New SD mode P2 accessory board - Page 31 — Parallax Forums
1282931333436
  • evanhevanh Posts: 16,988
    edited 2025-01-18 08:14
    With the multi-issuing (per dot) of CMD10 it now consistently produces an error message on unusable rxlag values.
    I've worked out that not all SD cards react the same to pin registration. Then the timing compensation causes lsb ordering mismatch. I'm not sure of best way to resolve. I've already improved the outcome by widening the min-max search of the calibration routine so that it still finds all good cases. But when using clock divider of 2 it can still end up picking the wrong value for rxlag.
    I could reject the choice on basis that that value failed and select plus/minus one instead. Or I could try separating the pin registration step so that the search order isn't based on preconceived behaviour of the SD cards.
    EDIT: Okay, it's really at the edge of that particular card's ability I think. ie: Not a Prop2 timing limitation. Older cards are sometimes slower unsurprisingly.
    Amusingly, another SD card, the camera card, of the same brand but 6 years older is actually a faster card.
    Well, I've simply made it subtract one for correcting rxlag when it hits the mis-ordered registration issue. The default choice was rounded up on halfway. So it now kind of rounds down for this exception.
  • roglohrogloh Posts: 6,208
    I would imagine there is going to be quite a bit of variation in delay required amongst different cards at the same P2 clock freq and divider, which affects the rxlag value needed. As so many different types of cards have been released from different manufacturers there is unlikely to be some one size fits all value. Not going to be something like the PSRAM output timing from the same manufacturer for example.
    Oh, I was being way more demanding there. That was explicitly using sysclock/2 only. So the timings were tight even at low speed frequency. And that particular stress was also at high frequency, although I've forgotten exactly how fast now. Certainly beyond max freq spec for SD High Speed mode.
    edited 2025-02-17 05:01
    Okay, I've finally posted an Obex for the driver - https://obex.parallax.com/obex/sdsd-cc/
    I had left it for a while before doing some small tidying and making sense of making the driver a plug-in instead of gluing the driver file into the includes as I had been previously.
    edited 2025-02-17 04:59
    On a tangent, I've half remade the smartpin's based SPI mode driver as a plug-in too. I'm attempting to strip out the use of smartpins entirely while still keeping the performance using optimised bit-bashing instead. The aim is to make it as small as possible ... and eventually replace the built-in driver.
    It'd be neat to not have to recompile flexspin to make use of this if could eventually be bundled in somehow. The include Readme file mentions you need to edit various source files included with Flex which would imply a recompile of flexspin too before this can be used.
    edited 2025-02-17 05:58
    That's the old method. Maybe I should just remove that text.
    Yeah, if it's no longer valid.
    edited 2025-02-17 06:06
    done.
    BTW: The speedtest demo does everything for you.
    I'd forgotten how far I'd got with it. It works fine for all SD card except the two Sandisks ... they both get stuck not responding to the ACMD41 during init ...
    edited 2025-02-17 11:39
    And here's a comparison of good vs bad results:
    Adata SD card first, with normal response:
    Orange trace is CLK pin
    Blue trace is MOSI pin (command to card)
    Pink trace is MISO pin (response from card)
    Now a Sandisk SD card with abnormal response:
    It's actually responding with the same ack response as the normal response but it's three clocks late ... EDIT: And then it stops responding altogether ... so the card is definitely not happy with the situation ...
    edited 2025-02-17 12:14
    Well, the Sandisk's are happy now by adding an extra read byte after each prefixing CMD55. I can see there is a requirement for a spacer byte between a response and an adjoining command. And it seems Sandisk are the only ones adhering to that requirement.
    At this stage I'm not sure why this hadn't been a problem in the smartpin's version of driver too.
    EDIT: Oh, wow, I see. I'd been smart and shifted the order of deselect()/select() in the command sequence. I'd realised there wasn't a need to do that twice in the middle of an ACMD. But in the optimisation I'd wiped out all extra spacings as well.
    Serves me right for doing a change in the middle of a retrofit ... now reverted back to how Eric had it.
  • Wuerfel_21Wuerfel_21 Posts: 5,745
    edited 2025-02-17 12:36
    "small as possible" :+1:
    Especially if it keeps the performance.
    Incidentially, I've been having a bug with the current built-in driver: https://github.com/totalspectrum/spin2cpp/issues/471 Any ideas?
    I also wonder if, with the new multitask feature, it'd make sense to have a cogged SD driver (because the task calling into the FS code can yield to other work). I feel like smartpin SPI handling locked to a reasonable(TM) rate like sysclk/10 would be able to fit into some other PASM cog as an interrupt handler (at /10 that's one interrupt every 320 cycles)
    Can't say I've seen such behaviour. How are you obtaining that error code? Is it reading/writing/mounting? Sysclock frequency?
