Click board for the P2. Stepper driver click board — Parallax Forums
@"Stephen Moraco"
@"Ken Gracey"
Does anyone have some P2 spin code for the Stepper 2 click?
https://www.parallax.com/product/stepper-2-click/
I only find the elink display.
Thanks in advance
Martin
  • JonnyMacJonnyMac Posts: 9,527
    edited 2025-08-18 19:04
    I write a lot of code as a break time exercise and then forget about it. Apparently, four years ago I did that with the Click Stepper-2. It's a very simple object, but does seem to work based on connecting the control pins to a logic analyzer. I did freshen the object a bit (to match my current template & standard) and made a really simple demo.
    That said, remember the MIT License: there are no guarantees.
  • I will look at it.
    Martin
  • @"Stephen Moraco"
    Howdy,
    I am looking at your demo elink click. Saw in the bit map data that mentioned
    "image by Convert v1.0"
    Do you have a link to that? I have been trying to find it with no luck.
    Thank you in advance.
    Martin
  • Martin,
    Of course I've been away from that effort long enough that I'm going to have to find it myself.
    I'll post here when i have news.
    Stephen
  • @"Stephen Moraco"
    Thank you very much. No rush.
    Your code for the elink looks interesting. I may have some questions. I am trying to
    get the clicks for the stepper to work. Your code is a good beginning.
    Martin
    See the C-src/ folder. You have the source code for it in my repo. Is that what you are looking for?
    Stephen
  • pilot0315pilot0315 Posts: 953
    edited 2025-08-26 02:56
    @"Stephen Moraco"
    I copied the area where it says "Image by Convert v1.0. I have searched for it with no luck.
    Martin
    DAT { Overlay Bitmap Data }
    ' Image by Convert v1.0 <<<<<<< :):):) The program that converted the image to the bitmap.
    I would like to use it.
        imgWidthBytes   WORD    16
        imgHeightBytes  WORD    49
        imgBits
                BYTE    $77, $77, $77, $77, $77, $77, $77, $77, $77, $77, $07, $77, $77, $77, $77, $77  ' row 1 of 49
                BYTE    $77, $77, $77, $77, $77, $77, $77, $77, $77, $77, $70, $77, $77, $77, $77, $77  ' row 2 of 49
                BYTE    $77, $77, $77, $77, $77, $77, $77, $77, $77, $77, $70, $77, $77, $77, $77, $77  ' row 3 of 49
                BYTE    $77, $77, $77, $77, $77, $77, $77, $77, $77, $77, $07, $77, $77, $77, $77, $77  ' row 4 of 49
                BYTE    $77, $77, $77, $77, $77, $77, $77, $77, $77, $70, $77, $77, $77, $77, $77, $77  ' row 5 of 49
                BYTE    $77, $77, $77, $77, $77, $77, $77, $77, $77, $70, $77, $77, $77, $77, $77, $77  ' row 6 of 49
                BYTE    $77, $77, $77, $77, $77, $77, $77, $77, $77, $70, $77, $71, $77, $77, $77, $77  ' row 7 of 49
                BYTE    $77, $77, $77, $77, $77, $77, $77, $77, $77, $77, $07, $77, $77, $77, $77, $77  ' row 8 of 49
                BYTE    $77, $77, $77, $77, $77, $77, $70, $07, $77, $77, $07, $77, $7
  • @pilot0315 said:
    @"Stephen Moraco"
    Martin
    Please see C-src/ at Repo
    -Stephen
