P2 based Pick and Place for P2 - Page 2 — Parallax Forums
2»
  • FYI- LumenPNP, replacing one of the two picker heads with paste placement is currently in the works. (It's in beta now.) So, if one is doing smaller PCB runs one can now paste up the board, place the parts, and then move the board to reflow.
    Yes, I'm a fan/follower/new owner of (still dialing it in) one of these.
    Stephen
  • RaymanRayman Posts: 15,722
    edited 2025-03-12 23:18
    I was surprised when screamming circuits said they don’t use stencil and just put out paste directly on pads. That would be pretty awesome is smaller pnp could do that too…
  • Unfortunately, that is correct for the tariff. Should fall under HTS code 8479.89.92 which has a 35% rate of duty plus a General Tariff referenced to 9903.88.01 that adds another 25% because it is from China. If it makes you feel any better, my last tariff was $56,000. (for work)
    Ok, have to admit that this OpenPNP machine does a significantly better and faster job at placing P2 for me:
    https://forums.parallax.com/discussion/176169/
    However, still dream of converting GRBL code from Arduino to P2. Think that is possible, just work...
    Looks like OpenPNP can use GRBL although my unit is using something called Merlin.
    There is a P2 GRBL conversion already here, but I think it needs improvements to work with OpenPNP.
