Click board for the P2. Stepper driver click board
pilot0315
@"Stephen Moraco"
@"Ken Gracey"
Does anyone have some P2 spin code for the Stepper 2 click?
https://www.parallax.com/product/stepper-2-click/
I only find the elink display.
Thanks in advance
Martin
I write a lot of code as a break time exercise and then forget about it. Apparently, four years ago I did that with the Click Stepper-2. It's a very simple object, but does seem to work based on connecting the control pins to a logic analyzer. I did freshen the object a bit (to match my current template & standard) and made a really simple demo.
That said, remember the MIT License: there are no guarantees.
I will look at it.
Martin
@"Stephen Moraco"
Howdy,
I am looking at your demo elink click. Saw in the bit map data that mentioned
"image by Convert v1.0"
Do you have a link to that? I have been trying to find it with no luck.
Thank you in advance.
Martin
Martin,
Of course I've been away from that effort long enough that I'm going to have to find it myself.
I'll post here when i have news.
Stephen
@"Stephen Moraco"
Thank you very much. No rush.
Your code for the elink looks interesting. I may have some questions. I am trying to
get the clicks for the stepper to work. Your code is a good beginning.
Martin
See the C-src/ folder. You have the source code for it in my repo. Is that what you are looking for?
Stephen
@"Stephen Moraco"
I copied the area where it says "Image by Convert v1.0. I have searched for it with no luck.
Martin
DAT { Overlay Bitmap Data }
' Image by Convert v1.0 <<<<<<<
The program that converted the image to the bitmap.
I would like to use it.
imgWidthBytes WORD 16 imgHeightBytes WORD 49 imgBits BYTE $77, $77, $77, $77, $77, $77, $77, $77, $77, $77, $07, $77, $77, $77, $77, $77 ' row 1 of 49 BYTE $77, $77, $77, $77, $77, $77, $77, $77, $77, $77, $70, $77, $77, $77, $77, $77 ' row 2 of 49 BYTE $77, $77, $77, $77, $77, $77, $77, $77, $77, $77, $70, $77, $77, $77, $77, $77 ' row 3 of 49 BYTE $77, $77, $77, $77, $77, $77, $77, $77, $77, $77, $07, $77, $77, $77, $77, $77 ' row 4 of 49 BYTE $77, $77, $77, $77, $77, $77, $77, $77, $77, $70, $77, $77, $77, $77, $77, $77 ' row 5 of 49 BYTE $77, $77, $77, $77, $77, $77, $77, $77, $77, $70, $77, $77, $77, $77, $77, $77 ' row 6 of 49 BYTE $77, $77, $77, $77, $77, $77, $77, $77, $77, $70, $77, $71, $77, $77, $77, $77 ' row 7 of 49 BYTE $77, $77, $77, $77, $77, $77, $77, $77, $77, $77, $07, $77, $77, $77, $77, $77 ' row 8 of 49 BYTE $77, $77, $77, $77, $77, $77, $70, $07, $77, $77, $07, $77, $7Please see C-src/ at Repo
-Stephen
