P1 Video scaling
pic18f2550
Hello,
I would like to modify this driver a little.
The resolution in the memory is 256x192.
The resolution on the monitor is 512x384.
To double the lines is no problem but how do I get the pixel 2x in a row?
Halving the pixel clock is not possible with 35MHz.
Does anyone have a tip?
To half the pixelrate, try to change:
into
or set the PLL to x2 instead of x4
Andy
Edit: You also need to set the pixel based constants like hp, vp, hf, hs, hb to half the value.
Far simpler, no need to change the main video clock, just double up the VSCL value used for the visible area. See documentation for that register.
vscl_pixel long 1 << 12 + 32 '1 pixel per clock and 32 pixels per set----->
vscl_pixel long 2 << 12 + 32 '2 pixelclock per pixel and 32 pixels per setWith the correct description, I now also understand this.
' xtiles = hp / 32 '{Pixelbreite} xtiles = hp / 64 '{Pixelbreite}You actually need to double the 32, too. That indicates the number of video clocks per WAITVID tile. So by setting
2 << 12 + 32, you only actually get the first 16 pixels.Ok.
I couldn't recognise this connection in the translated texts.
Thank you.
vscl_pixel long 2 << 12 + 64 '2 pixelclock per pixel and 32 pixels per set
