New SD mode P2 accessory board - Page 33 — Parallax Forums
13031333536
  • evanhevanh Posts: 17,069
    edited 2025-04-20 13:49
    Uh-oh, one of my seven SD cards doesn't like it ... getting a busy timeout following the first write ...
    It's happy with the older v1.2 driver, so can't blame the card.
    Normal CMD12,  Sysclock 350 MHz
     SD clock-divider set to sysclock/3 (116.6 MHz)
     CID decode:  ManID=9C   OEMID=SO  Name=USD00
      Ver=0.2   Serial=39A8FBFB   Date=2018-1
     cluster size = 8192 bytes
     Buffer = 2 kB,  Written 512 kB at 753 kB/s,  Verified,  Read 512 kB at 4558 kB/s
     Buffer = 2 kB,  Written 512 kB at 854 kB/s,  Verified,  Read 512 kB at 4558 kB/s
     Buffer = 2 kB,  Written 512 kB at 855 kB/s,  Verified,  Read 512 kB at 4558 kB/s
     Buffer = 4 kB,  Written 1024 kB at 1429 kB/s,  Verified,  Read 1024 kB at 8162 kB/s
     Buffer = 4 kB,  Written 1024 kB at 1678 kB/s,  Verified,  Read 1024 kB at 8162 kB/s
     Buffer = 4 kB,  Written 1024 kB at 1672 kB/s,  Verified,  Read 1024 kB at 8068 kB/s
     Buffer = 8 kB,  Written 2048 kB at 2949 kB/s,  Verified,  Read 2048 kB at 13420 kB/s
     Buffer = 8 kB,  Written 2048 kB at 2994 kB/s,  Verified,  Read 2048 kB at 13310 kB/s
     Buffer = 8 kB,  Written 2048 kB at 3331 kB/s,  Verified,  Read 2048 kB at 13423 kB/s
  • IIRC while the write is ongoing, the result isn't guaranteed to be flushed, so you might need to plumb through the flushing from the FS layer.
    edited 2025-04-20 14:53
    Yup, my updated CTRL_SYNC ioctl() issues a CMD12 and then waits on card busy before returning. An fclose() on an open write generates this sync.
  • RaymanRayman Posts: 16,059
    @evanh That's pretty awesome speeds there!
    Certainly is. I hadn't imagined such a big jump.
    But not yet confident. I've found a second SD card, of eight now, that's not entirely happy. This one works when I enable the block logging though.
    I used to have a bunch of full-sized SD cards too, but haven't found even one of those. I suspect I threw them all out a long time ago because they probably all got smashed. I remember sitting on some and cracking the thin PCB material.
  • @evanh said:
    Whoa! I found a bug (Every second join became disjointed) that was slowing it down still. And I've got writes working with lazy CMD12 too! Don't need no big buffers any longer. Fast recording here we come. :D
    Wow that's what I want to see! These sorts of speeds will let me get back to the HDMI capture stuff I started a while back. I'd sort of assumed we'd hit a fundamental limit somewhere but didn't know why.
    Keep at it. You'll probably figure out what the real limitation is there eventually and what feature the card needs to be able to do what we want.
    Appreciated, thanks.
    The scope is at work at the moment. I'm unsure what I'll be able to see but I need some inspiration at least, or just plain insight into what's actually occurring. The fact that the newer cards seem happy might be telling.
    edited 2025-04-22 12:51
    Uh-oh again, I've messed something up along the way. None of the cards work using portA now. There must be a typo or something similar. I don't know how far back this occurred, since the stable v1.2 release, because I've been using pin base of 40 all this time.
    PS: Hehe, I just double checked v1.2 to be sure it's okay. No problem there. :)
  • One step forward two steps back :smile:
    edited 2025-04-22 13:23
    The good news is that just by verbatim copying the two disk_read()/disk_write() functions from v1.2 everything returns to normal. So all my problems appear to be contained inside those two - Which is of course where 99% of the edits have occurred.
    PS: The new code structure makes the two of them act as one unit. They share state tracking of where CMD12 next needs to be issued. They look identical at first glance. Just a couple of differences like CMD18 for reads vs CMD25 for writes. CMD17 and CMD24 have been removed. In fact, if I get this to work cleanly, I think I'll be making them one function with two hooks for FS handler.
