joystick driven BOEBot using Xbee in spin — Parallax Forums
Patrick LangPatrick Lang Posts: 15
edited 2015-01-17 20:50 in Robotics
I had built a propeller BOEBot from the tutorialhttp://learn.parallax.com/node/162. I then went through the getting started with XBee RF modules text http://www.parallax.com/product/32450 including chapter 7 that uses an mx2125 accelerometer on a board to navigate the robot by tilting the board. When I saw a recent Projects forum post by Vale T. that used a 2 axis joystick to navigate an activity bot with XBee I was wondering If I could do the same with my BOEBot. His code was in c with which I am not familiar. So I thought I would try writing spin code that would accomplish my purpose. The two codes at the end of this post is my attempt. It worked for my BOEBot and should work for an activity BOT also. I mounted the joystick (parallax 27800) on an activity board but it should work on any board. If you follow the steps below it should work.
1. Build the joystick on an activity board or BOE as shown at: http://learn.parallax.com/KickStart/27800 and download the propeller demo code there also. Put an XBee on the board containing the joystick being careful to orient it correctly. A small diagram next to the XBEee socket on the board will show how it goes into the socket. Propeller board I/O pin 6 should be connected to XBee pin DI and propeller board I/O pin 7 should connect to XBee pin DO. See image below.
[img][/img]
2. Run the joystick spin demo and check out the raw RC time values displayed on PST. I ran the demo at: http:// learn.parallax.com/KickStart/27800 which gave me the raw RC time data. It was 0 to 230 with 114 as the value with joystick centered. To get both x axis and y axis readings to agree at these values I played around with the 220 ohm resistors and ending up replacing one with a 100 ohm and the other with a 260 ohm. With these values in mind I defined the cases where the wheels were set to zero (BOE-Bot) as having raw RC values (joystick) between 100 and 130. I set the max wheel values to 64 rather than 100 so the steering in turns was smoother and no “wheelies” happened between forward - backward changes. Make appropriate adjustments to your raw data as needed.
3. Build the BOE-Bot and download the code at: [url] http://learn.parallax.com/node/277[/url] the BOEBot tutorial.
4. Insert the XBEE module in the socket on the BOE-Bot, making sure it is oriented correctly ( not pointing the same way as on an activity board). Download XBEE_Object.spin and see diagram and code at: http://learn.parallax.com/node/362XBee tutorial .
5.Copy the two code files that follow in this post, paste them into a blank propeller editor window , and save them as spin files in the same folder. That folder must also contain all the files in the OBJ section of both: FullDuplexSerial.spin, RCTime.spin (both in propeller tools), PropellerBoardOfEducation.spin, PropellerBoeBotServoDrive.spin, Timing .spin (these three downloaded from the BOEBot tutorial), and XBee_object.spin ( from XBee tutorial)
Here is spin code for navigating the propeller BOEBot with a 2 axis joy stick.
This is the spin code for the joy stick board.
 {{ Reads 2 axis joystick,
   sends drive information to bot at address 1.}}
CON
  _clkmode = xtal1 + pll16x
  _xinfreq = 5_000_000
  ' Set pins and Baud rate for XBee comms
  XB_Rx     = 7       ' XBee Dout
  XB_Tx     = 6       ' XBee Din
  XB_Baud   = 9600
  MY_Addr  = 0
  DL_Addr  = 1        ' bot address
  'Constants used by joystick Object
  Xout_pin    =  0    'Propeller pin joystick X
  Yout_pin    = 1    'Propeller pin joystick Y
VAR
  long  drive, UD, LR
  byte  Stack[100]
OBJ
  pst        : "FullDuplexSerial"
  XB         : "XBee_Object"
  rc         : "RCTime"
PUB Start
         ' Configure XBee
  XB.start(XB_Rx, XB_Tx, 0, XB_Baud)                       ' Initialize comms for XBee
  XB.AT_Init                                               ' Fast AT updates
  XB.AT_ConfigVal(string("ATMY"), MY_Addr)
  XB.AT_ConfigVal(string("ATDL"), DL_Addr)
  cognew(sendcontrol,@Stack)       ' start cog to accept incoming data
Pub SendControl
        drive :=5
        repeat
          rc.rctime(0, 1, @UD)                                        'RC time joystick x axis
          rc.rctime(1, 1, @LR)                                        'RC time joystick y axis
          IF UD < 100
              drive := 1                                             ' 1 is forward
          IF UD > 130
             drive := 2                                               '2 is backward
         IF LR > 130  and UD < 100
           drive := 3                                                 '3 is left going forward
         IF LR < 100 and UD <100
           drive := 4                                                 '4 is right going forward
         IF UD >100 AND UD <130 AND LR > 100 AND LR <130
          drive := 5                                                  '5 is stop
         IF LR > 130 and UD > 130
            drive := 6                                                '6 is left going backward
         IF LR < 100 and UD > 130
             drive := 7                                               '7 is right going backwards
         XB.DEC(drive)                                                ' send drive value to BOEBot
         XB.tx(13)
This is the spin code for the propeller BOEBot
{{ Accept control information from node 0 joystick
   to drive propeller BOEbot.}}
CON
  ' I/O and Baud rate for XBee comms
  XB_Rx     = 6       ' XBee Dout
  XB_Tx     = 7       ' XBee Din
  XB_Baud   = 9600
  ' XBee addresses
  DL_Addr = $ffff     ' Send data to this address (both controller)
  MY_Addr = 1          ' This units address
  ' Servo outputs
   Left  = 14
   Right = 15
VAR
  long  drive
OBJ
  XB     : "XBee_Object"
  system : "Propeller Board of Education"
  servo  : "PropBOE-Bot Servo Drive"
  time   : "Timing"
PUB Start
  ' Initialize XBee Comms and stop wheels
  XB.Start(XB_Rx, XB_Tx ,0, XB_Baud)
   servo.wheels(0,0)
  ' Enable XBee for fast configation changes &
  ' set MY and DL (destinaton) address.
  XB.AT_Init
  repeat
    XB.RXFlush                                                               'clear data
    drive := XB.RXDec                                                        'accept drive values from node 0
    case drive
      1:        'forward
         servo.wheels(64, 64)
      2:        'reverse
          servo.wheels(-64, -64)
     3:        'right turn going forward
          servo.wheels(64, 0)
     4:        'left turn going forward
          servo.wheels(0, 64)
     5:        'stop
          servo.wheels(0,0)
     6:        'right turn going backwards
          servo.wheels(-64,0)
     7:        'left turn going backwards
          servo.wheels(0,-64)
