() == true debug("Did you forget to remove J1 for SPI mode?") if CHIPID[0] == $00 and CHIPID[1] == $00 and W6100.isspimode() == false debug("Did you forget to add J1 for Parallel mode?") abortAt this point I see 3 zeros sent to 0,1,and 2 (Addresses via A0 and A1) the W6100, and then a read of $61, $00 from the W6100. This should be perfect..
BUT
debug says:
Cog1 Chip Identification: $F7 $F7
Cog1 Error: Wiznet W6100 NOT detected.
I cannot think of any way to flip and invert the bits on the bus to turn $61,$00 into $F7,$F7, and I do not understand PASM well enough to make sense of what is going wrong.
I have switched from the W6100drv from this thread to the one from the Spinner Edge repo, and changed the pin defs to match my board.
What am I doing wrong?
It might be DPINS is set wrong. Appears this is telling the code which byte on INA to use for data.
The original had data bus starting at P24 and so DPINS was set to byte #3.
See if changing DPINS to 0 works for you...
So that got me all the way to 'Cog1 Waiting for TCP request on Socket 1 port 80' which at this point seems to be total success.
with that said, shall I assume that DATA must be some multiple of 8?
So it seems that DPINS = DATA/8 might be a sensible way to define DPINS.
Thanks!
Nope, DATA is a bitfield... gives nonsense when /8.. So much on P2 I still need to get my head around..
Think it does need to be multiple of 8.
U r lucky did it that way.
Although code could be changed if wasn’t …
DPINS = DATA/8
Was thinking same thing…
One can also automatically handle the port being on PortB.
Just divide base by 32 and add to ina…
I was considering replacing the altsb/setbyte combos with a shift/write, which would seem to work with any consecutive assignment of DATA0 pin. Someday, It works now..
Ya, putting the byte in a byte aligned spot just seemed right..
So here is how I am defining the pins in my modded 'W6100drv_FCB_000'.
it is intended to be parallel only
I have been away a few days, sorry I was unable to lend a hand. Really glad to see some folks using my terrible code. There is a lot of technical debt in there. I really need to update it so the pin definitions are consistent and proper, I also need to update the code to do proper timing waits that match the datasheet. It was more trial, error, full send
The technical investment is clear. A LOT of your demo made it into my prototype code. I even kept the DHCP stuff because I think the commented build of the packets will be useful at some point, even though my fixture will use fixed IP.
Can't thank you enough.
And thanks again Rayman, I don't see how I would have ever caught the DPINS thing with the troubleshooting trajectory I was on.
