New SD mode P2 accessory board - Page 28 — Parallax Forums
1252628303136
  • RaymanRayman Posts: 15,988
    Same, but only worked for me in latest PNut before...
  • evanhevanh Posts: 17,051
    Hehe, I'm ripping up the old sdspi_bashed code big time. Nothing is untouched. Amazingly no bugs. It's already a whole lot more reliable in fact.
    @evanh Fixing up the 1-bit code too?
    Could definitely use improvement.
    edited 2024-12-01 07:04
    Done. Checked at 360 MHz sysclock with all my SD cards.
    PS: Also now checked at 360 MHz sysclock on the Eval Board's built-in SD slot. Still works even with that protective inline resistor slowing things down. :)
    Looking at the error numbers in "FAT32" I see there is no distinction or meaning to individual numbers at the driver level. Any negative return code becomes error1, "Disk IO Error".
    As a result, I haven't tried to assign any meaning to the error numbers in the driver.
    @evanh Did you see the cogged version of the 1-bit driver?
    I remember seeing it be faster with that...
    But, it's been a while since looked at it...
    edited 2024-11-30 23:22
    Product!
    One just tested even seems to work!
    Have so many copies of speed_test.c, but only latest seems to work, probably messed around too much trying to make work.
    Had to add --fcache=256 again. Not sure how that keeps getting turned off...
    Had to substitute 0603 1uF for 0402 4.7uF, but pretty sure that's OK...
    1512 x 2016 - 678K
    @Rayman said:
    Product!
    You got those fully assembled, right? Six in one lot. Price?
    edited 2024-12-01 00:17
    Prop2 can do the driver just fine cog-less. If the filesystem object could make use of concurrency sure add the extra cog then, but that would also burn more RAM both in the buffering requirements and the code bloat managing it.
    PS: That's where Command-Queuing becomes useful too. When the filesystem object can make multiple requests and able to work with completion notifications rather than doing everything sequentially. But it is a lot for the code to manage so memory needs blow out.
    edited 2024-12-01 03:02
    Rayman,
    You've been using a "platform" config file of some sort haven't you? How does that work? Does it get loaded somehow?
    I've just added a pin map setting mechanism to the driver init that can be passed through the filesystem handler without it knowing the pins explicitly. I now have a growing table of pinout configs to choose from. It's done as a small DAT set built from larger sets of CONstants at the top of the tester program but it's obviously better if it was separated to be a general selection file or one file for each platform build.
    Been doing include “platform.h”
    Thinking about switching to config.spin2 or config.h though …
    Is the 4-bit speed test good enough to say breakouts are 100% good?
    edited 2024-12-01 20:33
    How is it used? Have you got an example for me to look at? Spin example preferably.
    For it to be used as a quality tester? Yeah, don't see why not. It does lots of checks. And especially with the basic debug set on it also says why it had any trouble.
    edited 2024-12-02 11:05
    I've got FSRW hooked up and seems to work. Haven't had it mess up anything on its own.
    I'm planning on merging the function/method naming of the two APIs. They don't seem to be all that far apart even though they appear drastically different at first look.
    200 MHz sysclock, 2017 32GB Sandisk Extreme, compiled with Flexspin
    fat32fs + sdspi_bashed3
    Writing 4096 kiB file ................................................................................................................................
    Writing took: 8198 milliseconds, 499 kiB/s
    Verifying content ... Passed!
    Reading took: 3140 milliseconds, 1304 kiB/s
    fsrw + sdspi_bashed3
    Writing took: 7493 milliseconds, 546 kiB/s
    Reading took: 3020 milliseconds, 1356 kiB/s
    fat32fs + sdsd_dma
    Writing took: 6702 milliseconds, 611 kiB/s
    Reading took: 1910 milliseconds, 2144 kiB/s
    fsrw + sdsd_dma
    Writing took: 6195 milliseconds, 661 kiB/s
    Reading took: 1754 milliseconds, 2335 kiB/s
    Is that 4-bit mode?
