StrToFloat() — Parallax Forums
StrToFloat()
cgraceycgracey Posts: 14,280
edited 2024-02-21 10:33 in Propeller 2
I made a StrToFloat method using the built-in Spin2 floating-point operators.
It accepts numbers in all formats and converts them to single-precision IEEE-754 floats:
123
123.456
0.00000000000000000000000012345
1.0
1.0e9
1.0e+9
1.0e-9
1e12
9e+45
1_000_000_000
So, no decimal point is needed. "E" is allowed for power-of-ten exponents. Underscores are allowed for grouping in the mantissa, but not in the exponent. It also checks for errors and ABORTS with messages.
' Get floating-point value - source_ptr must point to first digit
PRI get_float() : fp | n, dflag, nflag, exp
  repeat                                'MAC mantissa digits
    fp := fp *. 10.0 +. fp_dig[source_chr() & $0F]
    repeat while source_test("_")       'skip any "_" chrs
    if dflag                            'hold magnitude after decimal point
      n++
    if source_test(".")                 'check for decimal point, one only
      if dflag~~
        abort(@"Extra decimal point")
  while source_digit_next()             'another digit?
  if source_test_uppercase("E")         'check for exponent
    if source_test("-")                 'if "-", set negative flag
      nflag~~
    else                                'else, skip any "+"
      source_test("+")
    if not source_digit_next()          'make sure exponent digit
      abort(@"Expected exponent digit")
    repeat                              'MAC exponent digits
      exp := exp * 10 + source_chr() & $0F
    exp <#= 99                          'limit exponent, still under/overflows
    n -= (nflag ? -exp : exp)
  repeat while n                        'adjust magnitude
    exp := n #> -12 <# 12
    fp := fp /. fp_exp[exp]
    n -= exp
  if NaN(fp)                            'check overflow
    abort(@"Floating-point overflow")
DAT
fpstr   byte    "1.175494e+9",0         'test string
fp_dig  long    0.0, 1.0, 2.0, 3.0, 4.0, 5.0, 6.0, 7.0, 8.0, 9.0
        long                                1e-12, 1e-11, 1e-10, 1e-09
        long    1e-08, 1e-07, 1e-06, 1e-05, 1e-04, 1e-03, 1e-02, 1e-01
fp_exp  long    1e+00, 1e+01, 1e+02, 1e+03, 1e+04, 1e+05, 1e+06, 1e+07
        long    1e+08, 1e+09, 1e+10, 1e+11, 1e+12
  • Added to OBEX : https://obex.parallax.com/obex/strtofloat/
    Once you finish the intense video driver work Chip, we'll get you setup with an OBEX account and have these objects moved to your name.
  • JonnyMacJonnyMac Posts: 9,296
    edited 2024-02-21 15:02
    @cgracey : Consider making a source pointer argument so that the method can be used with any string.
    pri get_float(p_src) : fp | n, dflag, nflag, exp
    Sounds good.
  • RaymanRayman Posts: 15,184
    I'm not sure I appreciated that Spin2 supports floating point much more than Spin1 until just now...
    String to float could be very useful.
    Have to figure out how to use floats in Spin2 first...
    I see this in the docs:
    x *. y
    Does this mean multiplying signed integer with float? Is this possible to do?
    Can I multiply two floats?
    Can I convert integer to float?
    Some things to figure out...
    edited 2024-02-22 03:13
    x *. y
    Because Spin2 is type-agnostic at runtime, you must use special floating-point operators to do floating-point operations. And be sure to do them on LONGs that can hold 32 bits:
     -. (subtract / negate)
    So, just use these operators and you're doing floating-point.
    Here is a new version that works on a string you point it to. It is self-contained and doesn't call any other methods.
    ' https://baseconvert.com/ieee-754-floating-point
    pub go() | error
      if error := \doit()                   'call with abort trap, show any error
        debug(zstr(error))
    PRI doit() | fp
      fp := get_float(@fp_str)              'call and show results
      debug(fdec(fp), uhex(fp))
    ' Get floating-point value - ptr must point to first digit
    PRI get_float(ptr) : fp | n, dflag, nflag, exp
      repeat while byte[ptr] == " "                 'skip any spaces
        ptr++
      ifnot lookdown(byte[ptr]: "0".."9")           'make sure digit
        abort(@"Expected digit")
        fp := fp *. 10.0 +. fp_dig[byte[ptr++] & $0F]
        repeat while byte[ptr] == "_"               'skip any "_" chrs
          ptr++
          n++
        if byte[ptr] == "."                         'check for single decimal point
          ptr++
          if dflag~~
      while lookdown(byte[ptr]: "0".."9")           'another digit?
      if lookdown(byte[ptr]: "E", "e")              'check for exponent
        ptr++
        if byte[ptr] == "-"                         'if "-", set negative flag
          ptr++
          nflag~~
          if byte[ptr] == "+"
            ptr++
        if not lookdown(byte[ptr]: "0".."9")        'make sure exponent digit
          exp := exp * 10 + byte[ptr++] & $0F
        n -= exp
    DAT
    fp_str  byte    "0.00000000001e-9",0                    'test string
    x *. y
    FLOAT(integer) : float
    ROUND(float) : integer
    TRUNC(float) : integer
    The floating-point operators work on floats, only. Use FLOAT/ROUND/TRUNC to go between integers and floats.
    pub go() | error
        debug(zstr(error))
    PRI doit() | fp
        ptr++
          ptr++
          n++
          ptr++
          if dflag~~
        ptr++
          ptr++
          nflag~~
          if byte[ptr] == "+"
            ptr++
        n -= exp
    DAT
    @cgracey
    It appears your routine won't work with negative floating values (i.e. "-1.02"), it complains that it is expecting a digit as the first string character. It works OK with positive and negative exponents, but not with negative values.
    edited 2024-02-22 11:09
    pub go() | error
        debug(zstr(error))
    PRI doit() | fp
        ptr++
          ptr++
          n++
          ptr++
          if dflag~~
        ptr++
          ptr++
          nflag~~
          if byte[ptr] == "+"
            ptr++
        n -= exp
    DAT
    @cgracey
    Thanks for noticing this. I just added that...
    UPDATED
  • @cgracey
    Thanks Chip, it works for negative values now.
  • VonSzarvasVonSzarvas Posts: 3,584
    edited 2024-02-22 09:22
    StrToFloat OBEX updated with the negative fix : https://obex.parallax.com/obex/strtofloat/
    Thanks, Michael.
    Could you please put the latest file I posted in place of the older one in there? I posted a new file 3 posts up which handles regular strings. It needs to be renamed from StrToFloat2.spin2 to StrToFloat.spin2. That is the one people should be using. Thanks a lot.
  • Since the string could come from outside the P2, you might consider stripping all leading whitespace characters:
      repeat while lookdown(byte[ptr] : 32, 9..13)
        ptr++
    edited 2024-02-22 23:55
    Is there an inverse function? FloatToStr()?
    BTW: Seeing how the floating point ops work now. At first, looked like the "." was operating on y and not the operator.
    When I first looked at it, was not seeing the spaces before and after the operator. A lot clearer now.
    x *. y
    Also, I see the Float() and Round() methods that make using all this viable..
    edited 2024-02-23 15:08
    I made a small variation of Chip's object that uses a second return value for the error code instead of using the abort mechanism. For testing, there is a method in the object that converts the error code to the strings Chip used. The test program demonstrates this -- though I don't know how to make the object return the NaN error.
