towards a P2 Virtual Machine using XBYTE and Subsystems - Page 2 — Parallax Forums
2»
  • @RossH said:
    However, I'm now looking at using it instead to build a bytecode interpreter for Lua. If I can do that it would make Lua absolutely fly on the P2, and make all other P2 languages look positively neanderthal! :)
    +1 for languages on P2 XBTYE ... I think that might be what makes P2 stand out in the market. I'm not ready for the big reveal, but this is what I've been coding on for the past week.
  • I don't know if I understand XBYTE, but am looking forward to seeing what you're doing so that I can learn from it.
    I don't know if I understand XBYTE either. :) But, of all the P2 projects I've started in the past few years, it seems like I've hit the bedrock beneath to build my foundation on. It is keeping my attention.
  • RossHRossH Posts: 5,733
    edited 2025-06-18 01:43
    The easiest way to understand XBYTE is to compile and run the demo given in the P2 documentation. I have attached a slightly modified version below (I modified it to light up the LEDS on the P2 Evaluation board, which makes it very easy to see immediately the impact of any changes you make to the program - for example, I have added a waitx instruction to the PASM code at label r2, which is the code that implements the XBYTE code 2, and also to the code at label r4, which implements the XBYTE code 4).
    ' xbyte demo, modified to use default RCFAST clock (20Mhz) and the P2 Eval LEDs
    dat             org
                    drvh #56                 ' otherwise they float!
                    drvh #57                 ' otherwise they float!
                    drvh #58                 ' otherwise they float!
                    drvh #59                 ' otherwise they float!
                    setq2   #$FF            'load bytecode table into LUT $100..$1FF
                    rdlong  $100,#bytetable
                    rdfast  #0,#bytecodes   'init fifo read at start of bytecodes
                    push    #$1FF           'push $1FF for xbyte
            _ret_   setq    #$100           'start xbyte with LUT base = $100, no stack pop
    ' Bytecode routines
    r0      _ret_   drvnot  #56             'toggle pin 56
    r1      _ret_   drvnot  #57             'toggle pin 57
    r2              waitx  ##10000000       'wait 1/2 second (@20mhz)
            _ret_   drvnot  #58             'toggle pin 58
    r3      _ret_   drvnot  #59             'toggle pin 59
    r4              rfvars  pa              'get offset
                    add     pb,pa           'add offset
            _ret_   rdfast  #0,pb           'init fifo read at new address
    tmp             long    0
    ' Bytecodes that form the XBYTE program in hub
                    orgh
    bytecodes       byte    0                       'toggle pin 56
                    byte    1                       'toggle pin 57
                    byte    2                       'toggle pin 58
                    byte    3                       'toggle pin 59
                    byte    4,(bytecodes-$) & $7F   'relative branch, loop to bytecodes
    ' Bytecode EXECF data, moved into lut $100..$1FF (no SKIPF patterns are used in this example)
    bytetable       long    r0                      '#0     toggle pin 56
                    long    r1                      '#1     toggle pin 57
                    long    r2                      '#2     toggle pin 58
                    long    r3                      '#3     toggle pin 59
                    long    r4                      '#4     relative branch
    If you save it as xbyte.pasm you can compile and run it using the following commands:
    p2asm xbyte.pasm
    payload xbyte
    Then watch the LEDs! Note that the bytecodes table is the 5 byte XBYTE program that is being executed - the rest of the program is just set up.
    Ross.
    Interesting. I was also planning to implement the Lua interpreter across multiple cogs. It looks like your Lisp Engine will get there first, but that is entirely appropriate! :)
  • So, after a while, I have my hybrid approach for yet another Forth machine brought to a state that it can compile and run the Byte sieve benchmark.
    Hybrid means, that we have an inner-inner XBYTE loop sitting permanently in LUT, which can execute 44 Forth instructions, including calling other forth words and exit them to resume. When it encounters a TRAP instruction, it returns to the calling Inner Interpreter, written in C which executes 109 Trap Instructions written in C. I will write up details later. Stacks are in HUB Ram.
    It turns out, that P2XCForth for sieve is nearly as fast as Taqoz and is about 3,8 times faster than P2CCForth. Nearly all instructions of the sieve are XBYTE instructions.
    B) Christof
  • Christof Eb.Christof Eb. Posts: 1,541
    edited 2025-07-04 09:23
    Ha!
    The Sieve Benchmark contains an access to the "flags" field and also to the constant "size" in the innermost loop, which is normally 2 Trap codes each. If you bring the compiler to code a "literal" instead to get the address and the constant, then the loops are pure XBYTE and P2XCForth becomes better than twice as fast as Taqoz!
    The editor works now also:
    Edit: While the use of macros, which compile literals with their speed is still possible, I have now created a new XBYTE instruction, which gets the address of a variable. This is now used by create, variable and constant. So the traps are now avoided for these. For this there is no need to code special source text. With this there is a speed gain of factor 1,4 to Taqoz. I must say, that I am quite positively astonished: This XBYTE-C hybrid can indeed combine a similar speed like Taqoz and the ability to use modules from obex.
    :) Christof