    Looks like 1-bit speeds ?
    200 MHz sysclock, 2017 32GB Sandisk Extreme, compiled with Pnut
    Writing took: 8887 milliseconds, 460 kiB/s
    Reading took: 3934 milliseconds, 1041 kiB/s
    Writing took: 7986 milliseconds, 512 kiB/s
    Reading took: 3582 milliseconds, 1143 kiB/s
    fat32fs + sdsd_dma
    Writing took: 6922 milliseconds, 591 kiB/s
    Reading took: 2206 milliseconds, 1856 kiB/s
    fsrw + sdsd_dma
    Writing took: 6246 milliseconds, 655 kiB/s
    Reading took: 1925 milliseconds, 2127 kiB/s
    @Rayman said:
    Is that 4-bit mode?
    It's both. sdsd_dma is 4-bit SD mode, and sdspi_bashed3 is 1-bit SPI mode.
    Yes, the performance sucks at the filesystem layer. Neither FSRW nor FAT32FS have block level API. And both only work with a single block at a time.
  • The P1 block driver for fsrw speculatively prefetches the next sector. Multi-block transfers into contiguous memory aren't so useful on P1, that's why neither of the spin FAT drivers really optimizes it.
    Ah, I had seen comments alone those lines but I never understood it was the driver doing it.
    Well, at least around 2X faster. That's something.
    Guess really need to use FlexProp for the high speed then...
    Here's an example of a platform.h with sorta relevant stuff in it.
    The top .c file starts with:
    #include "Platform.h"
    edited 2024-12-02 21:29
    @Wuerfel_21 does something similar with MegaYume, but the main file is .spin2 and the top CON section there does:
    #include "config.spin2"
    I may change mine to be called config.h at some point for C work.
    But, still use Prop Tool for Spin2 and guess can't do #include
    On the other hand, if want to use new structures, may switch to SpinIDE and maybe #include works there...
    edited 2024-12-02 22:05
    Okay, is using a Flexspin feature then.
    Here's my current top level developer presentation:
    DAT
    '  ***  PINOUTS  ***
    ' Choose one:  Uncomment one SD_PIN_ARGS line from the following pinout selections
    ' Pinouts for the SPI mode SD card driver "sdspi_bashed3.spin2": cog-less
    '    SD_PIN_ARGS    byte SDTYPE_SPI, MISO_EVAL, MOSI_EVAL, CS_EVAL, CLK_EVAL
    '    SD_PIN_ARGS    byte SDTYPE_SPI, MISO_RL, MOSI_RL, CS_RL, CLK_RL
    '    SD_PIN_ARGS    byte SDTYPE_SPI, MISO_EH, MOSI_EH, CS_EH, CLK_EH
    ' Pinouts for the 4-bit SD mode driver "sdsd_dma.spin2": cog-less
        SD_PIN_ARGS    byte SDTYPE_SD, SD_CLK_DIV, CLK_RL, CMD_RL, DAT0_RL, PWR_RL, LED_RL
    '    SD_PIN_ARGS    byte SDTYPE_SD, SD_CLK_DIV, CLK_EH, CMD_EH, DAT0_EH, -1, -1
    CON
    ' Used by the filesystem layer to select internal driver
        SDTYPE_SPI  = 1    ' "sdspi_bashed3.spin2" 1-bit SPI mode driver
        SDTYPE_SD   = 2    ' "sdsd_dma.spin2" 4-bit SD driver
    ' Prop2 boot pins, set in the Prop2 ROM
        #58, MISO_EVAL, MOSI_EVAL, CS_EVAL, CLK_EVAL
    ' Clock divider used by "sdsd_dma.spin2" 4-bit SD driver
        SD_CLK_DIV  = 4
    ' Roger Loh's 4-bit add-on board
        RL_BASE_PIN = 16
        DAT0_RL     = RL_BASE_PIN+0    ' MISO, DO
        DAT1_RL     = RL_BASE_PIN+1
        DAT2_RL     = RL_BASE_PIN+2
        DAT3_RL     = RL_BASE_PIN+3    ' CS
