Footprint for P2 Edge socket SMT vs 3d model discrepancy.
R Baggett
Hi, I made the footprint for the P2 Edge SMT socket according to the datasheet:
but the 3d model looks wrong.. I presume the datasheet is the one that is correct, but i just don't get warm/fuzzy from this. If anyone has one on-hand could you please verify this measurement?
Here is what I get in 3D:
Just measured 11.61 mm. So guess that model is right...
Footprint used before from Eagle has distance between pad outer edges at about 13 mm
Thanks! the datasheet is correct! 3D model difference isn't a biggie, but shook my confidence a bit.