    Err, I guess it would need two wrapper functions to specify read vs write. Direct hooks won't provided that. I'll test it out before deciding.
    edited 2025-04-22 14:49
    Huh, found a weakness in tx_datablock() low level routine where it was failing to report unknown errors with debugging enabled. Something odd is happening with the card's CRC response. Definitely want to get the scope on to it now.
    edited 2025-04-24 07:05
    Okay, that one's solved. It was a brand new bug in the newest code attempting to narrow down why some cards weren't happy with the lazy CMD12. I'd missed out doing a bit-shift on the LED pin number variable. This resulted in a spurious low pin number with a huge ADDPINS value. Which would've messed with OUTA/DIRA bits when the activity LED was toggled.
    Didn't need the scope, just some sleep.
    edited 2025-04-24 09:10
    Amusingly, the botched workaround was on the right track. If I hadn't got confused I wouldn't have stopped the other day.
    Issuing CMD24 for doing single block writes has proven to be important.
    I've found I can still use CMD25+CMD12 for doing singles but a 0.5 ms separation is then required. Dunno why, but it works for both of the affected cards. Obviously adding extra delays on top of the CMD25+CMD12 already being a double command is simply a bad approach when using CMD24 by itself works best.
    So reads and writes have a notable structural difference now.
  • So writing from 512 byte buffers -> hit CMD24 sad case?
    edited 2025-04-24 15:06
    For those two old cards, yes. One is the 2007 camera card (Adata), it is also SDSC 2GB capacity. The other is not so old, 2018, but is obscure and cheap Apacer brand.
    PS: I have a cheap 2013 Adata that is fine using CMD25, without adding delays, for all writes. So age isn't everything.
  • I mean driver-side it would issue the single block write instead of keeping a multi-block open for more.
    I guess there's a general problem with the FS interface not really telling you in advance if there's going to be another sequential read/write command after the current.
    edited 2025-04-24 15:42
    Oh, yes, exactly. No way to know what might come later. Especially when it's just one block.
    It might be a blessing in disguise anyway. I hadn't got round to even thinking about the consequences of removing a card with a CMD25 still in progress.
    EDIT: Err, logging the block numbers and SYNC calls I can see the final SYNC is called after the final FAT meta data is written. So using CMD25 for everything should be just as reliable.
    Hmm, I'm happy with the stability again but I'm not particularly happy with the 0.4 kB increase in binary size.
    I'll post it here for testing before adding it to the Obex.
    edited 2025-04-26 00:17
    LOL, the optimiser beat me to it. I just noticed I could optimise the code size by shuffling the logic to eliminate duplication inside the disk_write() function. But it made no difference to the compiled size. Oh well.
    EDIT: Oops, it did make a tiny difference, 76 bytes. I just hadn't checked the exact bytes.
    EDIT2: Shaved another 44 bytes off, yahoo!
    EDIT3: Shaved off another 32 bytes, not off the recent bloat though. I finally replaced the CRC7 routine with the smaller Fcached version, as per Ada's request from a while back.
    Huh, I just started looking at the plug-in wrapper code and note it actually already merges the read and write hooks into one function, and then splits them up again to call my disk_read()/disk_write(). So there's two extra layers there, inside the driver, I hadn't even noticed before ...
    Do you expect that it would slow things down all that much?
    edited 2025-04-26 01:49
    Dunno, it is at least four extra hubexec branches per r/w operation, but it's gotta be extra binary size too. And I have noted the plug-in version of sdmm.cc is bigger than the built-in version.
    EDIT: Okay, I figure the plug-in wrapper code is arranged like that for compatibility with the legacy built-in code path. I think I could rehash it since my driver doesn't have any use for built-in path.
    edited 2025-04-27 11:01
    Binary size is back down to 40 bytes less than v1.2, which feels like a small milestone at least. But, comparatively, I could do some of the same to v1.2 and make it even smaller.
    PS: I've moved a lot of code directly into the new plug-in interfacing functions. Some of the boiler plate code is replaced. The old interface is gone from the driver. It'd be good for others to test this out for new bugs.