        CMD_RL      = RL_BASE_PIN+4    ' MOSI, DI
        CLK_RL      = RL_BASE_PIN+5    ' SCLK
        LED_RL      = RL_BASE_PIN+6  ' output to red LED
        PWR_RL      = RL_BASE_PIN+7  ' Card-Detect input, and power switch, and green LED
        CS_RL       = DAT3_RL
        MOSI_RL     = CMD_RL
        MISO_RL     = DAT0_RL
    ' My hand wired full sized 4-bit SD slot
        EH_BASE_PIN = 40
        CMD_EH      = EH_BASE_PIN+2    ' MOSI, DI
        CLK_EH      = EH_BASE_PIN+3    ' SCLK
        DAT0_EH     = EH_BASE_PIN+4    ' MISO, DO
        DAT1_EH     = EH_BASE_PIN+5
        DAT2_EH     = EH_BASE_PIN+6
        DAT3_EH     = EH_BASE_PIN+7    ' CS
        CS_EH       = DAT3_EH
        MOSI_EH     = CMD_EH
        MISO_EH     = DAT0_EH
    edited 2024-12-06 06:58
    I wrote a version of the speed tester in Spin2 that uses Flexspin's "libc.spin2" object for its file read/write and FAT32 layer.
    200 MHz sysclock, 2017 32GB Sandisk Extreme:
    libc + sdmm (1-bit SPI mode via smartpins)
    Cog0  Buffer size = 16 kB,  repeats = 128
    Cog0  Written 2048 kB in 858 ms,  2386 kB/s
    Cog0  Verified
    Cog0  Read 2048 kB in 728 ms,  2813 kB/s
    libc + sdsd_dma (4-bit SD mode via streamer)
    Cog0  Written 2048 kB in 221 ms,  9266 kB/s
    Cog0  Verified
    Cog0  Read 2048 kB in 105 ms,  19504 kB/s
    edited 2024-12-06 07:02
    Actually, that smartpins version ain't any better than what bit-bashed could achieve. Maybe worse in fact. I'm temped to have another blast at that sdmm.cc driver again. Bound to end up smaller without all the smartpins config.
  • MXXMXX Posts: 20
    edited 2024-12-06 13:32
    DAT
    '  ***  PINOUTS  ***
    CON
        SD_CLK_DIV  = 4
        RL_BASE_PIN = 16
        CS_RL       = DAT3_RL
        MOSI_RL     = CMD_RL
        MISO_RL     = DAT0_RL
        EH_BASE_PIN = 40
        CS_EH       = DAT3_EH
        MOSI_EH     = CMD_EH
        MISO_EH     = DAT0_EH
    @evanh, very impressive speed test results!
    Are there any advanges / drawbacks in using your hand wire pins sequence vs rloh add on board sequence? Are them 100% equivalent?
    Sorry for jumping in the topic but I'm designing a P2 board with uSD card slot and I would appreciate your suggestions to choose the best hardware solution.
    Massimo
    @evanh
    Libc.spin2 ?
    Is that for doing c type things in spin2?
    Haven’t used that.
    But, this sounds like a good case for it…
    edited 2024-12-06 14:43
    @Rayman said:
    @evanh
    Libc.spin2 ?
    Haven’t used that.
    Yeah, I didn't know about it until recently either. It's literally using C's libc. Flexspin allows importing objects from all three supported languages. Although "libc" is special in that it's the whole standard C library and then some. The device registering functions are extra for example.
    Anyway, it's unique to Flexspin so won't compile on any other Spin2 compiler.
    No power switch, and no indicator LED. Otherwise they function the same, yes. LED is unimportant but I would advise to have the power switch.
    Placing the DAT pins first or last doesn't matter, no. I was just proving it as part of doing the hand wiring.