    I'd be inclined to run the application code as managing the file buffers between multiple tasks. Then the filesystem and driver stay together under one task.
    The usual 300-something MHz (happens regardless of 45MHz flag, so clock rate issue seems out of the picture). You can see the raw FatFS error codes if you define _DEBUG_FATFS. It does mount successfully, but it seems FatFS is lazy on this and only actually mounts on the volume when you run another function, so that's why the error comes from f_opendir or something.
    Time to ditch the old device open function and start using the new API.
    Where you have something like:
        mount("/sd", _vfs_open_sdcard());
    Replace it with:
        FILE *handle = _sdmm_open(61, 60, 59, 58);
        if(handle)
            mount("/sd", _vfs_open_fat_handle(handle));
    And -D _DEBUG_SDMM for init reporting.
    Those are really the same thing - the errors ripple through. But there is no error code, the init just fails silently.
    With _DEBUG_SDMM there's ty=12 when it (or any of the other cards) are working and ty=4 when it's broken.
    edited 2025-02-22 10:52
    Never seen a type 4 ... that's bizarre, it's failing the block-addressing check after detecting SDv2.
    BTW: I've shrunk sdmm.cc driver by 556 bytes compiled.
    EDIT: Added the demo. You can pull the driver and use it in your emulators.
    PS: The binary won't actually be smaller though, since the built-in driver doesn't get replaced.
    EDIT2: Duh! That was wrong. The built-in driver is of course excluded when not used.
  • Remember, this is the same card, just re-loading the same program binary toggles between the states.
    edited 2025-02-17 23:26
    Give sdmm_bashed a try with that SD card.
    EDIT: Oh, to quickly integrate in Spin2:
    OBJ
        c: "libc.spin2"
        sddrv: "blkdrvr/sdmm_bashed.cc"
    PRI mounsd() | handle
        handle := sddrv._sdmm2_open(61, 60, 59, 58)
        if handle
            c.mount(string("/sd"), c._vfs_open_fat_handle(handle))
    It's not a local malloc()'d object like it is in C but that's all I know off the cuff. I'd copied the C solution from how Eric had done it.
    Same thing happens, same type=4.
    Okay, try this one. Now waiting on OCR bit31(card ready) to rise first before checking the CCS bit.
    PS: I've renamed sdmm_bashed's open function to _sdmm_open(). Since it's the same parameters as the built driver, may as well use the same name.
  • I'll have to try that tomorrow
  • @evanh nope same problem
    edited 2025-02-18 13:19
    Some added debug output reporting of CMD58 in particular. eg:
       clkfreq = 200000000   clkmode = 0x10009fb
      Compiled with FlexC v7.0.4
    &_pin_clk=db18, _pin_clk = 61
    disk_initialize: PINS=61 60 59 58
     400 kHz step = 250
    idle OK
      CMD8  R7=$1aa
      CMD58  R1=$0  OCR=$c0ff8000
    type = 12,  Data Clock Rate = 25.0 MHz
    edited 2025-02-18 13:26
    Good run:
    &_pin_clk=73c68, _pin_clk = 61
     400 kHz step = 423
    idle OK
      CMD8  R7=$1aa
    type = 12,  Data Clock Rate = 42.2 MHz
      f_open returned 4
    _set_dos_error(4)
    v_opendir(NEOYUME) this=71bf8
    f_opendir returned 0
    readdir fs_read: 0
    (the f_open error is just a file-not-found because this card doesn't have PADMAP.TXT)
    Bad run:
     400 kHz step = 423
    idle OK
      CMD8  R7=$1aa
      CMD58  R1=$0  OCR=$80ff8000
    type = 4,  Data Clock Rate = 42.2 MHz
      f_open returned 13
    _set_dos_error(13)
    f_opendir returned 13
    _set_dos_error(13)
    edited 2025-02-18 13:36
    That's bizarre! It's literally reporting itself as a byte addressed card. I could just ignore it and assume all SDv2 cards are also block addressed.
    Attached now ignores the CCS bit.
  • Still busted
    &_pin_clk=73c58, _pin_clk = 61
     400 kHz step = 423
    idle OK
      CMD8  R7=$1aa
      f_open returned 13
    _set_dos_error(13)
    v_opendir(NEOYUME) this=71be8
    _set_dos_error(13)
    edited 2025-02-18 19:21
    Oh, so it's some sort of mode change then. Didn't even know that was possible.
    Here's one that retries the init a few times to see if the mode can be toggled that way:
