flexspin compiler for P2: Assembly, Spin, BASIC, and C in one compiler - Page 123 — Parallax Forums
1120121123125126130
  • pik33pik33 Posts: 2,416
    edited 2024-12-10 10:01
    There is a simple test code that shows the difference:
    test.bas:
    dim test2 as class using "objtest.spin2"
    test2.start
    print varptr(test2.var2)
    objtest.spin2:
    var
    long var1
    long var2[64]
    pub start
    var1:=@var2
    word[var2+17*12+4]:=8
    word[var2+17*12+6]:=16
    Newer compilers print 0 while older print a non zero value
    edited 2024-12-10 10:29
    Newer compiler returns value of var2[0] instead of address ov var2.. Add var2[0]:=$deadbeef to objtest.spin2 and you got "deadbeef' as a result of test.bas.
    There is a difference in list files:
    good:
    00798     C7 AA 01 F6 |     mov local01, objptr
    0079c     04 AA 05 F1 |     add local01, #4
    007a0     00 A0 05 F6 |     mov arg01, #0
    007a4     00 AC 05 F6 |     mov local02, #0
    007a8     44 0A B0 FD |     call    #__system___gettxfunc
    bad:
    00798     C7 A0 01 F6 |     mov arg01, objptr
    0079c     04 A0 05 F1 |     add arg01, #4
    007a0     D0 AA 01 FB |     rdlong  local01, arg01
    007a4     00 A0 05 F6 |     mov arg01, #0
    007a8     00 AC 05 F6 |     mov local02, #0
    007ac     44 0A B0 FD |     call    #__system___gettxfunc
    that directed me to test if the program returns a value instead of the pointer.
    edited 2024-12-10 10:42
    Yet another test: the C compiler works as expected even in the newest compiler verson. The C test program
    #include <stdio.h>
    struct __using("objtest.spin2") test2;
    void main(){
            test2.start();
            printf ("%08x\n",&test2.var2);
            printf ("%08x\n",test2.var2[0]);
    returns good values using Version 7.0.0-beta2-v7.0.0-beta2-10-g7bc1389e Compiled on: Dec 8 2024
    Only the Basic's varptr is affected.
    Trying print varptr(test2.var2(0)) - that doesn't help and still return 'deadbeef'
  • Thank you for the simple example, @pik33 . The root cause of the problem was a change to the Spin2 language to make references "transparent". This affected an internal function used to implement the BASIC varptr operation. It should be fixed now in the current github repo.
  • RaymanRayman Posts: 15,895
    @ersmith Just noticed something odd when doing "Identify Serial Ports"...
    When you do the similar "Identify Hardware" in Prop Tool, seems like the P2 reboots when done identifying.
    The flexprop version seems to put the chip in some unknown state (at least to me).
    Would it be better to have it reboot the P2 when done identifying?
  • @Rayman I think "Identify Serial Ports" fails if there's anything in the flash of the attached P2s. I should probably just remove it.
    The newest version works and compiles the interpreter.
  • evanhevanh Posts: 17,005
    edited 2024-12-14 07:57
    fwrite() is broken in newest master. It reports zero written data but it does write one block full of 0x9e repeating. errno is zero.
    EDIT: Err, no, it does report one block written.
    EDIT2: Ah-ha! Just had a squiz at fwrite() in include/libc/stdio/fwrite.c and found the bug. Fixed with this:
        size_t size = n;
        if (elemSize != 1)
            size *= elemSize;
    And I see fread() is the same ... yep, all's good again. :)
  • Thanks, @evanh
    edited 2024-12-15 07:28
    Righty-ho, the 4-bit SD mode SD card driver is ready for inclusion.
    I've zipped up the driver (sdsd.cc) and a speed tester program and my own instructions for installing it into the block driver tree. I've also included a modified version of newest fatfs_vfs.c that matches my install instructions.
    PS: I haven't written any ioctl() programming instructions. There is hints in the tester's mounting function. At this stage the control codes (#70..72) are pulled out of thin air and only defined in the driver itself. I don't know if there is preferred numbering protocol or not.
    In future I'm thinking TRIMming could be offered via ioctl() as well.
    Can exFat be enabled in FatFs now?
    Seems that needed 64-bit integers last time this was asked, but seems we have these now?
    ShouldWorkTM. Currently can't be set with external define though, need to edit ffconf.h to try it.
    It would be nice to have that virtually unlimited file size...
    edited 2024-12-22 04:40
    Eric,
    On the Fcache allocation issue again, how about allowing adding of RES directives to specify trailing cogRAM needs? That would fix it for what I'm wanting.
    And doing this would also solve a separate workaround where I've been using a bunch of enums to give labels to each of the preset parameter registers. They could be individual res 1 allocations instead. Much cleaner.
    PS: Amusingly, the C compiler doesn't complain when I have RES directives. It doesn't work either.
    EDIT: Ah, looking at the generated .lst file, I see RES is copied like a DAT LONG would be. That would need fixed along with whatever is causing the crash.
    00a68     97 1A 48 FB |     callpa  #(@LR__0040-@LR__0030)>>2,fcache_load_ptr_
    00a6c                 | LR__0030
    00a6c 000             |     org 0
    00a6c 000 F0 1D 80 FE |     loc pa, #@_dat_ + 4
    00a70 001 28 10 64 FD |     setq    #8
    00a74 002 F6 1B 00 FB |     rdlong  LR__0031, pa
    00a78 003 0D AA 01 F6 |     mov local01, LR__0031
    00a7c 004 0E AC 01 F6 |     mov local02, LR__0032
    00a80 005 0F AE 01 F6 |     mov local03, LR__0033
    00a84 006 10 B0 01 F6 |     mov local04, LR__0034
    00a88 007 11 B2 01 F6 |     mov local05, LR__0035
    00a8c 008 12 B4 01 F6 |     mov local06, LR__0036
    00a90 009 13 B6 01 F6 |     mov local07, LR__0037
    00a94 00a 14 B8 01 F6 |     mov local08, LR__0038
    00a98 00b 15 BA 01 F6 |     mov local09, LR__0039
    00a9c 00c 24 00 90 FD |     jmp #LR__0040
    00aa0 00d             | LR__0031
    00aa0 00d             |     res 1
    00aa0 00e             | LR__0032
    00aa0 00e             |     res 1
    00aa0 00f             | LR__0033
    00aa0 00f             |     res 1
    00aa0 010             | LR__0034
    00aa0 010             |     res 1
    00aa0 011             | LR__0035
    00aa0 011             |     res 1
    00aa0 012             | LR__0036
    00aa0 012             |     res 1
    00aa0 013             | LR__0037
    00aa0 013             |     res 1
    00aa0 014             | LR__0038
    00aa0 014             |     res 1
    00aa0 015             | LR__0039
    00aa0 015             |     res 1
    00aa0 016             |     fit 128
    00aa0 016             | LR__0040
    00aa0                 |     orgh
    EDIT2: Attached a test program.
    Some glitches after a year gap in developing the player.
    D:/Programowanie/P2-retromachine-2/Propeller/P2P16/player33.bas:1605: error: Inline assembly too large to fit in fcache
    Did the fcache shrink? The player compiled earlier...
    edited 2024-12-23 11:47
    Yes, the default was reduced to fit, I think, the growing, but optional, byte-code VM. Compile using --fcache=256 to get it larger when compiling for native.
    PS: It can go bigger than 256 but I'd hope you're not using more than that.
    edited 2024-12-23 12:29
    I managed to strip one long from the code (and then it fit) but this --fcache=256 will go to the command line. I don't use bytecode (yet?)
    Edit: that was not a good idea. However, fcache=192 did the trick. fcache=256 seems to be too big and generated errors - code too big to fit in the cog
    I can reserve up to 360 when compiling the SD card speed tester. I guess something else must also consume cogRAM then.
    edited 2024-12-23 13:29
    The program - a multiformat media player - is big, including an mp3 decoder. and several other objects.
    dim v as class using "hg008.spin2"
    dim rm as class using "usbnew.spin2"
    dim tracker as class using "trackerplayer.spin2"
    dim paula as class using "audio093b-8-sc.spin2"
    dim sid as class using "sidcog8.spin2"
    dim psram as class using "psram.spin2"
    dim spc as class using "spccog.spin2"
    dim a6502 as class using "a6502-1.spin2"
    dim mp3 as class using "mp3.c"
    I don't know what needs the space in the cog. My code that didn't fit in the has (about) 128 longs in it. Maybe the standard size is now 128
    Reading the basic.md file, it looks like there is four ways to compile the Basic source code:
A predefined symbol is also generated for type of output being created:
    __OUTPUT_ASM__ | if PASM code is being generated
    __OUTPUT_BYTECODE__ | if bytecode is being generated
    __OUTPUT_C__ | if C code is being generated
    __OUTPUT_CPP__ | if C++ code is being generated
    What's the chances you're compiling for byte-code?
    edited 2024-12-23 15:09
    0
    I tried the bytecode, it is way too slow for this program to run.