    PPS: One functional change I did, for performance only, was to ignore the outcome of all CMD12s. The code path returns without waiting on the card's response. Instead it relies on the subsequent card-busy check that follows such an action. I've not actually tried to measure what difference it has. The speed gain may only show up at low sysclock frequencies where the Prop2 overheads take longer than a command response + card busy completing ... which would most likely occur for block reads. EDIT: Actually, it's almost a non-change in effect. With the new CMD12 state tracking the only time a card-busy check doesn't immediately follow a CMD12 is when there has been a data error and the driver has aborted. I'll change that now ... done - Data errors now collect the CMD12 response before aborting.
    Hmm, I might have a lingering bug there. I'm not certain how write data errors are meant to be handled. Having the CMD12 might be entirely superfluous for writes. EDIT: Okay, all good. I've checked the case of a failed CRC during CMD25 writes. It does still require a following CMD12 to close it off.
    edited 2025-04-29 15:01
    Grr, v1.3 and v1.4 have a new bug ... using multi-card instances causes a lock-up ...
    Double grr! It's impossible! The low level rx_datablock() is hanging as if the clock smartpin is not firing, but I've not changed anything in that area ... and it only occurs when the driver is rapidly alternating between both cards with an open file on each.
    Can't believe this. If the card was having an issue with the sequence, ie: not responding, then that routine should timeout, not lock up.
  • Sounds a bit like some sort of race condition where things get out of sync between HW and SW signalling. Supporting multi-instance is always going to add complexity.
    edited 2025-04-30 02:52
    Flex's filesystem layer seems fine doing it. Once I cleaned up the driver in v1.1, simultaneously using multiple cards worked perfectly. So, for example, I can simply swap the buggy v1.3 driver for the slightly older v1.2 driver and all is fine.
    PS: The tester program for this copies a 4 MB file between two cards by reading and writing a small amount at a time. But first it creates, filling it with XORO32 data, the 4 MB file to be copied and then also verifies its content. Both of those steps are fine using the buggy v1.3 or v1.4 drivers.
    rx_datablocks() is the most complicated routine in the whole driver, by far. But it hasn't changed since v1.0 except for one added clock smartpin enable at its start to handle the improved v1.2 sharing between cogs.
    edited 2025-04-30 08:34
    HA! A proper bug, this one was. Completely makes sense now and none of the behaviours I've already listed are in contradiction either. SETSE1 has been overlooked starting from driver v1.3. SETSE1 is normally configured by tx_command() to detect completion of clocking smartpin but, with the introduction of the lazy CMD12 short-cutting, tx_command() is no longer called on every filesystem transaction.
    The bug only showed up when SETSE1 is reused. Which is exactly what occurs when a second instance of the driver is in action.
    All fixed now.
       clkfreq = 320000000   clkmode = 0x1000ffb
     /sd1 handle = df08
     /sd2 handle = ded4
      deleting file /sd1/copy1.bin ...  deleted: OK
      deleting file /sd2/copy1.bin ...  deleted: OK
    buffer size = 4096,  data seed = 0xc266f07e
    write file /sd1/copy1.bin, buffer addr = 0x109a0, size = 4096
      Written 4403200 of 4400000 bytes at 23370 kB/s
      read back file /sd1/copy1.bin, size = 4403200
      read back buffer addr = 0x109a4, size = 4096
      Read back 4403200 of 4403200 bytes at 23889 kB/s
    Compare match.  :)
      copy file length = 4403200
      copy buffer addr = 0x109a4, size = 4096
      Copied 4403200 of 4403200 bytes at 13565 kB/s
      read back file /sd2/copy1.bin, size = 4403200
      Read back 4403200 of 4403200 bytes at 23757 kB/s
    Compare match.  :)
    edited 2025-04-30 09:31
    Next step is change the tester program to spawn a second task and run a double-buffer-flipping operation so that the copying can use two streamers at once with two cogs using the same driver in full parallel.
    Same driver, different SD cards on different IO cmd/clk/data pins, right? Not actually sharing the same SD data bus (which I believe is theoretically possible in SD transfer mode); as that case seems like too much complexity.