    I think it should be possible to use this without having to make any changes to the flexspin include tree, by using the _vfs_open_fat_handle() function and providing a block driver open function that exports a vfs_file_t *.
    We don't really have any standard yet for ioctls. I think the Linux kernel reserves some bits in the ioctl command to specify the kind of device that it applies to, maybe we could do something similar.
  • @evanh said:
    Eric,
    I think that should work now.
    No, although I can see why you thought that: the fcache load call uses @ addresses (HUB RAM) rather than COG addresses to calculate the size of the data to load. RES doesn't occupy any HUB space, so this actually all works out (as long as the RES all appear at the end).
    Oops, right, I wasn't really looking.
    @ersmith said:
    @evanh said:
    Eric,
    No change. :( Looks like RES space is messing with Fcache's ALTD placement of the RET instruction. Might be time to throw away that mechanism of branching to a common RET.
    FCACHE_LOAD_
        mov fcache_tmpb_,ptrb
        pop ptrb
        altd    pa,ret_instr_
        mov  0-0, ret_instr_
        setq    pa
        rdlong  $0, ptrb++
        push    ptrb
        mov ptrb,fcache_tmpb_
        jmp #\$0 ' jmp to cache
    ret_instr_
        _ret_ cmp inb,#0
    fcache_tmpb_
        long 0
    fcache_load_ptr_
        long FCACHE_LOAD_
  • The final RET is needed so that code that doesn't explicitly return returns. You should be able to put a manual ret...
    edited 2024-12-31 02:36
    Yeah, nice, it worked. I did four changes:
    • Moved the driver file out into the user source directory. EDIT: Now in a subdirectory blockdrivers.
    • Moved the driver opening function, _sdsd_open(), out to the user program. Since it references the driver file I don't suppose this can be placed in the driver itself? EDIT: Moved to a new file in the subdirectory.
    • Changed that function's driver reference path from struct __using("filesys/block/sdsd.cc") *SDSD; to struct __using("sdsd.cc") *SDSD;. EDIT: Now struct __using("blockdrivers/sdsd.cc") *SDSD;
    • And changed one line in the driver: #include "../fatfs/diskio.h" becomes #include <filesys/fatfs/diskio.h>
    EDIT: Made it feel cleaner by putting the driver in its own directory along with a new file sdsd_vfs.c just for the driver opening function. The user program now just has to include the new file before calling _sdsd_open().
    @Wuerfel_21 said:
    ... You should be able to put a manual ret...
    Those all get replaced with branches to that final RET.
  • ersmithersmith Posts: 6,231
    @evanh There was an optimizer issue which caused everything to fall down if there were RET statements inside inline assembly. I think that's fixed now in github; at least, I can compile a simple test program OK. If all else fails, you can insert a long $fd64002d as a RET instruction :) but that shouldn't be necessary.
    edited 2025-01-03 01:42
    cool, I see a lot of changes in master branch ...
    Working so far. But I've hit a niggle that is probably something Chip needs to sort out - I now want to insert register symbol references into dat values at compile time. Currently I get error: data item is not constant
    eg:
    altireg     long pa<<19 | cogdatbuf<<9    // register PA for ALTI result substitution, and CRC buffer address
    edited 2025-01-03 02:52
    Found something weird. In one of my more complex routines, if I use a _RET_ modifier, irrespective of any following RET instruction, it looks to be screwing up an unrelated variable. And probably worse, because it crashes. The variables to registers mappings must be messed up. Won't be easy to replicate I suspect, it didn't happen on first routine I converted.
    I note that all _RET_s get auto-converted to separate RET instructions anyway. So, to be safe, I've eliminated all _RET_ modifiers for now.
